[fusion-commits] r2350 - in branches/fusion-2.2: layers/MapGuide lib
svn_fusion at osgeo.org
Tue Mar 29 14:29:16 EDT 2011
Author: madair
Date: 2011-03-29 11:29:16 -0700 (Tue, 29 Mar 2011)
New Revision: 2350
branches/fusion-2.2/layers/MapGuide/MapGuide.js
branches/fusion-2.2/lib/fusion.js
closes #434: use WKT returned by MapGuide over the EPSG code returned
Modified: branches/fusion-2.2/layers/MapGuide/MapGuide.js
--- branches/fusion-2.2/layers/MapGuide/MapGuide.js 2011-03-29 18:28:35 UTC (rev 2349)
+++ branches/fusion-2.2/layers/MapGuide/MapGuide.js 2011-03-29 18:29:16 UTC (rev 2350)
@@ -306,13 +306,13 @@
//set projection units and code if supplied
var wktProj;
- if (o.epsg != 0) {
+ if (o.wkt && o.wkt.length > 0){
+ wktProj = new OpenLayers.Projection(o.wkt);
+ } else if (o.epsg != 0) {
this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
} else {
//default to the local non-projected system if not otherwise specified
- if (!o.wkt || o.wkt.length == 0){
- o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
//TODO: consider passing the metersPerUnit value into the framework
Modified: branches/fusion-2.2/lib/fusion.js
--- branches/fusion-2.2/lib/fusion.js 2011-03-29 18:28:35 UTC (rev 2349)
+++ branches/fusion-2.2/lib/fusion.js 2011-03-29 18:29:16 UTC (rev 2350)
@@ -1227,6 +1227,7 @@
var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+ OpenLayers.INCHES_PER_UNIT["Degree"] = inPerUnit;
More information about the fusion-commits
