[fusion-commits] r2381 - trunk/lib
svn_fusion at osgeo.org
Fri May 13 13:52:04 EDT 2011
Author: madair
Date: 2011-05-13 10:52:04 -0700 (Fri, 13 May 2011)
New Revision: 2381
trunk/lib/fusion.js
re #448: load all scripts through document.write()
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2011-05-12 19:54:21 UTC (rev 2380)
+++ trunk/lib/fusion.js 2011-05-13 17:52:04 UTC (rev 2381)
@@ -1397,27 +1397,12 @@
coreScripts.push('text/'+locale+'.json');
- var agent = navigator.userAgent;
- var docWrite = (agent.match("MSIE") || agent.match("Safari"));
- if (docWrite) {
- var allScriptTags = new Array(coreScripts.length);
+ var allScriptTags = new Array(coreScripts.length);
for (var i = 0; i < coreScripts.length; i++) {
- if (docWrite) {
- allScriptTags[i] = "<script src='" + host + coreScripts[i] +
+ allScriptTags[i] = "<script src='" + host + coreScripts[i] +
"'></script>";
- } else {
- var s = document.createElement("script");
- s.src = host + coreScripts[i];
- var h = document.getElementsByTagName("head").length ?
- document.getElementsByTagName("head")[0] :
- document.body;
- h.appendChild(s);
- if (docWrite) {
- document.write(allScriptTags.join(""));
+ document.write(allScriptTags.join(""));
More information about the fusion-commits
