[fusion-commits] r2379 - trunk/widgets
svn_fusion at osgeo.org
Wed May 11 14:15:38 EDT 2011
Author: madair
Date: 2011-05-11 11:15:37 -0700 (Wed, 11 May 2011)
New Revision: 2379
trunk/widgets/MapMenu.js
allow listing of either published or not published maps
Modified: trunk/widgets/MapMenu.js
--- trunk/widgets/MapMenu.js 2011-05-05 19:24:04 UTC (rev 2378)
+++ trunk/widgets/MapMenu.js 2011-05-11 18:15:37 UTC (rev 2379)
@@ -49,10 +49,18 @@
this.rootFolder = this.extension.Folder ? this.extension.Folder[0] : '/';
//var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + '/MapMenu.' + Fusion.getScriptLanguage();
this.requestURL = this.extension.ListURL ? this.extension.ListURL[0] : '/platform/api/mapsherpa.php';
+ this.publishedMapsOnly = this.extension.PublishedMapsOnly ? this.extension.PublishedMapsOnly : false;
+ if(this.publishedMapsOnly){
+ this.platformRequest = 'listpublishedmaps';
+ else
+ this.platformRequest = 'listresources';
this.loadOverlaysOnly = (this.extension.LoadOverlaysOnly && this.extension.LoadOverlaysOnly[0] == 'true') ? true:false;
- this.getMapLayer().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.loadMenu, this));
+ this.getMapLayer().registerForEvent(Fusion.Event.MAP_SESSION_CREATED, OpenLayers.Function.bind(this.loadMenu, this));
this.enable();
@@ -88,8 +96,8 @@
loadMenu: function() {
- console.log("LOADMENU");
- debugger;
+ //console.log("LOADMENU");
+ //debugger;
//get the mapdefinitions as xml if there is a folder specified
//in the widget tag. All subfolders will be enumerated.
@@ -105,7 +113,7 @@
var map = this.getMapLayer();
var options = {
parameters: {
- request: 'listresources',
+ request: this.platformRequest,
type: 'map',
session: map.getSessionID(),
depth: -1,
@@ -131,7 +139,7 @@
//eval("o="+testData);
this.menus = {};
this.uiObj.empty();
- if (o.values) {
+ if (o.values && o.values.resources) {
var list = o.values.resources;
var widgetLayer = this.getMapLayer();
for (var i=0; i<list.length; i++) {
More information about the fusion-commits
