[fusion-commits] r2564 - trunk/widgets/QuickPlot
svn_fusion at osgeo.org
Wed Aug 1 23:10:32 PDT 2012
Author: liuar
Date: 2012-08-01 23:10:32 -0700 (Wed, 01 Aug 2012)
New Revision: 2564
trunk/widgets/QuickPlot/PlotAsPDF.php
On behalf of Ted Yang.
fix the ticket 2075: http://trac.osgeo.org/mapguide/ticket/2075
The submission is mainly implement the RFC 124:http://trac.osgeo.org/mapguide/wiki/MapGuideRfc124
part 5:
fix a defect which will cause the Linux won't work. the $_SERVER["HTTP_HOST"] will return the server name or ip with the port. use the $_SERVER["SERVER_NAME"]
Modified: trunk/widgets/QuickPlot/PlotAsPDF.php
--- trunk/widgets/QuickPlot/PlotAsPDF.php 2012-08-02 05:47:45 UTC (rev 2563)
+++ trunk/widgets/QuickPlot/PlotAsPDF.php 2012-08-02 06:10:32 UTC (rev 2564)
@@ -2,7 +2,7 @@
require_once("../../lib/tcpdf/config/lang/eng.php");
require_once("../../lib/tcpdf/tcpdf.php");
- $host = $_SERVER["HTTP_HOST"];
+ $host = $_SERVER["SERVER_NAME"];
$protocol = (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] != "off") ? "https://" : "http://";
$path = $_SERVER["PHP_SELF"];
$port = $_SERVER["SERVER_PORT"];
More information about the fusion-commits
