[fusion-commits] r2241 - sandbox/jxlib-3.0/lib
svn_fusion at osgeo.org
Wed Sep 29 16:19:20 EDT 2010
Author: pagameba
Date: 2010-09-29 20:19:20 +0000 (Wed, 29 Sep 2010)
New Revision: 2241
sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
updating jxlib 3 build.
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-09-29 13:57:05 UTC (rev 2240)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2010-09-29 20:19:20 UTC (rev 2241)
@@ -18617,15 +18617,17 @@
* marked as deleted.
each: function (fn, bind, ignoreDeleted) {
- var data;
- if (ignoreDeleted) {
- data = this.data.filter(function (record) {
- return record.state !== Jx.Record.DELETE;
- }, this);
- } else {
- data = this.data;
+ if ($defined(this.data)) {
+ var data;
+ if (ignoreDeleted) {
+ data = this.data.filter(function (record) {
+ return record.state !== Jx.Record.DELETE;
+ }, this);
+ } else {
+ data = this.data;
+ data.each(fn, bind);
- data.each(fn, bind);
* APIMethod: get
@@ -31292,10 +31294,16 @@
* APIMethod: getHeaderHTML
getHeaderHTML : function () {
- if (this.isSortable()) {
- new Element('img', {
+ if (this.isSortable() && !this.sortImage) {
+ this.sortImage = new Element('img', {
src: Jx.aPixel.src
- }).inject(this.domObj);
+ this.sortImage.inject(this.domObj);
+ } else {
+ if (!this.isSortable() && this.sortImage) {
+ this.sortImage.dispose();
+ this.sortImage = null;
return this.domObj;
@@ -31631,6 +31639,9 @@
* create the row template based on the current columns
buildTemplates: function() {
+ if (!this.grid) {
+ return;
var rowTemplate = '',
hasExpandable = false,
grid = this.grid,
@@ -32533,6 +32544,16 @@
'gridMouseLeave': false
+ this.storeEvents = {
+ 'storeDataLoaded': this.storeLoaded,
+ // 'storeSortFinished': this.drawStore,
+ 'storeRecordAdded': this.addRow,
+ 'storeColumnChanged': this.updateRow,
+ 'storeRecordRemoved': this.removeRow,
+ 'storeMultipleRecordsRemoved': this.removeRows
this.parent();
@@ -32625,12 +32646,7 @@
if (store instanceof Jx.Store) {
- store.addEvent('storeDataLoaded', this.storeLoaded);
- // store.addEvent('storeSortFinished', this.drawStore);
- store.addEvent('storeRecordAdded', this.addRow);
- store.addEvent('storeColumnChanged', this.updateRow);
- store.addEvent('storeRecordRemoved', this.removeRow);
- store.addEvent('storeMultipleRecordsRemoved', this.removeRows);
+ store.addEvents(this.storeEvents);
if (store.loaded) {
this.storeLoaded(store);
@@ -32723,8 +32739,15 @@
* store - {Object} the store to use for this grid
setStore: function(store) {
+ if (this.store) {
+ this.store.removeEvents(this.storeEvents);
this.store = store;
+ if (store.loaded) {
+ this.storeLoaded(store);
this.render();
this.domObj.resize();
} else {
@@ -32754,6 +32777,8 @@
this.gridObj.getElement('tbody').empty();
+ this.hoverColumn = this.hoverRow = this.hoverCell = null;
// TODO: consider moving whole thing into Jx.Columns ??
// create a suitable column representation for everything
// in the store that doesn't already have a representation
@@ -32814,8 +32839,8 @@
this.columns.calculateWidths();
this.columns.createRules(this.styleSheet+'Columns', '.'+this.uniqueId);
+ this.drawStore();
this.fireEvent('doneCreateGrid');
- this.drawStore();
@@ -33751,11 +33776,14 @@
if (grid) {
grid.gridTableBody.removeEvents({
click: this.onCellClick
+ if (this.checkColumn) {
+ grid.columns.columns.erase(this.checkColumn);
+ this.checkColumn.destroy();
+ this.checkColumn = null;
if (options.useCheckColumn) {
- col = grid.columns.getByName('selection');
- grid.columns.columns.erase(col);
if (options.checkAsHeader) {
grid.row.options.headerColumn = this.oldHeaderColumn;
@@ -34798,7 +34826,7 @@
var grid = this.grid,
store = grid.store;
this.removeHandles();
- if (this.options.column) {
+ if (this.options.column && grid.columns.useHeaders()) {
grid.columns.columns.each(function(col, idx) {
if (col.isResizable() && !col.isHidden()) {
var colEl = grid.colObj.getElement('.jxGridCol'+idx+ ' .jxGridCellContent');
More information about the fusion-commits
