[fusion-commits] r2537 - trunk/widgets/Theme/classes
svn_fusion at osgeo.org
Sun May 20 23:23:01 PDT 2012
Author: liuar
Date: 2012-05-20 23:23:01 -0700 (Sun, 20 May 2012)
New Revision: 2537
trunk/widgets/Theme/classes/theme.php
Submit on behalf of Spark Liu: Fix ticket #524 - "Individual" theme doesn't work for provider not supporting distinct
If provider doesn't support distinct, "Individual theme" will not work for the layer depending on it. This is because it uses distinct function. The solution is using calculation function UNIQUE to work around this.
Modified: trunk/widgets/Theme/classes/theme.php
--- trunk/widgets/Theme/classes/theme.php 2012-05-03 10:17:07 UTC (rev 2536)
+++ trunk/widgets/Theme/classes/theme.php 2012-05-21 06:23:01 UTC (rev 2537)
@@ -312,14 +312,13 @@
$values = array();
- $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
- $aggregateOptions->SelectDistinct(true);
+ $aggregateOptions->AddComputedProperty('THEME_VALUE', 'UNIQUE("' . $this->args['PROPERTYNAME'] . '")');
if($filter != '')
$aggregateOptions->SetFilter($filter);
- $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
+ $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
while ($dataReader->ReadNext())
- $value = $this->GetFeaturePropertyValue($dataReader, $this->args['PROPERTYNAME']);
+ $value = $this->GetFeaturePropertyValue($dataReader, 'THEME_VALUE');
array_push($values, $value);
$dataReader->Close();
More information about the fusion-commits
