[fusion-commits] r2215 - sandbox/jxlib-3.0/layers/MapServer/php
svn_fusion at osgeo.org
Thu Sep 2 13:20:20 EDT 2010
Author: pagameba
Date: 2010-09-02 17:20:19 +0000 (Thu, 02 Sep 2010)
New Revision: 2215
sandbox/jxlib-3.0/layers/MapServer/php/GetAttributes.php
sandbox/jxlib-3.0/layers/MapServer/php/LegendIcon.php
sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php
fixing some annoying php notice and warning messages, get loadmap to work correctly again when using a file-based map file.
Modified: sandbox/jxlib-3.0/layers/MapServer/php/GetAttributes.php
--- sandbox/jxlib-3.0/layers/MapServer/php/GetAttributes.php 2010-09-02 14:21:53 UTC (rev 2214)
+++ sandbox/jxlib-3.0/layers/MapServer/php/GetAttributes.php 2010-09-02 17:20:19 UTC (rev 2215)
@@ -1,120 +1,121 @@
-<?php
- * GetAttributes
- * $Id: GetAttributes.php 1972 2009-11-11 20:47:47Z pagameba $
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Purpose: create a new selection based on one or more attribute filters and
- * a spatial filter
-/* set up the session */
-include ("Common.php");
-include('../../../common/php/Utilities.php');
-//header('Content-type: application/json');
-//header('X-JSON: true');
-/* the name of the layer in the map to query */
-if ($_REQUEST['layers'] != '') {
- $layers = explode(',',$_REQUEST['layers']);
-} else {
- $layers = array();
-//echo "<!--";
-//print_r($_REQUEST);
-//echo "-->";
-if (!isset($mapName)) {
- die('mapname not set');
-if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
- $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
-$bAllLayers = false;
-$nLayers = count($layers);
-if ($nLayers == 0) {
- $nLayers = $oMap->numlayers;
- $bAllLayers = true;
-/*holds selection array*/
-$properties = NULL;
-$properties->layers = array();
- echo "/* nLayers: ".$nLayers." */";
-for ($i=0; $i<$nLayers; $i++) {
- if (!$bAllLayers) {
- $oLayer = $oMap->GetLayerByName($layers[$i]);
- } else {
- $oLayer = $oMap->GetLayer($i);
- $selectable = strtolower($oLayer->getMetaData('selectable'));
- if ( $selectable == 'true' ) {
- $oLayer->open();
- $layerName = $oLayer->name != "" ? $oLayer->name : "Layer_".$i;
- echo "/* layername: ".$layerName." */";
- array_push($properties->layers, $layerName);
- $properties->$layerName->propertynames = array();
- $properties->$layerName->propertyvalues = array();
- $properties->$layerName->propertytypes = array();
- /*get first shape to get the attributes*/
- //$oRes = $oLayer->getResult(0);
- //$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
- $oShape = $oLayer->getFeature(0);
- while ( list($key,$val) = each($oShape->values) ) {
- array_push($properties->$layerName->propertynames, $key);
- //TODO : we should define away to give alias to field names
- array_push($properties->$layerName->propertyvalues, $key);
- //TODO we do not know the types of the attributes in MS. Just output 0
- //we shouls possibly use OGR to get the attributes
- array_push($properties->$layerName->propertytypes, 0);
- $oLayer->close();
- if(isset($_SESSION['selection_array']->$layerName)){
- if(isset($_SESSION['selection_array']->$layerName->values)){
- $properties->$layerName->values = $_SESSION['selection_array']->$layerName->values;
-/*save selection in the session*/
-//$_SESSION['selection_array'] = $properties;
-echo var2json($properties);
+<?php
+ * GetAttributes
+ * $Id: GetAttributes.php 1972 2009-11-11 20:47:47Z pagameba $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Purpose: create a new selection based on one or more attribute filters and
+ * a spatial filter
+/* set up the session */
+include ("Common.php");
+include('../../../common/php/Utilities.php');
+//header('Content-type: application/json');
+//header('X-JSON: true');
+/* the name of the layer in the map to query */
+if (isset($_REQUEST['layers']) && $_REQUEST['layers'] != '') {
+ $layers = explode(',',$_REQUEST['layers']);
+} else {
+ $layers = array();
+//echo "<!--";
+//print_r($_REQUEST);
+//echo "-->";
+if (!isset($mapName)) {
+ die('mapname not set');
+if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+ $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+$bAllLayers = false;
+$nLayers = count($layers);
+if ($nLayers == 0) {
+ $nLayers = $oMap->numlayers;
+ $bAllLayers = true;
+/*holds selection array*/
+$properties = NULL;
+$properties->layers = array();
+ echo "/* nLayers: ".$nLayers." */";
+for ($i=0; $i<$nLayers; $i++) {
+ if (!$bAllLayers) {
+ $oLayer = $oMap->GetLayerByName($layers[$i]);
+ } else {
+ $oLayer = $oMap->GetLayer($i);
+ $selectable = strtolower($oLayer->getMetaData('selectable'));
+ if ( $selectable == 'true' ) {
+ $oLayer->open();
+ $layerName = $oLayer->name != "" ? $oLayer->name : "Layer_".$i;
+ echo "/* layername: ".$layerName." */";
+ array_push($properties->layers, $layerName);
+ $properties->$layerName->propertynames = array();
+ $properties->$layerName->propertyvalues = array();
+ $properties->$layerName->propertytypes = array();
+ /*get first shape to get the attributes*/
+ //$oRes = $oLayer->getResult(0);
+ //$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
+ $oShape = $oLayer->getFeature(0);
+ if ($oShape) {
+ while ( list($key,$val) = each($oShape->values) ) {
+ array_push($properties->$layerName->propertynames, $key);
+ //TODO : we should define away to give alias to field names
+ array_push($properties->$layerName->propertyvalues, $key);
+ //TODO we do not know the types of the attributes in MS. Just output 0
+ //we shouls possibly use OGR to get the attributes
+ array_push($properties->$layerName->propertytypes, 0);
+ $oLayer->close();
+ if(isset($_SESSION['selection_array']->$layerName)){
+ if(isset($_SESSION['selection_array']->$layerName->values)){
+ $properties->$layerName->values = $_SESSION['selection_array']->$layerName->values;
+/*save selection in the session*/
+//$_SESSION['selection_array'] = $properties;
+echo var2json($properties);
Modified: sandbox/jxlib-3.0/layers/MapServer/php/LegendIcon.php
--- sandbox/jxlib-3.0/layers/MapServer/php/LegendIcon.php 2010-09-02 14:21:53 UTC (rev 2214)
+++ sandbox/jxlib-3.0/layers/MapServer/php/LegendIcon.php 2010-09-02 17:20:19 UTC (rev 2215)
@@ -1,130 +1,135 @@
-<?php
- * LegendIcon
- * $Id$
- * Purpose: Draw a legend icon
+<?php
+ * LegendIcon
+ * $Id$
+ * Purpose: Draw a legend icon
include(dirname(__FILE__).'/../../../common/php/Utilities.php');
-include(dirname(__FILE__).'/Common.php');
+include(dirname(__FILE__).'/Common.php');
include(dirname(__FILE__).'/Utilities.php');
$mapFile = getSessionSavePath().$mapName.".map";
$str = file_get_contents($mapFile);
-$legendIconCacheFile = "";
+$legendIconCacheFile = "";
if ($str) {
- $configObj = $_SESSION['fusionConfig'];
- /* if the legendIconCache dir is set */
- if (isset($configObj->mapserver->legendIconCacheDir)) {
- $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
- // check for closing '/'
- $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
- if ( substr( $legendIconCacheDir, -1 ) != '/' )
- $legendIconCacheDir .= '/';
- $cacheLegendIcons = true;
+ $configObj = $_SESSION['fusionConfig'];
+ /* if the legendIconCache dir is set */
+ if (isset($configObj->mapserver->legendIconCacheDir)) {
+ $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
+ // check for closing '/'
+ $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
+ if ( substr( $legendIconCacheDir, -1 ) != '/' )
+ $legendIconCacheDir .= '/';
+ $cacheLegendIcons = true;
//$str = file_get_contents($_SESSION['maps'][$mapName]);
- /* create a unique location for the map icons based on
- * the content of the of map file. If the content changes
- * then the icons should be rebuilt anyway
- $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
- if (!is_dir($legendIconCacheDir)) {
- mkdir($legendIconCacheDir);
- /* TODO: can we figure out what the content type is? */
- $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
- /* if the icon exists, return it */
- if (file_exists($legendIconCacheFile)) {
- header('Content-type: image/png');
- $etag = '"' . md5_file($legendIconCacheFile) . '"';
- header ("ETag: " . $etag );
- $cache_time = mktime(0, 0, 0, 1, 1, 2004);
- $expires = 3600 * 256;
- header("last-modified: " . gmdate("D, d M Y H:i:s",$cache_time) . " GMT");
- $inm = split(',', getenv("HTTP_IF_NONE_MATCH"));
- $send_body = true;
- foreach ($inm as $i) {
- if (trim($i) == $etag || trim($i) == $cache_time) {
- header ("HTTP/1.0 304 Not Modified");
- $send_body = false;
- //last modified test
- if(getenv("HTTP_IF_MODIFIED_SINCE") == gmdate("D, d M Y H:i:s",$cache_time). " GMT") {
- //more headers
- header("Expires: " . gmdate("D, d M Y H:i:s",$cache_time+$expires) . " GMT");
- header("Cache-Control: max-age=$expires, must-revalidate");
- //header('Content-Length: ' . strlen($body));
- //if we're not cacheing
- if ($send_body) {
- readfile($legendIconCacheFile);
- exit;
+ /* create a unique location for the map icons based on
+ * the content of the of map file. If the content changes
+ * then the icons should be rebuilt anyway
+ $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
+ if (!is_dir($legendIconCacheDir)) {
+ mkdir($legendIconCacheDir);
+ /* TODO: can we figure out what the content type is? */
+ $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
+ /* if the icon exists, return it */
+ if (file_exists($legendIconCacheFile)) {
+ header('Content-type: image/png');
+ $etag = '"' . md5_file($legendIconCacheFile) . '"';
+ header ("ETag: " . $etag );
+ $cache_time = mktime(0, 0, 0, 1, 1, 2004);
+ $expires = 3600 * 256;
+ header("last-modified: " . gmdate("D, d M Y H:i:s",$cache_time) . " GMT");
+ $inm = split(',', getenv("HTTP_IF_NONE_MATCH"));
+ $send_body = true;
+ foreach ($inm as $i) {
+ if (trim($i) == $etag || trim($i) == $cache_time) {
+ header ("HTTP/1.0 304 Not Modified");
+ $send_body = false;
+ //last modified test
+ if(getenv("HTTP_IF_MODIFIED_SINCE") == gmdate("D, d M Y H:i:s",$cache_time). " GMT") {
+ //more headers
+ header("Expires: " . gmdate("D, d M Y H:i:s",$cache_time+$expires) . " GMT");
+ header("Cache-Control: max-age=$expires, must-revalidate");
+ //header('Content-Length: ' . strlen($body));
+ //if we're not cacheing
+ if ($send_body) {
+ readfile($legendIconCacheFile);
+ exit;
$oMap = ms_newMapObj($mapFile);
- $oLayer = $oMap->getLayerByName($REQUEST_VARS['layername']);
- $oClass = $oLayer->getClass($REQUEST_VARS['classindex']);
- $width = $oMap->legend->keysizex;
- $height = $oMap->legend->keysizey;
- if ($width <=0) {
- $width = 16;
- if ($height <=0) {
- $height = 16;
- $oImg = $oClass->createLegendIcon($width, $height);
- if ($cacheLegendIcons) {
- $oImg->saveImage($legendIconCacheFile);
- } else {
- $oImg->saveImage("");
- $oImg->free();
+ $oLayer = $oMap->getLayerByName($REQUEST_VARS['layername']);
+ $oClass = $oLayer->getClass($REQUEST_VARS['classindex']);
+ $width = $oMap->legend->keysizex;
+ $height = $oMap->legend->keysizey;
+ if ($width <=0) {
+ $width = 16;
+ if ($height <=0) {
+ $height = 16;
+ if ($oClass) {
+ $oImg = $oClass->createLegendIcon($width, $height);
+ } else {
+ $oMap->setSize($width,$height);
+ $oImg = $oMap->prepareImage();
+ if ($cacheLegendIcons) {
+ $oImg->saveImage($legendIconCacheFile);
+ } else {
+ $oImg->saveImage("");
+ $oImg->free();
Modified: sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php
--- sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php 2010-09-02 14:21:53 UTC (rev 2214)
+++ sandbox/jxlib-3.0/layers/MapServer/php/LoadMap.php 2010-09-02 17:20:19 UTC (rev 2215)
@@ -89,10 +89,11 @@
$sMapFileContents = $result->Get('MAPDATA');
- } else {
- $sMapFileContents = file_get_contents($szMapFile);
+ $oMap = ms_newMapObjFromString($sMapFileContents);
+ } else if (file_exists($szMapFile)) {
+ $modifyPaths = true;
+ $oMap = ms_newMapObj($szMapFile);
- $oMap = ms_newMapObjFromString($sMapFileContents);
/* optionally move the mapfile to the session */
if ($moveToSession) {
@@ -158,6 +159,8 @@
$mapObj = NULL;
if ($oMap) {
+ $mapName = $oMap->name;
$mapObj->sessionId = $sessionID;
More information about the fusion-commits
