[fusion-commits] r2274 - in trunk/layers: . MapServer/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 11 10:41:30 EST 2010
Author: pagameba
Date: 2010-11-11 07:41:30 -0800 (Thu, 11 Nov 2010)
New Revision: 2274
   trunk/layers/Layers.js
   trunk/layers/MapServer/php/LoadMap.php
make the metadata related to editing more fine-grained so that we can differentiate between attribute and feature editing and between create/update/delete operations on the two.
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2010-11-05 18:30:23 UTC (rev 2273)
+++ trunk/layers/Layers.js	2010-11-11 15:41:30 UTC (rev 2274)
@@ -484,7 +484,14 @@
         this.expandInLegend = o.expandInLegend;
         this.actuallyVisible = o.actuallyVisible;
         this.statusDefault = o.statusdefault;
-        this.editable = o.editable;
+        this.feature = OpenLayers.Util.extend({},o.feature);
+        this.attribute = OpenLayers.Util.extend({},o.attribute);
+        this.editable = this.feature.create ||
+                        this.feature.update ||
+                        this.feature.del ||
+                        this.attribute.create ||
+                        this.attribute.update ||
+                        this.attribute.del;
         this.isEditing = false;
         this.visible = o.visible;
         this.initiallyVisible = o.visible;
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php	2010-11-05 18:30:23 UTC (rev 2273)
+++ trunk/layers/MapServer/php/LoadMap.php	2010-11-11 15:41:30 UTC (rev 2274)
@@ -294,9 +294,34 @@
          $layerObj->visible = ($layer->status == MS_ON || $layer->status == MS_DEFAULT);
          $layerObj->actuallyVisible = true;
-         $editable = strtolower($layer->getMetaData('editable'));
-         $layerObj->editable = $editable == 'true' ? true : false;
+         $layerObj->feature = null;
+         $create = strtolower($layer->getMetaData('feature_create'));
+         $layerObj->feature->create = $create == 'true' ? true : false;
+         $read = strtolower($layer->getMetaData('feature_read'));
+         $layerObj->feature->read = $read == 'true' ? true : false;
+         $update = strtolower($layer->getMetaData('feature_update'));
+         $layerObj->feature->update = $update == 'true' ? true : false;
+         $del = strtolower($layer->getMetaData('feature_delete'));
+         $layerObj->feature->del = $del == 'true' ? true : false;
+         $layerObj->attribute = null;
+         $create = strtolower($layer->getMetaData('attribute_create'));
+         $layerObj->attribute->create = $create == 'true' ? true : false;
+         $read = strtolower($layer->getMetaData('attribute_read'));
+         $layerObj->attribute->read = $read == 'true' ? true : false;
+         $update = strtolower($layer->getMetaData('attribute_update'));
+         $layerObj->attribute->update = $update == 'true' ? true : false;
+         $del = strtolower($layer->getMetaData('attribute_delete'));
+         $layerObj->attribute->del = $del == 'true' ? true : false;
          /* process the classes.  The legend expects things
           * organized by scale range so we have to first
           * find all the scale breaks, then create ranges
@@ -382,11 +407,13 @@
     $mapObj->groups = array();
     $aGroups = $oMap->getAllGroupNames();
-    foreach($aGroups as $groupName) {
-        $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
-        if (count($aLayerIndexes) > 0) {
-            array_push($mapObj->groups, getGroupObject($oMap->getLayer($aLayerIndexes[0])));
+    if (is_array($aGroups)) {
+      foreach($aGroups as $groupName) {
+          $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
+          if (count($aLayerIndexes) > 0) {
+              array_push($mapObj->groups, getGroupObject($oMap->getLayer($aLayerIndexes[0])));
     echo var2json($mapObj);
More information about the fusion-commits mailing list
