[fusion-commits] r2216 - sandbox/jxlib-3.0/layers/MapServer/php
svn_fusion at osgeo.org
Fri Sep 3 11:47:13 EDT 2010
Author: pagameba
Date: 2010-09-03 15:47:13 +0000 (Fri, 03 Sep 2010)
New Revision: 2216
sandbox/jxlib-3.0/layers/MapServer/php/LoadScaleRanges.php
check to see if class is valid before creating a legend icon for it.
Modified: sandbox/jxlib-3.0/layers/MapServer/php/LoadScaleRanges.php
--- sandbox/jxlib-3.0/layers/MapServer/php/LoadScaleRanges.php 2010-09-02 17:20:19 UTC (rev 2215)
+++ sandbox/jxlib-3.0/layers/MapServer/php/LoadScaleRanges.php 2010-09-03 15:47:13 UTC (rev 2216)
@@ -1,41 +1,41 @@
-<?php
- * SetLayers
- * $Id: $
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Utility function to load scale ranges for the layers. Initially
- * scale ranges were returned as part of in LoadMap.php. This allows
- * to reduce the size of information that is returned by LoadMap, by putting
- * elements that are unnessary to the map draw her.
-/* set up the session */
+<?php
+ * SetLayers
+ * $Id: $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Utility function to load scale ranges for the layers. Initially
+ * scale ranges were returned as part of in LoadMap.php. This allows
+ * to reduce the size of information that is returned by LoadMap, by putting
+ * elements that are unnessary to the map draw her.
+/* set up the session */
include(dirname(__FILE__).'/../../../common/php/Utilities.php');
include(dirname(__FILE__).'/Common.php');
include(dirname(__FILE__).'/Utilities.php');
/*if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
$oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
@@ -107,7 +107,7 @@
if($layer->maxscale != -1 && $layerMax > $maxScale)
$layerMax = $maxScale;
//find all the unique scale breaks in this layer
$aScaleBreaks = array($layerMin, $layerMax);
for ($j=0; $j<$layer->numclasses; $j++) {
@@ -156,97 +156,98 @@
//$layerObj->scaleRanges = $aScaleRanges;
$_SESSION['scale_ranges'][$mapName][$layer->name] = $aScaleRanges;
$scaleObj = NULL;
$scaleObj->layers = array();
define('ICON_SIZE', 16);
$nIconWidth = $oMap->legend->keysizex;
$nIconHeight = $oMap->legend->keysizey;
if ($nIconWidth <=0)
- $nIconWidth = ICON_SIZE;
+ $nIconWidth = ICON_SIZE;
$nTotalClasses=0;
$aIcons = array();
/*special case to force the the legend icons to be drawn using a gd driver
- This was fixed in ticket http://trac.osgeo.org/mapserver/ticket/2682 which
- will be available for mapserver version 5.2.1 and 5.4
- Note that we do not check the outputformat of the map (assuming that we are
- using GD or AGG renderers)
+ This was fixed in ticket http://trac.osgeo.org/mapserver/ticket/2682 which
+ will be available for mapserver version 5.2.1 and 5.4
+ Note that we do not check the outputformat of the map (assuming that we are
+ using GD or AGG renderers)
$nVersion = ms_GetVersionInt();
if ($nVersion <= 50200) /*5.2 and before*/
- $oMap->selectOutputFormat("png24");
+ $oMap->selectOutputFormat("png24");
for($i=0;$i<$oMap->numlayers;$i++)
- $layer = $oMap->getLayer($i);
+ $layer = $oMap->getLayer($i);
if (isset($_SESSION['scale_ranges']) && isset($_SESSION['scale_ranges'][$mapName]) && isset($_SESSION['scale_ranges'][$mapName][$layer->name]))
$scaleranges = $_SESSION['scale_ranges'][$mapName][$layer->name];
- $layerObj = NULL;
- $layerObj->uniqueId = $i;
- /*generate the legend icons here*/
- $nScaleRanges = count($scaleranges);
- for ($j=0; $j<$nScaleRanges; $j++)
- $nStyles = count($scaleranges[$j]->styles);
- for ($k=0; $k<$nStyles; $k++)
- $nClassIndex = $scaleranges[$j]->styles[$k]->index;
- $oClass = $layer->getClass($nClassIndex);
- $oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
- array_push($aIcons, $oImg);
- $scaleranges[$j]->styles[$k]->icon_x = ($nTotalClasses*$nIconWidth);
- $scaleranges[$j]->styles[$k]->icon_y=0;
- $nTotalClasses++;
- $layerObj->scaleRanges = $scaleranges;
- array_push($scaleObj->layers, $layerObj);
+ $layerObj = NULL;
+ $layerObj->uniqueId = $i;
+ /*generate the legend icons here*/
+ $nScaleRanges = count($scaleranges);
+ for ($j=0; $j<$nScaleRanges; $j++)
+ $nStyles = count($scaleranges[$j]->styles);
+ for ($k=0; $k<$nStyles; $k++)
+ $nClassIndex = $scaleranges[$j]->styles[$k]->index;
+ $oClass = $layer->getClass($nClassIndex);
+ if ($oClass) {
+ $oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
+ array_push($aIcons, $oImg);
+ $scaleranges[$j]->styles[$k]->icon_x = ($nTotalClasses*$nIconWidth);
+ $scaleranges[$j]->styles[$k]->icon_y=0;
+ $nTotalClasses++;
+ $layerObj->scaleRanges = $scaleranges;
+ array_push($scaleObj->layers, $layerObj);
if ($nTotalClasses > 0) {
- //set the image path and image dir based on what fusion config file
- $configObj = $_SESSION['fusionConfig'];
- $original_imagepath = $oMap->web->imagepath;
- $original_imageurl = $oMap->web->imageurl;
- if (isset($configObj->mapserver->imagePath) && $configObj->mapserver->imagePath !="")
- $oMap->web->set("imagepath", $configObj->mapserver->imagePath);
- if(isset($configObj->mapserver->imageUrl) && $configObj->mapserver->imageUrl!="")
- $oMap->web->set("imageurl", $configObj->mapserver->imageUrl);
- //build and image containing all the icons and return url
- $nTmpWidth = $oMap->width;
- $nTmpHeight = $oMap->height;
- $oMap->set("width", $nTotalClasses*$nIconWidth);
- $oMap->set("height", $nIconHeight);
- $oImage = $oMap->prepareImage();
- $oMap->set("width", $nTmpWidth);
- $oMap->set("height", $nTmpHeight);
- for ($i=0; $i<$nTotalClasses;$i++)
- $oImage->pasteImage($aIcons[$i], -1, $i*$nIconWidth, 0);
- $scaleObj->icons_url = $oImage->saveWebImage();
- $scaleObj->icons_width = $nIconWidth;
- $scaleObj->icons_height = $nIconHeight;
- $oMap->web->set("imagepath", $original_imagepath);
- $oMap->web->set("imageurl", $original_imageurl);
+ //set the image path and image dir based on what fusion config file
+ $configObj = $_SESSION['fusionConfig'];
+ $original_imagepath = $oMap->web->imagepath;
+ $original_imageurl = $oMap->web->imageurl;
+ if (isset($configObj->mapserver->imagePath) && $configObj->mapserver->imagePath !="")
+ $oMap->web->set("imagepath", $configObj->mapserver->imagePath);
+ if(isset($configObj->mapserver->imageUrl) && $configObj->mapserver->imageUrl!="")
+ $oMap->web->set("imageurl", $configObj->mapserver->imageUrl);
+ //build and image containing all the icons and return url
+ $nTmpWidth = $oMap->width;
+ $nTmpHeight = $oMap->height;
+ $oMap->set("width", $nTotalClasses*$nIconWidth);
+ $oMap->set("height", $nIconHeight);
+ $oImage = $oMap->prepareImage();
+ $oMap->set("width", $nTmpWidth);
+ $oMap->set("height", $nTmpHeight);
+ for ($i=0; $i<$nTotalClasses;$i++)
+ $oImage->pasteImage($aIcons[$i], -1, $i*$nIconWidth, 0);
+ $scaleObj->icons_url = $oImage->saveWebImage();
+ $scaleObj->icons_width = $nIconWidth;
+ $scaleObj->icons_height = $nIconHeight;
+ $oMap->web->set("imagepath", $original_imagepath);
+ $oMap->web->set("imageurl", $original_imageurl);
@@ -275,13 +276,13 @@
$aReplace[4] = "_";
$aReplace[5] = "_";
$aReplace[6] = "_";
return str_replace($aInvalidLayerNameCharacters,$aReplace,$szLayerName);
-header('Content-type: application/json');
-header('X-JSON: true');
-echo var2json($scaleObj);
-exit;
+header('Content-type: application/json');
+header('X-JSON: true');
+echo var2json($scaleObj);
+exit;
\ No newline at end of file
More information about the fusion-commits
