[fusion-commits] r2214 - in sandbox/jxlib-3.0: common/php
layers/MapServer/php
svn_fusion at osgeo.org
Thu Sep 2 10:21:53 EDT 2010
Author: pagameba
Date: 2010-09-02 14:21:53 +0000 (Thu, 02 Sep 2010)
New Revision: 2214
sandbox/jxlib-3.0/common/php/Utilities.php
sandbox/jxlib-3.0/layers/MapServer/php/Common.php
sandbox/jxlib-3.0/layers/MapServer/php/CreateSession.php
sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php
sandbox/jxlib-3.0/layers/MapServer/php/Session.php
updating sandbox with code to make fusion work with platform sessions and to load resources directly from the platform.
Modified: sandbox/jxlib-3.0/common/php/Utilities.php
--- sandbox/jxlib-3.0/common/php/Utilities.php 2010-09-02 02:52:59 UTC (rev 2213)
+++ sandbox/jxlib-3.0/common/php/Utilities.php 2010-09-02 14:21:53 UTC (rev 2214)
@@ -25,7 +25,8 @@
/* recursively convert a variable to its json representation */
-function var2json($var) {
+if (!function_exists('var2json')) {
+ function var2json($var) {
if (function_exists('json_encode')) {
$result = json_encode($var);
} else {
@@ -61,8 +62,10 @@
return utf8_encode($result);
-function xml2json($domElement) {
+if (!function_exists('xml2json')) {
+ function xml2json($domElement) {
$result = '';
if ($domElement->nodeType == XML_COMMENT_NODE) {
return '';
@@ -166,6 +169,7 @@
return $result;
* this function determines if a path represents an absolute path and returns
@@ -173,7 +177,8 @@
* @param szPath string the path to test
* @result boolean true if the path is absolute, false otherwise
-function isAbsolutePath( $szPath ) {
+if (!function_exists('isAbsolutePath')) {
+ function isAbsolutePath( $szPath ) {
if ($szPath == "") { return false; }
if ($szPath[0] == "/" || preg_match('/^(\w:)/', $szPath)) {
return true;
@@ -181,8 +186,8 @@
return false;
* This function translate $szDestPath (relative or absolute)
* to a absolute path based on $szOrigPath.
@@ -190,7 +195,8 @@
* @param $szDestPath string Destination path to translate
* @param $szOrigPath string Reference path
-function resolvePath2 ($szDestPath, $szOrigPath) {
+if (!function_exists('resolvePath2')) {
+ function resolvePath2 ($szDestPath, $szOrigPath) {
// If one or other path is missing or absolute, return it.
if ($szDestPath == "") { return $szOrigPath; }
if ($szOrigPath == "") { return $szDestPath; }
@@ -229,6 +235,7 @@
//Rest of the function
return $szPrefix.$szPath;
* Recursive ereg_replace
@@ -239,7 +246,8 @@
* @return string szString with the matching result replaced.
-function iterate_ereg_replace ( $szPattern, $szReplacement, $szString) {
+if (!function_exists('iterate_ereg_replace')) {
+ function iterate_ereg_replace ( $szPattern, $szReplacement, $szString) {
$szResult = $szString;
do {
$szString = $szResult;
@@ -248,8 +256,11 @@
return $szResult;
-function arguments($argv) {
+if (!function_exists('arguments')) {
+ function arguments($argv) {
$_ARG = array();
foreach ($argv as $arg) {
if (ereg('--[a-zA-Z0-9]*=.*',$arg)) {
@@ -266,8 +277,10 @@
return $_ARG;
-function loadFusionConfig() {
+if (!function_exists('loadFusionConfig')) {
+ function loadFusionConfig() {
/* json decode only in PHP 5.2 and later */
if (function_exists('json_decode')) {
$configFile = realpath(dirname(__FILE__)."/../../config.json");
@@ -291,5 +304,6 @@
Modified: sandbox/jxlib-3.0/layers/MapServer/php/Common.php
--- sandbox/jxlib-3.0/layers/MapServer/php/Common.php 2010-09-02 02:52:59 UTC (rev 2213)
+++ sandbox/jxlib-3.0/layers/MapServer/php/Common.php 2010-09-02 14:21:53 UTC (rev 2214)
@@ -64,7 +64,7 @@
/* handle restoring a session */
if (isset($REQUEST_VARS['session'])) {
$sessionID = $REQUEST_VARS['session'];
- initializeSession( "sid", "", $sessionID );
+ initializeSession( "session", "", $sessionID );
if (isset($_REQUEST['mapname'])) {
Modified: sandbox/jxlib-3.0/layers/MapServer/php/CreateSession.php
--- sandbox/jxlib-3.0/layers/MapServer/php/CreateSession.php 2010-09-02 02:52:59 UTC (rev 2213)
+++ sandbox/jxlib-3.0/layers/MapServer/php/CreateSession.php 2010-09-02 14:21:53 UTC (rev 2214)
@@ -32,7 +32,8 @@
include(dirname(__FILE__).'/Common.php');
include('../../../common/php/Utilities.php');
-initializeSession( "sid", "", "" );
+$cookie = isset($_COOKIE['session'])?$_COOKIE['session']:"";
+initializeSession( "session", "", $cookie);
$sessionId = session_id();
loadFusionConfig();
Modified: sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php
--- sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php 2010-09-02 02:52:59 UTC (rev 2213)
+++ sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php 2010-09-02 14:21:53 UTC (rev 2214)
@@ -1,420 +1,439 @@
-<?php
- * LoadMap
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Purpose: Load a mapfile into the session and return information about the
- * map to the client
-/* Common starts the session */
-include(dirname(__FILE__).'/../../../common/php/Utilities.php');
-include(dirname(__FILE__).'/Common.php');
-include(dirname(__FILE__).'/Utilities.php');
-/* if scales are not set, these become the default values */
-define('MIN_SCALE', 1);
-define('MAX_SCALE', 1000000000);
-/* could potentially make this optional */
-$moveToSession = true;
- TODO make it possible to specify only a relative path
- in the WebLayout and have this code know where to
- look for it on the server somehow
-/* only do something if a mapfile was requested */
-if (isset($_REQUEST['mapfile'])) {
- /* look for mapFileRoot specified in config.json and test to see if the map path in appdef is realitive to it.*/
- $configObj = $_SESSION['fusionConfig'];
- $szFusionRoot = dirname(__FILE__).'/../../../'; // TODO : not a very elegant way of doing this
- $szDblSeparator = DIRECTORY_SEPARATOR.DIRECTORY_SEPARATOR;
- $szMapFromFusionRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$szFusionRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
- $szMapFileRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$configObj->mapserver->mapFileRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
- if( file_exists($szMapFileRoot) ) {
- /* use the realitive path specified in config.json */
- $szMapFile = $szMapFileRoot;
- else
- if( file_exists($szMapFromFusionRoot) ) {
- /* use the realitive path from fusion install root */
- $szMapFile = $szMapFromFusionRoot;
- else
- /* use absolute path from appdef */
- $szMapFile = $_REQUEST['mapfile'];
- $oMap = ms_newMapObj($szMapFile);
- /* optionally move the mapfile to the session */
- if ($moveToSession) {
- //path to map file in the session is used by the client
- $mapId = getSessionSavePath().($oMap->name).".map";
- //modify various paths if necessary
- $pathToMap = dirname($szMapFile);
- $cwd = getcwd();
- chdir($pathToMap);
- $shapePath = $oMap->shapepath;
- $oMap->set('shapepath', realpath($shapePath));
- $symbolSet = $oMap->symbolsetfilename;
- if ($symbolSet != '') {
- $oMap->setSymbolSet(realpath($symbolSet));
- $fontSet = $oMap->fontsetfilename;
- if ($fontSet != '') {
- $oMap->setFontSet(realpath($fontSet));
- /* need to modify all image symbols reference in the map file
- eg STYLE
- SYMBOL "../etc/markers/target-7.gif" : this is relative to the map file
- for ($i=0; $i<$oMap->numlayers; $i++)
- $oLayer = &$oMap->GetLayer($i);
- /* check layername for invalid URI characters and replace */
- $oLayer->set("name",replaceInvalidLayerName($oLayer->name));
- for ($j=0; $j<$oLayer->numclasses; $j++)
- $oClass = $oLayer->GetClass($j);
- /* if keyimage is defined, change the path*/
- if ($oClass->keyimage && strlen($oClass->keyimage) > 0)
- $oClass->set("keyimage", realpath($oClass->keyimage));
- for ($k=0; $k<$oClass->numstyles; $k++)
- $oStyle = $oClass->getStyle($k);
- if ($oStyle->symbolname != "")
- if (file_exists(realpath($oStyle->symbolname)))
- $oStyle->set("symbolname", realpath($oStyle->symbolname));
- $oMap->save($mapId);
- chdir($cwd);
- } else {
- $mapId = $_REQUEST['mapfile'];
-} elseif (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
- $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
-$mapObj = NULL;
-if ($oMap) {
- header('Content-type: application/json');
- header('X-JSON: true');
- $mapObj->sessionId = $sessionID;
- $mapObj->mapId = $mapId;
- $mapObj->metadata = NULL;
- if (isset($_REQUEST['map_metadata'])) {
- $mapMetadataKeys = explode(',',$_REQUEST['map_metadata']);
- foreach($mapMetadataKeys as $key) {
- $mapObj->metadata->$key = $oMap->getMetadata($key);
- $mapObj->projString = $oMap->getProjection();
- $mapObj->metersPerUnit = GetMetersPerUnit($oMap->units);
- $mapObj->dpi = $oMap->resolution;
- $mapObj->imagetype = $oMap->imagetype;
- $mapObj->mapName = $oMap->name;
- if (!isset($_SESSION['maps'])) {
- $_SESSION['maps'] = array();
- if (!isset($_SESSION['maps'][$mapObj->mapName])) {
- $_SESSION['maps'][$mapObj->mapName] = $mapId;
- $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
- $oMap->extent->maxx, $oMap->extent->maxy );
- $minScale = $oMap->web->minscale == -1 ? MIN_SCALE : $oMap->web->minscale;
- $maxScale = $oMap->web->maxscale == -1 ? MAX_SCALE : $oMap->web->maxscale;
- $title = $oMap->getmetadata('legend_title');
- $mapObj->mapTitle = $title == "" ? $mapObj->mapName : $title;
- //layers
- $mapObj->layers = array();
- for ($i=0;$i<$oMap->numlayers;$i++)
- $layer=$oMap->getLayer($i);
- $layerObj = NULL;
- /* Status Default - If a layer is status Default trac it in layerObj */
- if($layer->status == MS_DEFAULT)
- $layerObj->statusdefault = true;
- else
- $layerObj->statusdefault = false;
- /* rename layes names with invalid characters */
- $layer->set("name",replaceInvalidLayerName($layer->name));
- $layerObj->metadata = NULL;
- if (isset($_REQUEST['layer_metadata'])) {
- $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
- foreach($layerMetadataKeys as $key) {
- $layerObj->metadata->$key = $layer->getMetadata($key);
- //$extent = $layer->getExtent();
- $layerObj->extent = NULL;
- $layerObj->extent->minx = NULL;
- $layerObj->extent->maxx = NULL;
- $layerObj->extent->miny = NULL;
- $layerObj->extent->maxy = NULL;
- // only proceed if extent is valid
- if( isset($GLOBALS["extent"]) )
- $layerObj->extent->minx = $extent->minx;
- $layerObj->extent->maxx = $extent->maxx;
- $layerObj->extent->miny = $extent->miny;
- $layerObj->extent->maxy = $extent->maxy;
- $layerObj->propertyMappings = '';
- $layerObj->uniqueId = $i;
- $layerObj->layerName = $layer->name;
- switch($layer->type) {
- case MS_LAYER_POINT:
- $type = 0;
- break;
- case MS_LAYER_LINE:
- $type = 1;
- break;
- case MS_LAYER_POLYGON:
- $type = 2;
- break;
- case MS_LAYER_RASTER:
- $type = 4;
- break;
- case MS_LAYER_ANNOTATION:
- $type = 8;
- break;
- default:
- $type = 0;
- $layerObj->layerTypes = array($type);
- $displayInLegend = strtolower($layer->getMetaData('displayInLegend'));
- $layerObj->displayInLegend = $displayInLegend == 'false' ? false : true;
- $expandInLegend = strtolower($layer->getMetaData('expandInLegend'));
- $layerObj->expandInLegend = $expandInLegend == 'false' ? false : true;
- $layerObj->resourceId = $layer->name;
- $layerObj->parentGroup = $layer->group;
- $legendLabel = $layer->getMetaData('legendLabel');
- if ($legendLabel == '') {
- $legendLabel = $layer->name;
- $layerObj->legendLabel = $legendLabel;
- $selectable = strtolower($layer->getMetaData('selectable'));
- $layerObj->selectable = $selectable == 'true' ? true : false;
- $layerObj->visible = ($layer->status == MS_ON || $layer->status == MS_DEFAULT);
- $layerObj->actuallyVisible = true;
- $editable = strtolower($layer->getMetaData('editable'));
- $layerObj->editable = $editable == 'true' ? true : false;
- /* process the classes. The legend expects things
- * organized by scale range so we have to first
- * find all the scale breaks, then create ranges
- * for each scale break pair, then slot the classes
- * into the scale ranges that they apply to.
- $aScaleRanges = array();
- //create a default scale range for the layer as a whole
- $layerMin = $layer->minscale == -1 ? $minScale : $layer->minscale;
- $layerMax = $layer->maxscale == -1 ? $maxScale : $layer->maxscale;
- /* check to see that the layer has a vaild scale range
- * inside the defined map's main min max scale ranges
- * set them to the maps scale ranges if they exceede
- if($layer->minscale != -1 && $layerMin < $minScale)
- $layerMin = $minScale;
- if($layer->maxscale != -1 && $layerMax > $maxScale)
- $layerMax = $maxScale;
- //find all the unique scale breaks in this layer
- $aScaleBreaks = array($layerMin, $layerMax);
- for ($j=0; $j<$layer->numclasses; $j++) {
- $oClass = $layer->getClass($j);
- $classMin = $oClass->minscale == -1 ? $layerMin : max($oClass->minscale, $layerMin);
- $classMax = $oClass->maxscale == -1 ? $layerMax : min($oClass->maxscale, $layerMax);
- if (!in_array($classMin, $aScaleBreaks)) {
- array_push($aScaleBreaks, $classMin);
- if (!in_array($classMax, $aScaleBreaks)) {
- array_push($aScaleBreaks, $classMax);
- //sort them
- sort($aScaleBreaks);
- //create scale ranges for each pair of breaks
- for ($j=0; $j<count($aScaleBreaks)-1; $j++) {
- $scaleRange = NULL;
- $scaleRange->minScale = $aScaleBreaks[$j];
- $scaleRange->maxScale = $aScaleBreaks[$j+1];
- $scaleRange->styles = array();
- array_push($aScaleRanges, $scaleRange);
- //create classes and slot them into the scale breaks
- $classObj = NULL;
- // Use formatted legend label as defined by CLASS->TITLE
- $classObj->legendLabel = $oClass->title != '' ? $oClass->title : $oClass->name;
- $classObj->filter = $oClass->getExpression();
- $classObj->minScale = $classMin;
- $classObj->maxScale = $classMax;
- $classObj->index = $j;
- for ($k=0; $k<count($aScaleRanges); $k++) {
- if ($classMin < $aScaleRanges[$k]->maxScale &&
- $classMax > $aScaleRanges[$k]->minScale) {
- array_push($aScaleRanges[$k]->styles, $classObj);
- //$layerObj->scaleRanges = $aScaleRanges;
- $_SESSION['scale_ranges'][$mapName][$layer->name] = $aScaleRanges;
- /*get the min/max scale for the layer*/
- $nCount = count($aScaleRanges);
- $layerObj->minScale = $aScaleRanges[0]->minScale;
- $layerObj->maxScale = $aScaleRanges[0]->maxScale;
- for ($j=1; $j<$nCount; $j++)
- $layerObj->minScale = min($layerObj->minScale, $aScaleRanges[$j]->minScale);
- $layerObj->maxScale = max($layerObj->maxScale, $aScaleRanges[$j]->maxScale);
- array_push($mapObj->layers, $layerObj);
- $mapObj->groups = array();
- $aGroups = $oMap->getAllGroupNames();
- foreach($aGroups as $groupName) {
- $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
- if (count($aLayerIndexes) > 0) {
- array_push($mapObj->groups, getGroupObject($oMap->getLayer($aLayerIndexes[0])));
- echo var2json($mapObj);
-function getGroupObject($layer) {
- $group = NULL;
- $group->groupName = $layer->group;
- $ll = $layer->getMetaData('groupLegendLabel');
- $group->legendLabel = $ll != '' ? $ll : $group->groupName;
- $group->uniqueId = $group->groupName;
- $b = $layer->getMetaData('groupDisplayInLegend');
- $group->displayInLegend = ($b == 'false') ? false : true;
- $b = $layer->getMetaData('groupExpandInLegend');
- $group->expandInLegend = ($b == 'false') ? false : true;
- $group->layerGroupType = '';
- /* parent is always not set for mapserver since we can't have nested groups */
- $group->parentUniqueId = '';
- $group->parent = '';
- $b = $layer->getMetaData('groupVisible');
- $group->visible = ($b == 'false') ? false : true;
- $group->actuallyVisible = $layer->isVisible();
- $group->groupParent = $layer->getMetaData('groupParent');
- return $group;
-function GetMetersPerUnit($unit)
- if ($unit == MS_INCHES)
- return 0.0254;
- else if ($unit == MS_FEET)
- return 0.3048;
- else if ($unit == MS_MILES)
- return 1609.344;
- else if ($unit == MS_METERS)
- return 1;
- else if ($unit == MS_KILOMETERS)
- return 1000;
- else if ($unit == MS_DD)
- return 111118.7516;
- else if ($unit == MS_PIXELS)
- return 1;
-function replaceInvalidLayerName($szLayerName){
- bug http://trac.osgeo.org/fusion/ticket/96 - Invalid characters in layer name (pdeschamps)
- Fusion requests the map imavge via the Mapserver CGI to toggle the layer visibility.
- The layer paramerter for the cgi uses spaces as a delimiter for the layer names this creates
- an issue for the mapserver binary to toggle layers that have these reserved URI characters.
- also removing characters that could pose potential issues with json.
- $aInvalidLayerNameCharacters = array();
- $aInvalidLayerNameCharacters[0] ="&";
- $aInvalidLayerNameCharacters[1] =" ";
- $aInvalidLayerNameCharacters[2] ="#";
- $aInvalidLayerNameCharacters[3] ="\\";
- $aInvalidLayerNameCharacters[4] ="=";
- $aInvalidLayerNameCharacters[5] ="/";
- $aInvalidLayerNameCharacters[6] ="'";
- $aReplace[0] = "_";
- $aReplace[1] = "_";
- $aReplace[2] = "_";
- $aReplace[3] = "_";
- $aReplace[4] = "_";
- $aReplace[5] = "_";
- $aReplace[6] = "_";
- return str_replace($aInvalidLayerNameCharacters,$aReplace,$szLayerName);
+<?php
+ * LoadMap
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Purpose: Load a mapfile into the session and return information about the
+ * map to the client
+/* Common starts the session */
+include(dirname(__FILE__).'/../../../common/php/Utilities.php');
+include(dirname(__FILE__).'/Common.php');
+include(dirname(__FILE__).'/Utilities.php');
+/* if scales are not set, these become the default values */
+define('MIN_SCALE', 1);
+define('MAX_SCALE', 1000000000);
+/* could potentially make this optional */
+$moveToSession = true;
+$modifyPaths = false;
+ TODO make it possible to specify only a relative path
+ in the WebLayout and have this code know where to
+ look for it on the server somehow
+/* only do something if a mapfile was requested */
+if (isset($_REQUEST['mapfile'])) {
+ /* look for mapFileRoot specified in config.json and test to see if the map path in appdef is realitive to it.*/
+ $configObj = $_SESSION['fusionConfig'];
+ $szFusionRoot = dirname(__FILE__).'/../../../'; // TODO : not a very elegant way of doing this
+ $szDblSeparator = DIRECTORY_SEPARATOR.DIRECTORY_SEPARATOR;
+ $szMapFromFusionRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$szFusionRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
+ $szMapFileRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$configObj->mapserver->mapFileRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
+ if( file_exists($szMapFileRoot) ) {
+ /* use the realitive path specified in config.json */
+ $szMapFile = $szMapFileRoot;
+ else
+ if( file_exists($szMapFromFusionRoot) ) {
+ /* use the realitive path from fusion install root */
+ $szMapFile = $szMapFromFusionRoot;
+ else
+ /* use absolute path from appdef */
+ $szMapFile = $_REQUEST['mapfile'];
+ $sMapFileContents = '';
+ if (strpos($szMapFile, 'platform://') === 0) {
+ include_once($configObj->mapserver->platformPath . "/include/Common.php");
+ global $platformDefaultConfig;
+ $platformContext = new PlatformContext($platformDefaultConfig);
+ $platformContext->RestoreSession(session_id());
+ $mapGen = new Map($platformContext, substr($szMapFile, 10));
+ if ($mapGen->Exists()) {
+ $result = $mapGen->Save();
+ if ($result->IsOk()) {
+ $sMapFileContents = $result->Get('MAPDATA');
+ } else {
+ $sMapFileContents = file_get_contents($szMapFile);
+ $oMap = ms_newMapObjFromString($sMapFileContents);
+ /* optionally move the mapfile to the session */
+ if ($moveToSession) {
+ //path to map file in the session is used by the client
+ $mapId = getSessionSavePath().($oMap->name).".map";
+ //modify various paths if necessary
+ if ($modifyPaths) {
+ $pathToMap = dirname($szMapFile);
+ $cwd = getcwd();
+ chdir($pathToMap);
+ $shapePath = $oMap->shapepath;
+ $oMap->set('shapepath', realpath($shapePath));
+ $symbolSet = $oMap->symbolsetfilename;
+ if ($symbolSet != '') {
+ $oMap->setSymbolSet(realpath($symbolSet));
+ $fontSet = $oMap->fontsetfilename;
+ if ($fontSet != '') {
+ $oMap->setFontSet(realpath($fontSet));
+ /* need to modify all image symbols reference in the map file
+ eg STYLE
+ SYMBOL "../etc/markers/target-7.gif" : this is relative to the map file
+ for ($i=0; $i<$oMap->numlayers; $i++)
+ $oLayer = &$oMap->GetLayer($i);
+ /* check layername for invalid URI characters and replace */
+ $oLayer->set("name",replaceInvalidLayerName($oLayer->name));
+ for ($j=0; $j<$oLayer->numclasses; $j++)
+ $oClass = $oLayer->GetClass($j);
+ /* if keyimage is defined, change the path*/
+ if ($oClass->keyimage && strlen($oClass->keyimage) > 0)
+ $oClass->set("keyimage", realpath($oClass->keyimage));
+ for ($k=0; $k<$oClass->numstyles; $k++)
+ $oStyle = $oClass->getStyle($k);
+ if ($oStyle->symbolname != "")
+ if (file_exists(realpath($oStyle->symbolname)))
+ $oStyle->set("symbolname", realpath($oStyle->symbolname));
+ chdir($cwd);
+ $oMap->save($mapId);
+ } else {
+ $mapId = $_REQUEST['mapfile'];
+} elseif (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+ $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+$mapObj = NULL;
+if ($oMap) {
+ header('Content-type: application/json');
+ header('X-JSON: true');
+ $mapObj->sessionId = $sessionID;
+ $mapObj->mapId = $mapId;
+ $mapObj->metadata = NULL;
+ if (isset($_REQUEST['map_metadata'])) {
+ $mapMetadataKeys = explode(',',$_REQUEST['map_metadata']);
+ foreach($mapMetadataKeys as $key) {
+ $mapObj->metadata->$key = $oMap->getMetadata($key);
+ $mapObj->projString = $oMap->getProjection();
+ $mapObj->metersPerUnit = GetMetersPerUnit($oMap->units);
+ $mapObj->dpi = $oMap->resolution;
+ $mapObj->imagetype = $oMap->imagetype;
+ $mapObj->mapName = $oMap->name;
+ if (!isset($_SESSION['maps'])) {
+ $_SESSION['maps'] = array();
+ if (!isset($_SESSION['maps'][$mapObj->mapName])) {
+ $_SESSION['maps'][$mapObj->mapName] = $mapId;
+ $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
+ $oMap->extent->maxx, $oMap->extent->maxy );
+ $minScale = $oMap->web->minscale == -1 ? MIN_SCALE : $oMap->web->minscale;
+ $maxScale = $oMap->web->maxscale == -1 ? MAX_SCALE : $oMap->web->maxscale;
+ $title = $oMap->getmetadata('legend_title');
+ $mapObj->mapTitle = $title == "" ? $mapObj->mapName : $title;
+ //layers
+ $mapObj->layers = array();
+ for ($i=0;$i<$oMap->numlayers;$i++)
+ $layer=$oMap->getLayer($i);
+ $layerObj = NULL;
+ /* Status Default - If a layer is status Default trac it in layerObj */
+ if($layer->status == MS_DEFAULT)
+ $layerObj->statusdefault = true;
+ else
+ $layerObj->statusdefault = false;
+ /* rename layes names with invalid characters */
+ $layer->set("name",replaceInvalidLayerName($layer->name));
+ $layerObj->metadata = NULL;
+ if (isset($_REQUEST['layer_metadata'])) {
+ $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
+ foreach($layerMetadataKeys as $key) {
+ $layerObj->metadata->$key = $layer->getMetadata($key);
+ //$extent = $layer->getExtent();
+ $layerObj->extent = NULL;
+ $layerObj->extent->minx = NULL;
+ $layerObj->extent->maxx = NULL;
+ $layerObj->extent->miny = NULL;
+ $layerObj->extent->maxy = NULL;
+ // only proceed if extent is valid
+ if( isset($GLOBALS["extent"]) )
+ $layerObj->extent->minx = $extent->minx;
+ $layerObj->extent->maxx = $extent->maxx;
+ $layerObj->extent->miny = $extent->miny;
+ $layerObj->extent->maxy = $extent->maxy;
+ $layerObj->propertyMappings = '';
+ $layerObj->uniqueId = $i;
+ $layerObj->layerName = $layer->name;
+ switch($layer->type) {
+ case MS_LAYER_POINT:
+ $type = 0;
+ break;
+ case MS_LAYER_LINE:
+ $type = 1;
+ break;
+ case MS_LAYER_POLYGON:
+ $type = 2;
+ break;
+ case MS_LAYER_RASTER:
+ $type = 4;
+ break;
+ case MS_LAYER_ANNOTATION:
+ $type = 8;
+ break;
+ default:
+ $type = 0;
+ $layerObj->layerTypes = array($type);
+ $displayInLegend = strtolower($layer->getMetaData('displayInLegend'));
+ $layerObj->displayInLegend = $displayInLegend == 'false' ? false : true;
+ $expandInLegend = strtolower($layer->getMetaData('expandInLegend'));
+ $layerObj->expandInLegend = $expandInLegend == 'false' ? false : true;
+ $layerObj->resourceId = $layer->name;
+ $layerObj->parentGroup = $layer->group;
+ $legendLabel = $layer->getMetaData('legendLabel');
+ if ($legendLabel == '') {
+ $legendLabel = $layer->name;
+ $layerObj->legendLabel = $legendLabel;
+ $selectable = strtolower($layer->getMetaData('selectable'));
+ $layerObj->selectable = $selectable == 'true' ? true : false;
+ $layerObj->visible = ($layer->status == MS_ON || $layer->status == MS_DEFAULT);
+ $layerObj->actuallyVisible = true;
+ $editable = strtolower($layer->getMetaData('editable'));
+ $layerObj->editable = $editable == 'true' ? true : false;
+ /* process the classes. The legend expects things
+ * organized by scale range so we have to first
+ * find all the scale breaks, then create ranges
+ * for each scale break pair, then slot the classes
+ * into the scale ranges that they apply to.
+ $aScaleRanges = array();
+ //create a default scale range for the layer as a whole
+ $layerMin = $layer->minscale == -1 ? $minScale : $layer->minscale;
+ $layerMax = $layer->maxscale == -1 ? $maxScale : $layer->maxscale;
+ /* check to see that the layer has a vaild scale range
+ * inside the defined map's main min max scale ranges
+ * set them to the maps scale ranges if they exceede
+ if($layer->minscale != -1 && $layerMin < $minScale)
+ $layerMin = $minScale;
+ if($layer->maxscale != -1 && $layerMax > $maxScale)
+ $layerMax = $maxScale;
+ //find all the unique scale breaks in this layer
+ $aScaleBreaks = array($layerMin, $layerMax);
+ for ($j=0; $j<$layer->numclasses; $j++) {
+ $oClass = $layer->getClass($j);
+ $classMin = $oClass->minscale == -1 ? $layerMin : max($oClass->minscale, $layerMin);
+ $classMax = $oClass->maxscale == -1 ? $layerMax : min($oClass->maxscale, $layerMax);
+ if (!in_array($classMin, $aScaleBreaks)) {
+ array_push($aScaleBreaks, $classMin);
+ if (!in_array($classMax, $aScaleBreaks)) {
+ array_push($aScaleBreaks, $classMax);
+ //sort them
+ sort($aScaleBreaks);
+ //create scale ranges for each pair of breaks
+ for ($j=0; $j<count($aScaleBreaks)-1; $j++) {
+ $scaleRange = NULL;
+ $scaleRange->minScale = $aScaleBreaks[$j];
+ $scaleRange->maxScale = $aScaleBreaks[$j+1];
+ $scaleRange->styles = array();
+ array_push($aScaleRanges, $scaleRange);
+ //create classes and slot them into the scale breaks
+ $classObj = NULL;
+ // Use formatted legend label as defined by CLASS->TITLE
+ $classObj->legendLabel = $oClass->title != '' ? $oClass->title : $oClass->name;
+ $classObj->filter = $oClass->getExpression();
+ $classObj->minScale = $classMin;
+ $classObj->maxScale = $classMax;
+ $classObj->index = $j;
+ for ($k=0; $k<count($aScaleRanges); $k++) {
+ if ($classMin < $aScaleRanges[$k]->maxScale &&
+ $classMax > $aScaleRanges[$k]->minScale) {
+ array_push($aScaleRanges[$k]->styles, $classObj);
+ //$layerObj->scaleRanges = $aScaleRanges;
+ $_SESSION['scale_ranges'][$mapName][$layer->name] = $aScaleRanges;
+ /*get the min/max scale for the layer*/
+ $nCount = count($aScaleRanges);
+ $layerObj->minScale = $aScaleRanges[0]->minScale;
+ $layerObj->maxScale = $aScaleRanges[0]->maxScale;
+ for ($j=1; $j<$nCount; $j++)
+ $layerObj->minScale = min($layerObj->minScale, $aScaleRanges[$j]->minScale);
+ $layerObj->maxScale = max($layerObj->maxScale, $aScaleRanges[$j]->maxScale);
+ array_push($mapObj->layers, $layerObj);
+ $mapObj->groups = array();
+ $aGroups = $oMap->getAllGroupNames();
+ foreach($aGroups as $groupName) {
+ $aLayerIndexes = $oMap->getLayersIndexByGroup($groupName);
+ if (count($aLayerIndexes) > 0) {
+ array_push($mapObj->groups, getGroupObject($oMap->getLayer($aLayerIndexes[0])));
+ echo var2json($mapObj);
+function getGroupObject($layer) {
+ $group = NULL;
+ $group->groupName = $layer->group;
+ $ll = $layer->getMetaData('groupLegendLabel');
+ $group->legendLabel = $ll != '' ? $ll : $group->groupName;
+ $group->uniqueId = $group->groupName;
+ $b = $layer->getMetaData('groupDisplayInLegend');
+ $group->displayInLegend = ($b == 'false') ? false : true;
+ $b = $layer->getMetaData('groupExpandInLegend');
+ $group->expandInLegend = ($b == 'false') ? false : true;
+ $group->layerGroupType = '';
+ /* parent is always not set for mapserver since we can't have nested groups */
+ $group->parentUniqueId = '';
+ $group->parent = '';
+ $b = $layer->getMetaData('groupVisible');
+ $group->visible = ($b == 'false') ? false : true;
+ $group->actuallyVisible = $layer->isVisible();
+ $group->groupParent = $layer->getMetaData('groupParent');
+ return $group;
+function GetMetersPerUnit($unit)
+ if ($unit == MS_INCHES)
+ return 0.0254;
+ else if ($unit == MS_FEET)
+ return 0.3048;
+ else if ($unit == MS_MILES)
+ return 1609.344;
+ else if ($unit == MS_METERS)
+ return 1;
+ else if ($unit == MS_KILOMETERS)
+ return 1000;
+ else if ($unit == MS_DD)
+ return 111118.7516;
+ else if ($unit == MS_PIXELS)
+ return 1;
+function replaceInvalidLayerName($szLayerName){
+ bug http://trac.osgeo.org/fusion/ticket/96 - Invalid characters in layer name (pdeschamps)
+ Fusion requests the map imavge via the Mapserver CGI to toggle the layer visibility.
+ The layer paramerter for the cgi uses spaces as a delimiter for the layer names this creates
+ an issue for the mapserver binary to toggle layers that have these reserved URI characters.
+ also removing characters that could pose potential issues with json.
+ $aInvalidLayerNameCharacters = array();
+ $aInvalidLayerNameCharacters[0] ="&";
+ $aInvalidLayerNameCharacters[1] =" ";
+ $aInvalidLayerNameCharacters[2] ="#";
+ $aInvalidLayerNameCharacters[3] ="\\";
+ $aInvalidLayerNameCharacters[4] ="=";
+ $aInvalidLayerNameCharacters[5] ="/";
+ $aInvalidLayerNameCharacters[6] ="'";
+ $aReplace[0] = "_";
+ $aReplace[1] = "_";
+ $aReplace[2] = "_";
+ $aReplace[3] = "_";
+ $aReplace[4] = "_";
+ $aReplace[5] = "_";
+ $aReplace[6] = "_";
+ return str_replace($aInvalidLayerNameCharacters,$aReplace,$szLayerName);
Modified: sandbox/jxlib-3.0/layers/MapServer/php/Session.php
--- sandbox/jxlib-3.0/layers/MapServer/php/Session.php 2010-09-02 02:52:59 UTC (rev 2213)
+++ sandbox/jxlib-3.0/layers/MapServer/php/Session.php 2010-09-02 14:21:53 UTC (rev 2214)
@@ -62,489 +62,494 @@
$GLOBALS['bLockSession'] = false;
- * _open Called by PHP session manager when a session is opened.
- * We just set the save path and session name into global variable.
- * @param szSavePath String containing the absolute path where to
- * save session info.
- * @param szSessionName String contqaining the session name.
-function _open($szSavePath, $szSessionName)
- if ($GLOBALS["bDebug"])
- debug_msg("Opened() $szSavePath, $szSessionName");
- debug_msg("session_id() says ".session_id());
+if (!function_exists("_open")) {
+ * _open Called by PHP session manager when a session is opened.
+ * We just set the save path and session name into global variable.
+ * @param szSavePath String containing the absolute path where to
+ * save session info.
+ * @param szSessionName String contqaining the session name.
+ function _open($szSavePath, $szSessionName)
+ if ($GLOBALS["bDebug"])
+ debug_msg("Opened() $szSavePath, $szSessionName");
+ debug_msg("session_id() says ".session_id());
- $GLOBALS['gszSessSavePath'] = $szSavePath;
- $GLOBALS['gszSessName'] = $szSessionName;
- $GLOBALS['gszSessId'] = session_id();
+ $GLOBALS['gszSessSavePath'] = $szSavePath;
+ $GLOBALS['gszSessName'] = $szSessionName;
+ $GLOBALS['gszSessId'] = session_id();
- $szSessionDir = $GLOBALS['gszSessSavePath']."/sess_".$GLOBALS['gszSessId'];
- $szSessionFile = $szSessionDir."/session_file";
- $szLockFile = $szSessionDir."/lock";
+ $szSessionDir = $GLOBALS['gszSessSavePath']."/sess_".$GLOBALS['gszSessId'];
+ $szSessionFile = $szSessionDir."/session_file";
+ $szLockFile = $szSessionDir."/lock";
- clearstatcache();
- if (!file_exists($szSessionDir))
- mkdir($szSessionDir);
+ clearstatcache();
+ if (!file_exists($szSessionDir))
+ mkdir($szSessionDir);
- if ( PHP_OS == "WINNT" || PHP_OS == "WIN32" || $GLOBALS['bLockSession'])
- $i=0;
- while ($i < ini_get("max_execution_time") - 2 ) //wait at most 2 seconds less than the execution time for the lock
- clearstatcache();
- if (!file_exists($szLockFile))
- break;
- debug_msg("pausing in open()");
- $i++;
- sleep(1);
- $fh = fopen( $szLockFile, "w+" );
- if ($fh !== false)
- fwrite( $fh, "1" );
- fclose($fh);
- debug_msg("created lock file in open()");
+ if ( PHP_OS == "WINNT" || PHP_OS == "WIN32" || $GLOBALS['bLockSession'])
+ $i=0;
+ while ($i < ini_get("max_execution_time") - 2 ) //wait at most 2 seconds less than the execution time for the lock
+ clearstatcache();
+ if (!file_exists($szLockFile))
+ break;
+ debug_msg("pausing in open()");
+ $i++;
+ sleep(1);
+ $fh = fopen( $szLockFile, "w+" );
+ if ($fh !== false)
+ fwrite( $fh, "1" );
+ fclose($fh);
+ debug_msg("created lock file in open()");
- return(true);
+ return(true);
- * _close Called by PHP session manager when a session is closed,
- * not destroyed. In this case we do nothing.
-function _close()
- debug_msg("Closed()");
- $szLockFile = $GLOBALS['gszSessSavePath']."/sess_".$GLOBALS["gszSessId"]."/lock";
- debug_msg("checking lock file $szLockFile");
- clearstatcache();
- if ( @is_file( $szLockFile ) )
- @unlink( $szLockFile );
- debug_msg("removed lock file $szLockFile");
- else
- debug_msg("lock file $szLockFile is missing.");
+ * _close Called by PHP session manager when a session is closed,
+ * not destroyed. In this case we do nothing.
+ function _close()
+ debug_msg("Closed()");
+ $szLockFile = $GLOBALS['gszSessSavePath']."/sess_".$GLOBALS["gszSessId"]."/lock";
+ debug_msg("checking lock file $szLockFile");
+ clearstatcache();
+ if ( @is_file( $szLockFile ) )
+ @unlink( $szLockFile );
+ debug_msg("removed lock file $szLockFile");
+ else
+ debug_msg("lock file $szLockFile is missing.");
- return(true);
+ return(true);
- * _read Called by PHP session manager when the session file
- * is read. In this case we just return the file content of
- * session_file file.
-function _read($szId)
- $GLOBALS["gszSessId"] = $szId;
+ * _read Called by PHP session manager when the session file
+ * is read. In this case we just return the file content of
+ * session_file file.
+ function _read($szId)
+ $GLOBALS["gszSessId"] = $szId;
- debug_msg("Read() $szId");
+ debug_msg("Read() $szId");
- $szSessionDir = $GLOBALS['gszSessSavePath']."/sess_".$szId;
+ $szSessionDir = $GLOBALS['gszSessSavePath']."/sess_".$szId;
- clearstatcache();
+ clearstatcache();
- if ($fp = @fopen($szSessionFile, "r"))
- $szSessionData = fread($fp, filesize($szSessionFile));
- fclose( $fp );
- return($szSessionData);
- else
- return(""); // Must return "" here.
+ if ($fp = @fopen($szSessionFile, "r"))
+ $szSessionData = fread($fp, filesize($szSessionFile));
+ fclose( $fp );
+ return($szSessionData);
+ else
+ return(""); // Must return "" here.
- * _write Called by PHP session manager when session should be
- * saved.
- * @param szId String containing the unique identifier of current
- * session.
- * @param szSessionData String containig the session file content
- * to be saved.
-function _write($szId, $szSessionData)
- $result = false;
- debug_msg("Write() $szId $szSessionData");
+ * _write Called by PHP session manager when session should be
+ * saved.
+ * @param szId String containing the unique identifier of current
+ * session.
+ * @param szSessionData String containig the session file content
+ * to be saved.
+ function _write($szId, $szSessionData)
+ $result = false;
+ debug_msg("Write() $szId $szSessionData");
- $szSessionFile = $GLOBALS['gszSessSavePath']."/sess_".$szId.
- "/session_file";
+ $szSessionFile = $GLOBALS['gszSessSavePath']."/sess_".$szId.
+ "/session_file";
- // touch command don't works under windows for directory.
- // since it is only needed for unix (for now) I'll test
- // the platform and bypass this call is windows platform.
- if ( !(PHP_OS == "WINNT" || PHP_OS == "WIN32") )
- @touch($GLOBALS['gszSessSavePath']."/sess_".$szId);
+ // touch command don't works under windows for directory.
+ // since it is only needed for unix (for now) I'll test
+ // the platform and bypass this call is windows platform.
+ if ( !(PHP_OS == "WINNT" || PHP_OS == "WIN32") )
+ @touch($GLOBALS['gszSessSavePath']."/sess_".$szId);
- if ($fp = @fopen($szSessionFile, "w"))
- $result = fwrite($fp, $szSessionData);
- fclose($fp);
+ if ($fp = @fopen($szSessionFile, "w"))
+ $result = fwrite($fp, $szSessionData);
+ fclose($fp);
- return($result);
+ return($result);
- * _destroy Called by PHP session manager when it should be explicitly
- * destroyed now.
-function _destroy($szId)
- debug_msg("Destroy $szId");
- if ( (PHP_OS == "WINNT" || PHP_OS == "WIN32"|| $GLOBALS['bLockSession']) )
+ * _destroy Called by PHP session manager when it should be explicitly
+ * destroyed now.
+ function _destroy($szId)
+ debug_msg("Destroy $szId");
+ if ( (PHP_OS == "WINNT" || PHP_OS == "WIN32"|| $GLOBALS['bLockSession']) )
- if ($GLOBALS['gszGarbageColectionCallBackFunction'] != "")
- if (function_exists($GLOBALS['gszGarbageColectionCallBackFunction']))
- eval($GLOBALS['gszGarbageColectionCallBackFunction']);
+ if ($GLOBALS['gszGarbageColectionCallBackFunction'] != "")
+ if (function_exists($GLOBALS['gszGarbageColectionCallBackFunction']))
+ eval($GLOBALS['gszGarbageColectionCallBackFunction']);
- $bReturn = true;
+ $bReturn = true;
- if (!$szDir = @opendir($GLOBALS['gszSessSavePath']))
- return false;
+ if (!$szDir = @opendir($GLOBALS['gszSessSavePath']))
+ return false;
- while($szFile = readdir($szDir))
- if (!strstr($szFile,'sess_'.$szId))
- continue;
+ while($szFile = readdir($szDir))
+ if (!strstr($szFile,'sess_'.$szId))
+ continue;
- $bReturn = (deleteDirectory($GLOBALS['gszSessSavePath']."/".
- $szFile)) ? $bReturn : false;
- closedir($szDir);
+ $bReturn = (deleteDirectory($GLOBALS['gszSessSavePath']."/".
+ $szFile)) ? $bReturn : false;
+ closedir($szDir);
- return $bReturn;
- return true;
+ return $bReturn;
+ return true;
- * _gc Called by PHP session manager when a session is started or
- * register (not all the time) depending og session.gc_probability
-function _gc($nMaxLifeTime)
- debug_msg("_gc called");
+ * _gc Called by PHP session manager when a session is started or
+ * register (not all the time) depending og session.gc_probability
+ function _gc($nMaxLifeTime)
+ debug_msg("_gc called");
- @touch($GLOBALS['gszSessSavePath']."/deleteme", time()-$nMaxLifeTime*60);
- system("find ".$GLOBALS['gszSessSavePath']." -name sess_* ! -newer ".
- $GLOBALS['gszSessSavePath']."/deleteme -exec rm -rf {} \; ");
+ @touch($GLOBALS['gszSessSavePath']."/deleteme", time()-$nMaxLifeTime*60);
+ system("find ".$GLOBALS['gszSessSavePath']." -name sess_* ! -newer ".
+ $GLOBALS['gszSessSavePath']."/deleteme -exec rm -rf {} \; ");
- return true;
+ return true;
- $bReturn = true;
+ $bReturn = true;
- if (!$hDir = @opendir($GLOBALS['gszSessSavePath']))
- return false;
+ if (!$hDir = @opendir($GLOBALS['gszSessSavePath']))
+ return false;
- while($szFile = readdir($hDir))
- if (!strstr($szFile,'sess_'))
- continue;
+ while($szFile = readdir($hDir))
+ if (!strstr($szFile,'sess_'))
+ continue;
- if (strpos($szFile,'sess_') != 0)
- continue;
+ if (strpos($szFile,'sess_') != 0)
+ continue;
- $szSessionDir = $GLOBALS['gszSessSavePath']."/".$szFile;
+ $szSessionDir = $GLOBALS['gszSessSavePath']."/".$szFile;
- if (!($mtime = @filemtime($szSessionFile)))
- $bReturn=false;
- continue;
+ if (!($mtime = @filemtime($szSessionFile)))
+ $bReturn=false;
+ continue;
- if (time() > $mtime + $nMaxLifeTime)
- $bReturn = (deleteDirectory($szSessionDir)) ? $bReturn : false;
- closedir($hDir);
+ if (time() > $mtime + $nMaxLifeTime)
+ $bReturn = (deleteDirectory($szSessionDir)) ? $bReturn : false;
+ closedir($hDir);
- return $bReturn;
+ return $bReturn;
-function deleteDirectory($szFile)
- if (PHP_OS != "WINNT" && PHP_OS != "WIN32")
- chmod($szFile,0777);
+ function deleteDirectory($szFile)
+ if (PHP_OS != "WINNT" && PHP_OS != "WIN32")
+ chmod($szFile,0777);
- if (is_dir($szFile))
- $handle = opendir($szFile);
- while($szFileName = readdir($handle))
- if ($szFileName != "." && $szFileName != "..")
- deleteDirectory($szFile."/".$szFileName);
- closedir($handle);
- rmdir($szFile);
- else
- unlink($szFile);
+ if (is_dir($szFile))
+ $handle = opendir($szFile);
+ while($szFileName = readdir($handle))
+ if ($szFileName != "." && $szFileName != "..")
+ deleteDirectory($szFile."/".$szFileName);
+ closedir($handle);
+ rmdir($szFile);
+ else
+ unlink($szFile);
-function installSessionDirectoryHandler($szGCCallBack="")
- $GLOBALS['gszGarbageColectionCallBackFunction'] = $szGCCallBack;
+ function installSessionDirectoryHandler($szGCCallBack="")
+ $GLOBALS['gszGarbageColectionCallBackFunction'] = $szGCCallBack;
- // Set handler functions
- session_set_save_handler("_open",
- "_close",
- "_read",
- "_write",
- "_destroy",
- "_gc");
+ // Set handler functions
+ session_set_save_handler("_open",
+ "_close",
+ "_read",
+ "_write",
+ "_destroy",
+ "_gc");
-function initializeSession( $szSessName="sid", $szSessSavePath="", $szSessionID="" )
+ function initializeSession( $szSessName="sid", $szSessSavePath="", $szSessionID="" )
- debug_msg("initializeSession( $szSessName, $szSessSavePath, $szSessionID )");
+ debug_msg("initializeSession( $szSessName, $szSessSavePath, $szSessionID )");
- //if session was run already don't execute again
- if (isset($GLOBALS['session_started']))
- return true;
- if ($szSessName == "")
- echo "<FONT color=#FF0000>FATAL ERROR: Sessionname not specified</FONT>";
- exit;
- else
- ini_set("session.name", $szSessName);
+ //if session was run already don't execute again
+ if (isset($GLOBALS['session_started']))
+ return true;
+ if ($szSessName == "")
+ echo "<FONT color=#FF0000>FATAL ERROR: Sessionname not specified</FONT>";
+ exit;
+ else
+ ini_set("session.name", $szSessName);
- if ($szSessSavePath != "")
- ini_set("session.save_path", $szSessSavePath);
+ if ($szSessSavePath != "")
+ ini_set("session.save_path", $szSessSavePath);
- clearstatcache();
- // Check if save path is writable
- if (!(file_exists(ini_get("session.save_path")) &&
- is_writable(ini_get("session.save_path"))))
- echo "<FONT COLOR=#DD0000>FATAL ERROR: Session save path (".ini_get("session.save_path").") doesn't exist or is not writable</FONT>";
- exit;
+ clearstatcache();
+ // Check if save path is writable
+ if (!(file_exists(ini_get("session.save_path")) &&
+ is_writable(ini_get("session.save_path"))))
+ echo "<FONT COLOR=#DD0000>FATAL ERROR: Session save path (".ini_get("session.save_path").") doesn't exist or is not writable</FONT>";
+ exit;
- //turn off cookies for propagating session ids
- ini_set( "session.use_cookies", "0" );
+ //turn off cookies for propagating session ids
+ ini_set( "session.use_cookies", "0" );
- // turn off tranparent SID (becuase of buffer problem)
- ini_set( "session.use_trans_sid", "0" );
+ // turn off tranparent SID (becuase of buffer problem)
+ ini_set( "session.use_trans_sid", "0" );
- // intialize tmp id
- $szTmpID = "";
+ // intialize tmp id
+ $szTmpID = "";
- // check both get and post variables
- if ( isset($GLOBALS['_GET'][ini_get('session.name')]) )
- $szTmpID = $GLOBALS['_GET'][ini_get('session.name')];
- elseif (isset($GLOBALS['_POST'][ini_get('session.name')]))
- $szTmpID = $GLOBALS['_POST'][ini_get('session.name')];
+ // check both get and post variables
+ if ( isset($GLOBALS['_GET'][ini_get('session.name')]) )
+ $szTmpID = $GLOBALS['_GET'][ini_get('session.name')];
+ elseif (isset($GLOBALS['_POST'][ini_get('session.name')]))
+ $szTmpID = $GLOBALS['_POST'][ini_get('session.name')];
- // create new if necessary
- if ( strlen( $szTmpID ) <= 0 )
- debug_msg("creating a new session because .$szTmpID. has zero characters ");
- // create new and set IP flag
- if ( strlen( $szSessionID ) > 0 )
- $szTmpID = $szSessionID;
- else
- $szTmpID = uniqid("");
- $bNewSession = true;
- debug_msg("creating a new session with id ");
- else
- $bNewSession = false;
+ // create new if necessary
+ if ( strlen( $szTmpID ) <= 0 )
+ debug_msg("creating a new session because .$szTmpID. has zero characters ");
+ // create new and set IP flag
+ if ( strlen( $szSessionID ) > 0 )
+ $szTmpID = $szSessionID;
+ else
+ $szTmpID = uniqid("");
+ $bNewSession = true;
+ debug_msg("creating a new session with id ");
+ else
+ $bNewSession = false;
- // initialize flag variable
- $bSessionOK = true;
+ // initialize flag variable
+ $bSessionOK = true;
- // set the session ID
- session_id( $szTmpID );
+ // set the session ID
+ session_id( $szTmpID );
- // Check if session is expired
- if (!$bNewSession)
- $szSavePath = getSessionSavePath();
- $szSessionFile = $szSavePath."/session_file";
+ // Check if session is expired
+ if (!$bNewSession)
+ $szSavePath = getSessionSavePath();
+ $szSessionFile = $szSavePath."/session_file";
- if (file_exists($szSessionFile))
- if ($atime=@filemtime($szSessionFile))
- if (time() > $atime + ini_get("session.gc_maxlifetime"))
+ if (file_exists($szSessionFile))
+ if ($atime=@filemtime($szSessionFile))
+ if (time() > $atime + ini_get("session.gc_maxlifetime"))
- // reset the session ID
+ // reset the session ID
- $bSessionOK = false;
+ $bSessionOK = false;
- //start the session
- session_start();
- register_shutdown_function( "session_write_close" );
+ //start the session
+ session_start();
+ register_shutdown_function( "session_write_close" );
- // set IP if a new session
- if ( $bNewSession ) $_SESSION["gszRemoteAdd"] = $_SERVER["REMOTE_ADDR"];
+ // set IP if a new session
+ if ( $bNewSession ) $_SESSION["gszRemoteAdd"] = $_SERVER["REMOTE_ADDR"];
- * Check IP to see if it is the same
+ * Check IP to see if it is the same
- // check if the IP has been set and validate
- if ( isset( $_SESSION["gszRemoteAdd"] ) &&
- strlen(trim($_SESSION["gszRemoteAdd"])) > 0 )
- // check if IP matches current client
- if ( trim( $_SESSION["gszRemoteAdd"] ) !=
- trim( $_SERVER["REMOTE_ADDR"] ) )
- // possible security breach void session
- /* if the session address is the loopback interface then it is
- * likely that the application was configured to use an external
- * address but someone is trying to test locally using localhost
- if ($_SESSION['gszRemoteAdd'] != '127.0.0.1')
- else
+ // check if the IP has been set and validate
+ if ( isset( $_SESSION["gszRemoteAdd"] ) &&
+ strlen(trim($_SESSION["gszRemoteAdd"])) > 0 )
+ // check if IP matches current client
+ if ( trim( $_SESSION["gszRemoteAdd"] ) !=
+ trim( $_SERVER["REMOTE_ADDR"] ) )
+ // possible security breach void session
+ /* if the session address is the loopback interface then it is
+ * likely that the application was configured to use an external
+ * address but someone is trying to test locally using localhost
+ if ($_SESSION['gszRemoteAdd'] != '127.0.0.1')
+ else
- // return success or failure and set global so we
- // know session has been inited.
- if ($bSessionOK)
- $GLOBALS['session_started'] = true;
+ // return success or failure and set global so we
+ // know session has been inited.
+ if ($bSessionOK)
+ $GLOBALS['session_started'] = true;
- return $bSessionOK;
+ return $bSessionOK;
-// end intializeSession() function
+ // end intializeSession() function
-function getSessionSavePath()
- $szReturn = ini_get("session.save_path")."/sess_".session_id()."/";
- $szReturn = str_replace( "\\", "/", $szReturn );
- return $szReturn;
+ function getSessionSavePath()
+ $szReturn = ini_get("session.save_path")."/sess_".session_id()."/";
+ $szReturn = str_replace( "\\", "/", $szReturn );
+ return $szReturn;
+ function debug_msg( $szMsg )
+ list($usec, $sec) = explode(" ",microtime());
+ $ts = sprintf( "%s.%4d", date( "H:s", $sec), round( 10000 * $usec ));
+ $fh = fopen($GLOBALS['szDebugDir']."session.log", "a+");
+ fwrite($fh, "$ts : ".$GLOBALS['szDebugPage']." : $szMsg\n");
+ fclose($fh);
-function debug_msg( $szMsg )
- list($usec, $sec) = explode(" ",microtime());
- $ts = sprintf( "%s.%4d", date( "H:s", $sec), round( 10000 * $usec ));
- $fh = fopen($GLOBALS['szDebugDir']."session.log", "a+");
- fwrite($fh, "$ts : ".$GLOBALS['szDebugPage']." : $szMsg\n");
- fclose($fh);
More information about the fusion-commits
