[fusion-commits] r2380 - in trunk: layers/MapServer widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu May 12 15:54:21 EDT 2011
Author: madair
Date: 2011-05-12 12:54:21 -0700 (Thu, 12 May 2011)
New Revision: 2380
   trunk/layers/MapServer/MapServer.js
   trunk/widgets/MapMetadata.js
re #447: adding support for Layer metadata
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2011-05-11 18:15:37 UTC (rev 2379)
+++ trunk/layers/MapServer/MapServer.js	2011-05-12 19:54:21 UTC (rev 2380)
@@ -272,7 +272,6 @@
             this.layerRoot.displayInLegend = true;
             this.layerRoot.expandInLegend = true;
-            o.groups.sort(function(a,b) {return a.depth-b.depth} );
             this.parseMapLayersAndGroups(o);
             var minScale = 1.0e10;
@@ -479,6 +478,9 @@
     parseMapLayersAndGroups: function(o) {
+        //sort the groups so that root folders are created before subfolders
+        o.groups.sort(function(a,b) {return a.depth-b.depth} );
         for (var i=0; i<o.groups.length; i++) {
             var group = new Fusion.Layers.Group(o.groups[i], this);
             var parent;
@@ -833,12 +835,33 @@
         Fusion.ajaxRequest(s, params);
-    getMetadata: function(key) {
+    getMetadata: function(key, layerName) {
+      if (layerName) {
+        var layer = this.getLayerByName(layerName);
+        if (layer.metadata && typeof layer.metadata[key] != 'undefined') {
+          return layer.metadata[key];
+        } else {
+          return '';
+      } else {
         if (this.metadata && typeof this.metadata[key] != 'undefined') {
             return this.metadata[key];
         } else {
-            return '';
+          //TODO: a better way to create the layer metadata string?
+            var metadataString = ''
+            var join = "";
+            for (var i=0; i<this.aLayers.length; i++) {
+              if (this.aLayers[i].metadata &&
+                  typeof this.aLayers[i].metadata[key] != 'undefined' &&
+                  this.aLayers[i].metadata[key].length>0 ) {
+                metadataString += join + this.aLayers[i].legendLabel + ":" + this.aLayers[i].metadata[key] ;
+                join = " - ";
+            return metadataString;
     getGroupInfoUrl: function(groupName) {
Modified: trunk/widgets/MapMetadata.js
--- trunk/widgets/MapMetadata.js	2011-05-11 18:15:37 UTC (rev 2379)
+++ trunk/widgets/MapMetadata.js	2011-05-12 19:54:21 UTC (rev 2380)
@@ -33,6 +33,7 @@
 Fusion.Widget.MapMetadata = OpenLayers.Class(Fusion.Widget, {
     content: 'text',
+    layerName: null,
  * Constructor: MapMetadata
@@ -52,6 +53,9 @@
         if (json.Content) {
           this.content = json.Content[0];
+        if (json.LayerName) {
+          this.layerName = json.LayerName[0];
         this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.showMetadata, this));
@@ -63,7 +67,7 @@
     showMetadata: function() {
       var metadataLayer = this.getMapLayer();
-      var metadata = metadataLayer.getMetadata(this.metadataId);
+      var metadata = metadataLayer.getMetadata(this.metadataId, this.layerName);
       if (metadata) {
         //this.domObj.appendChild(metadata);
         if (this.content == 'markup') {
More information about the fusion-commits mailing list
