[fusion-commits] r2378 - trunk/widgets
svn_fusion at osgeo.org
Thu May 5 15:24:04 EDT 2011
Author: madair
Date: 2011-05-05 12:24:04 -0700 (Thu, 05 May 2011)
New Revision: 2378
trunk/widgets/SelectRadius.js
re #446: combine up/done event handlers so only one is called on a single click
Modified: trunk/widgets/SelectRadius.js
--- trunk/widgets/SelectRadius.js 2011-05-05 15:34:56 UTC (rev 2377)
+++ trunk/widgets/SelectRadius.js 2011-05-05 19:24:04 UTC (rev 2378)
@@ -87,8 +87,7 @@
interval: 100,
done: this.execute,
down: this.mouseDown,
- move: this.mouseMove,
- up: this.mouseUp
+ move: this.mouseMove
}, this.handlerOptions);
mapWidget.handlers.push(this.handler);
@@ -195,17 +194,6 @@
- mouseUp: function(geom) {
- if (this.radiusTip && this.radiusTipType == 'dynamic') {
- this.radiusTip.style.display = 'none';
- this.radiusTip.innerHTML = '';
- if (this.handler.start == this.handler.last) {
- this.handler.clear();
- this.execute(geom);
* set the extants of the map based on the pixel coordinates
* passed
@@ -214,6 +202,14 @@
* @param radius
execute: function(geom) {
+ if (this.radiusTip && this.radiusTipType == 'dynamic') {
+ this.radiusTip.style.display = 'none';
+ this.radiusTip.innerHTML = '';
+ if (this.handler.start == this.handler.last) {
+ this.handler.clear();
var options = {};
options.geometry = geom.toString();
options.selectionType = this.selectionType;
More information about the fusion-commits
