[fusion-commits] r2349 - in trunk: layers/MapGuide lib
svn_fusion at osgeo.org
Tue Mar 29 14:28:36 EDT 2011
Author: madair
Date: 2011-03-29 11:28:35 -0700 (Tue, 29 Mar 2011)
New Revision: 2349
trunk/layers/MapGuide/MapGuide.js
trunk/lib/fusion.js
re #434: use WKT returned by MapGuide over the EPSG code returned
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2011-03-29 14:00:46 UTC (rev 2348)
+++ trunk/layers/MapGuide/MapGuide.js 2011-03-29 18:28:35 UTC (rev 2349)
@@ -310,13 +310,13 @@
//set projection units and code if supplied
var wktProj;
- if (o.epsg != 0) {
+ if (o.wkt && o.wkt.length > 0){
+ wktProj = new OpenLayers.Projection(o.wkt);
+ } else if (o.epsg != 0) {
this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
} else {
//default to the local non-projected system if not otherwise specified
- if (!o.wkt || o.wkt.length == 0){
- o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
//TODO: consider passing the metersPerUnit value into the framework
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2011-03-29 14:00:46 UTC (rev 2348)
+++ trunk/lib/fusion.js 2011-03-29 18:28:35 UTC (rev 2349)
@@ -1227,6 +1227,7 @@
var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+ OpenLayers.INCHES_PER_UNIT["Degree"] = inPerUnit;
More information about the fusion-commits
