[fusion-commits] r2273 - trunk/templates/mapguide/standard
svn_fusion at osgeo.org
Fri Nov 5 14:30:23 EDT 2010
Author: madair
Date: 2010-11-05 11:30:23 -0700 (Fri, 05 Nov 2010)
New Revision: 2273
trunk/templates/mapguide/standard/ApplicationDefinition.xml
re #311: update MapGuide template for Jx3.0
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml 2010-11-05 18:23:10 UTC (rev 2272)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml 2010-11-05 18:30:23 UTC (rev 2273)
@@ -8,9 +8,9 @@
* application.
- <MapSet xsi:type="MapSetType">
- <MapGroup id="sheboygan" xsi:type="MapType">
- <Map xsi:type="MapGuideLayerType">
+ <MapSet>
+ <MapGroup id="sheboygan">
+ <Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
@@ -22,8 +22,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="mixed" xsi:type="MapType">
- <Map xsi:type="WMSLayerType">
+ <MapGroup id="mixed">
+ <Map>
<Type>WMS</Type>
<Extension>
<ResourceId>http://localhost/cgi-bin/testwms.exe</ResourceId>
@@ -39,7 +39,7 @@
</Parameters>
</Extension>
</Map>
+ <Map>
<Extension>
@@ -50,8 +50,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="sheboygan-tiled" xsi:type="MapType">
+ <MapGroup id="sheboygan-tiled">
+ <Map>
<SingleTile>false</SingleTile>
<Extension>
@@ -59,8 +59,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="gmap-tiled" xsi:type="MapType">
+ <MapGroup id="gmap-tiled">
+ <Map>
<Extension>
@@ -70,8 +70,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="gmap" xsi:type="MapType">
+ <MapGroup id="gmap">
+ <Map>
<Extension>
@@ -81,8 +81,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="wmsOnly" xsi:type="MapType">
+ <MapGroup id="wmsOnly">
+ <Map>
<Type>WMS</Type>
<Extension>
@@ -115,7 +115,7 @@
<ResourceId>ve</ResourceId>
</Extension>
</Map>
+ <Map>
<Extension>
@@ -141,7 +141,7 @@
<ResourceId>google</ResourceId>
</Extension>
</Map>
+ <Map>
<Extension>
@@ -154,8 +154,8 @@
</Extension>
</Map>
</MapGroup>
- <MapGroup id="google" xsi:type="MapType">
+ <MapGroup id="google">
+ <Map>
<Type>Google</Type>
<Extension>
@@ -178,7 +178,7 @@
* application.
- <WidgetSet xsi:type="WidgetSetType">
+ <WidgetSet>
* ContextMenu (Tasks)
@@ -186,14 +186,14 @@
* Menu available to the Task Pane
- <Container xsi:type="UiItemContainerType">
+ <Container>
<Name>TaskContextMenu</Name>
<Type>ContextMenu</Type>
- <Item xsi:type="WidgetItemType">
+ <Item>
<Function>Widget</Function>
<Widget>menuMeasure</Widget>
</Item>
+ <Item>
<Widget>toolbarBuffer</Widget>
</Item>
@@ -205,124 +205,124 @@
* Menu available to the Map on right-click
+ <Container>
<Name>MapContextMenu</Name>
+ <Item>
<Widget>menuRefreshMap</Widget>
</Item>
- <Item xsi:type="SeparatorItemType">
+ <Item>
<Function>Separator</Function>
</Item>
+ <Item>
<Widget>menuPan</Widget>
</Item>
+ <Item>
<Widget>menuZoomInRectangle</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>menuZoomInFixed</Widget>
</Item>
+ <Item>
<Widget>menuZoomOutFixed</Widget>
</Item>
+ <Item>
</Item>
- <Item xsi:type="FlyoutItemType">
+ <Item>
<Function>Flyout</Function>
<Label>Zoom</Label>
<Tooltip>Open the zoom menu</Tooltip>
<ImageUrl/>
<ImageClass/>
+ <Item>
<Widget>menuInitialMapView</Widget>
</Item>
+ <Item>
<Widget>menuPreviousView</Widget>
</Item>
+ <Item>
<Widget>menuNextView</Widget>
</Item>
+ <Item>
<Widget>menuInitialMapScaleAndCenter</Widget>
</Item>
+ <Item>
<Widget>menuZoomSelection</Widget>
</Item>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>menuSelect</Widget>
</Item>
+ <Item>
<Widget>menuClearSelection</Widget>
</Item>
+ <Item>
<Label>Select More</Label>
<Tooltip>Open the select menu</Tooltip>
<ImageUrl/>
<ImageClass/>
+ <Item>
<Widget>menuSelectRadius</Widget>
</Item>
+ <Item>
<Widget>menuSelectPolygon</Widget>
</Item>
+ <Item>
<Widget>menuSelectWithin</Widget>
</Item>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>menuBuffer</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>menuViewOptions</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>menuHelp</Widget>
</Item>
+ <Item>
<Widget>menuAbout</Widget>
</Item>
@@ -334,86 +334,86 @@
+ <Container>
<Name>Toolbar</Name>
<Type>Toolbar</Type>
+ <Item>
<Widget>MapMenu</Widget>
</Item>
+ <Item>
<Widget>toolbarHelp</Widget>
</Item>
+ <Item>
<Widget>toolbarViewOptions</Widget>
</Item>
+ <Item>
<Widget>GetPrintablePage</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>Select</Widget>
</Item>
+ <Item>
<Widget>Pan</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>ZoomInRectangle</Widget>
</Item>
+ <Item>
<Widget>ZoomInFixed</Widget>
</Item>
+ <Item>
<Widget>ZoomOutFixed</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>toolbarSecondaryInitialMapView</Widget>
</Item>
+ <Item>
<Widget>toolbarSecondaryPreviousView</Widget>
</Item>
+ <Item>
<Widget>toolbarSecondaryNextView</Widget>
</Item>
+ <Item>
</Item>
+ <Item>
<Widget>toolbarSecondaryZoomSelection</Widget>
</Item>
+ <Item>
<Widget>toolbarSelectPolygon</Widget>
</Item>
+ <Item>
<Widget>toolbarSelectRadius</Widget>
</Item>
+ <Item>
<Widget>toolbarMeasure</Widget>
</Item>
+ <Item>
<Widget>toolbarSaveMap</Widget>
</Item>
@@ -427,22 +427,31 @@
+ <Container>
<Name>Statusbar</Name>
- <Type>Splitterbar</Type>
+ <Type>Toolbar</Type>
+ <Item>
<Widget>StatusCoords</Widget>
</Item>
+ <Item>
+ <Function>Separator</Function>
+ </Item>
+ <Item>
<Widget>StatusSelection</Widget>
</Item>
+ <Item>
+ </Item>
+ <Item>
<Widget>StatusScale</Widget>
</Item>
+ <Item>
+ </Item>
+ <Item>
<Widget>StatusViewSize</Widget>
</Item>
@@ -450,11 +459,11 @@
<!-- MAP -->
- <MapWidget xsi:type="WidgetType">
+ <MapWidget>
<Name>Map</Name>
<Type>Map</Type>
<StatusText>The map.</StatusText>
- <Extension xsi:type="CustomContentType">
+ <Extension>
<MenuContainer>MapContextMenu</MenuContainer>
<!--Scales>100000,50000,25000,12500,8000,4000</Scales-->
</Extension>
@@ -469,7 +478,7 @@
<!-- CONTEXT MENU PAN -->
- <Widget xsi:type="UiWidgetType">
+ <Widget>
<Name>menuPan</Name>
<Type>Pan</Type>
<StatusText>Drag the map to view areas out of range.</StatusText>
@@ -482,11 +491,11 @@
<!-- CONTEXT MENU ZOOM RECTANGLE -->
+ <Widget>
<Name>menuZoomInRectangle</Name>
<Type>Zoom</Type>
<StatusText>Zoom in on an area.</StatusText>
+ <Extension>
<Tolerance>5</Tolerance>
<Factor>2</Factor>
</Extension>
@@ -499,11 +508,11 @@
<!-- CONTEXT MENU ZOOM FIXED (IN) -->
+ <Widget>
<Name>menuZoomInFixed</Name>
<Type>ZoomOnClick</Type>
<StatusText>Zoom in by a preset increment.</StatusText>
+ <Extension>
<Factor>2</Factor>
</Extension>
<ImageUrl>images/icons.png</ImageUrl>
@@ -515,7 +524,7 @@
<!-- CONTEXT MENU REFRESH MAP -->
+ <Widget>
<Name>menuRefreshMap</Name>
<Type>RefreshMap</Type>
<StatusText>Refreshes the map image.</StatusText>
@@ -528,11 +537,11 @@
<!-- CONTEXT MENU ZOOM FIXED (OUT) -->
+ <Widget>
<Name>menuZoomOutFixed</Name>
<StatusText>Zoom out by a preset increment</StatusText>
+ <Extension>
<Factor>0.5</Factor>
</Extension>
@@ -544,11 +553,11 @@
<!-- CONTEXT MENU INITIAL MAP VIEW -->
+ <Widget>
<Name>menuInitialMapView</Name>
<Type>InitialMapView</Type>
<StatusText>Fit the extents of the map to the window</StatusText>
+ <Extension>
<ViewType>extent</ViewType>
</Extension>
@@ -560,11 +569,11 @@
<!-- CONTEXT MENU PREVIOUS VIEW -->
+ <Widget>
<Name>menuPreviousView</Name>
<Type>ExtentHistory</Type>
<StatusText>Go to previous view.</StatusText>
+ <Extension>
<Direction>previous</Direction>
</Extension>
@@ -576,11 +585,11 @@
<!-- CONTEXT MENU NEXT VIEW -->
+ <Widget>
<Name>menuNextView</Name>
<StatusText>Go to next view.</StatusText>
+ <Extension>
<Direction>next</Direction>
</Extension>
@@ -592,11 +601,11 @@
+ <Widget>
<Name>menuInitialMapScaleAndCenter</Name>
<StatusText>Zoom to initial map center and scale.</StatusText>
+ <Extension>
<ViewType>center</ViewType>
</Extension>
@@ -608,7 +617,7 @@
<!-- CONTEXT MENU ZOOM SELECTION -->
+ <Widget>
<Name>menuZoomSelection</Name>
<Type>ZoomToSelection</Type>
<StatusText>Zoom to the extents of the current selection.</StatusText>
@@ -621,7 +630,7 @@
<!-- CONTEXT MENU SELECT -->
+ <Widget>
<Name>menuSelect</Name>
<Type>Select</Type>
<StatusText>Select features by clicking and dragging.</StatusText>
@@ -634,7 +643,7 @@
<!-- CONTEXT MENU CLEAR SELECTION -->
+ <Widget>
<Name>menuClearSelection</Name>
<Type>ClearSelection</Type>
<StatusText>Clears the current selection.</StatusText>
@@ -647,7 +656,7 @@
<!-- CONTEXT MENU SELECT RADIUS -->
+ <Widget>
<Name>menuSelectRadius</Name>
<Type>SelectRadius</Type>
<StatusText>Click and drag to select all features inside a circle.</StatusText>
@@ -660,7 +669,7 @@
<!-- CONTEXT MENU SELECT POLYGON -->
+ <Widget>
<Name>menuSelectPolygon</Name>
<Type>SelectPolygon</Type>
<StatusText>Create a polygon and select all features that fall within.</StatusText>
@@ -673,7 +682,7 @@
<!-- CONTEXT MENU SELECT WITHIN -->
+ <Widget>
<Name>menuSelectWithin</Name>
<Type>SelectWithin</Type>
<StatusText>Select all features that fall within the currently selected area.</StatusText>
@@ -686,7 +695,7 @@
<!-- CONTEXT MENU BUFFER -->
+ <Widget>
<Name>menuBuffer</Name>
<Type>BufferPanel</Type>
<StatusText>Create buffers around the selected features</StatusText>
@@ -699,11 +708,11 @@
<!-- CONTEXT MENU VIEW OPTIONS -->
+ <Widget>
<Name>menuViewOptions</Name>
<Type>ViewOptions</Type>
<StatusText>Switch between Imperial and Metric units</StatusText>
+ <Extension>
<DisplayUnits>degrees</DisplayUnits>
</Extension>
@@ -715,7 +724,7 @@
<!-- CONTEXT MENU HELP -->
+ <Widget>
<Name>menuHelp</Name>
<Type>Help</Type>
<StatusText/>
@@ -728,7 +737,7 @@
<!-- CONTEXT MENU ABOUT -->
+ <Widget>
<Name>menuAbout</Name>
<Type>About</Type>
<StatusText/>
@@ -741,11 +750,11 @@
<!-- CONTEXT MENU MEASURE -->
+ <Widget>
<Name>menuMeasure</Name>
<Type>Measure</Type>
<StatusText>Measure distances and areas on the map.</StatusText>
+ <Extension>
<Type>both</Type>
<MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
<MeasureTooltipType>dynamic</MeasureTooltipType>
@@ -769,7 +778,7 @@
<!-- TOOLBAR BUFFER -->
+ <Widget>
<Name>toolbarBuffer</Name>
@@ -785,7 +794,7 @@
<!-- TOOLBAR REFRESH MAP -->
+ <Widget>
<Name>toolbarRefreshMap</Name>
@@ -798,11 +807,11 @@
<!-- TOOLBAR MEASURE -->
+ <Widget>
<Name>toolbarMeasure</Name>
+ <Extension>
<Type>both</Type>
@@ -818,11 +827,11 @@
<Disabled/>
</Widget>
+ <Widget>
<Name>toolbarSaveMap</Name>
<Type>SaveMap</Type>
<StatusText></StatusText>
+ <Extension>
</Extension>
<Tooltip>SaveMap</Tooltip>
<Label>Save Map</Label>
@@ -831,11 +840,11 @@
<!-- TOOLBAR VIEW OPTIONS -->
+ <Widget>
<Name>toolbarViewOptions</Name>
+ <Extension>
<DisplayUnits>meters</DisplayUnits>
</Extension>
@@ -847,7 +856,7 @@
<!-- TOOLBAR HELP -->
+ <Widget>
<Name>toolbarHelp</Name>
<Type>Help</Type>
<StatusText/>
@@ -860,7 +869,7 @@
<!-- TOOLBAR ABOUT -->
+ <Widget>
<Name>toolbarAbout</Name>
<Type>About</Type>
<StatusText/>
@@ -873,7 +882,7 @@
<!-- TOOLBAR CLEAR SELECTION -->
+ <Widget>
<Name>toolbarClearSelection</Name>
@@ -886,7 +895,7 @@
<!-- TOOLBAR SELECT RADIUS -->
+ <Widget>
<Name>toolbarSelectRadius</Name>
@@ -902,7 +911,7 @@
<!-- TOOLBAR SELECT POLYGON -->
+ <Widget>
<Name>toolbarSelectPolygon</Name>
@@ -923,11 +932,11 @@
<!-- SECONDARY TOOLBAR INITIAL MAP VIEW -->
+ <Widget>
<Name>toolbarSecondaryInitialMapView</Name>
+ <Extension>
</Extension>
@@ -939,11 +948,11 @@
<!-- SECONDARY TOOLBAR PREVIOUS VIEW-->
+ <Widget>
<Name>toolbarSecondaryPreviousView</Name>
+ <Extension>
</Extension>
@@ -955,11 +964,11 @@
<!-- SECONDARY TOOLBAR NEXT VIEW -->
+ <Widget>
<Name>toolbarSecondaryNextView</Name>
+ <Extension>
</Extension>
@@ -971,7 +980,7 @@
<!-- SECONDARY TOOLBAR ZOOM SELECTION -->
+ <Widget>
<Name>toolbarSecondaryZoomSelection</Name>
@@ -984,7 +993,7 @@
<!-- SECONDARY TOOLBAR SELECT WITHIN -->
+ <Widget>
<Name>toolbarSelectWithin</Name>
@@ -1008,11 +1017,11 @@
<!-- STATUS POSITION -->
- <Widget xsi:type="WidgetType">
+ <Widget>
<Name>StatusCoords</Name>
<Type>CursorPosition</Type>
<StatusText/>
+ <Extension>
<Template>X: {x} {units}, Y: {y} {units}</Template>
<Precision>4</Precision>
<EmptyText>&nbsp;</EmptyText>
@@ -1021,7 +1030,7 @@
<!-- STATUS SELECTION INFO -->
+ <Widget>
<Name>StatusSelection</Name>
<Type>SelectionInfo</Type>
<StatusText/>
@@ -1032,7 +1041,7 @@
<!-- STATUS SCALE -->
+ <Widget>
<Name>StatusScale</Name>
<Type>EditableScale</Type>
<StatusText/>
@@ -1040,11 +1049,11 @@
<!-- STATUS VIEWSIZE -->
+ <Widget>
<Name>StatusViewSize</Name>
<Type>ViewSize</Type>
<StatusText/>
+ <Extension>
<Template>{w} x {h} ({units})</Template>
<Precision>2</Precision>
</Extension>
@@ -1059,7 +1068,7 @@
<!-- LEGEND
+ <Widget>
<Name>Legend</Name>
<Type>Legend</Type>
<Extension>
@@ -1069,7 +1078,7 @@
</Widget>
<!-- SELECTION -->
+ <Widget>
<Name>SelectionPanel</Name>
<Type>SelectionPanel</Type>
<StatusText/>
@@ -1077,7 +1086,7 @@
<!-- TASKS -->
+ <Widget>
<Name>TaskPane</Name>
<Type>TaskPane</Type>
<StatusText/>
@@ -1094,20 +1103,20 @@
<!-- INMAP NAVIGATOR -->
+ <Widget>
<Name>Navigator</Name>
<Type>Navigator</Type>
+ <Extension>
</Extension>
</Widget>
<!-- ZOOM IN RECTANGLE -->
+ <Widget>
<Name>ZoomInRectangle</Name>
<Type>Zoom</Type>
+ <Extension>
<Factor>2</Factor>
</Extension>
@@ -1120,11 +1129,11 @@
<!-- ZOOM ON CLICK (IN) -->
+ <Widget>
<Name>ZoomInFixed</Name>
+ <Extension>
<Factor>4</Factor>
</Extension>
@@ -1136,11 +1145,11 @@
<!-- ZOOM ON CLICK (OUT) -->
+ <Widget>
<Name>ZoomOutFixed</Name>
+ <Extension>
</Extension>
@@ -1152,7 +1161,7 @@
<!-- SELECT -->
+ <Widget>
<Name>Select</Name>
<Type>Select</Type>
@@ -1182,22 +1191,22 @@
<!-- OVERVIEW MAP -->
+ <Widget>
<Name>OverviewMap</Name>
<Type>OverviewMap</Type>
<Description/>
+ <Extension>
<MapId>sheboygan</MapId>
</Extension>
</Widget>
<!-- PRINT -->
+ <Widget>
<Name>GetPrintablePage</Name>
<Type>Print</Type>
<StatusText>Get printer-friendly page.</StatusText>
+ <Extension>
<ShowPrintUI>true</ShowPrintUI>
<ShowTitle>true</ShowTitle>
<PageTitle>Some Title</PageTitle>
@@ -1213,7 +1222,7 @@
</Widget>
<!-- PAN -->
+ <Widget>
<Name>Pan</Name>
<Type>Pan</Type>
@@ -1225,12 +1234,12 @@
<Disabled/>
</Widget>
+ <Widget>
<Name>Scalebar</Name>
<Type>ScalebarDual</Type>
</Widget>
+ <Widget>
<Name>MapTip</Name>
<Type>Maptip</Type>
<Extension>
More information about the fusion-commits
