[fusion-commits] r2240 - branches/fusion-2.2/lib
svn_fusion at osgeo.org
Wed Sep 29 09:57:05 EDT 2010
Author: madair
Date: 2010-09-29 13:57:05 +0000 (Wed, 29 Sep 2010)
New Revision: 2240
branches/fusion-2.2/lib/jxlib.uncompressed.js
re #408: patch applied to the file jxlib.uncompressed.js
Modified: branches/fusion-2.2/lib/jxlib.uncompressed.js
--- branches/fusion-2.2/lib/jxlib.uncompressed.js 2010-09-28 17:55:17 UTC (rev 2239)
+++ branches/fusion-2.2/lib/jxlib.uncompressed.js 2010-09-29 13:57:05 UTC (rev 2240)
@@ -1405,17 +1405,27 @@
Document.implement({
- newElement: function(tag, props){
- if (Browser.Engine.trident && props){
- ['name', 'type', 'checked'].each(function(attribute){
- if (!props[attribute]) return;
- tag += ' ' + attribute + '="' + props[attribute] + '"';
- if (attribute != 'checked') delete props[attribute];
- tag = '<' + tag + '>';
- return $.element(this.createElement(tag)).set(props);
+ newElement: function(tag, props) {
+ var createdElement;
+ if (Browser.Engine.trident && props) {
+ ['name', 'type', 'checked'].each(function(attribute) {
+ if (!props[attribute]) return;
+ tag += ' ' + attribute + '="' + props[attribute] + '"';
+ if (attribute != 'checked') delete props[attribute];
+ var replaceTag = '<' + tag + '>';
+ try {
+ createdElement = this.createElement(replaceTag);
+ catch (e) {
+ createdElement = this.createElement(tag);
+ else {
+ return $.element(createdElement).set(props);
newTextNode: function(text){
return this.createTextNode(text);
More information about the fusion-commits
