[fusion-commits] r2538 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Wed May 30 01:52:09 PDT 2012
Author: liuar
Date: 2012-05-30 01:52:09 -0700 (Wed, 30 May 2012)
New Revision: 2538
trunk/layers/MapGuide/MapGuide.js
on behalf of yangte
http://trac.osgeo.org/fusion/ticket/525
Fix the defect about Fusion base map layer group visibility
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2012-05-21 06:23:01 UTC (rev 2537)
+++ trunk/layers/MapGuide/MapGuide.js 2012-05-30 08:52:09 UTC (rev 2538)
@@ -407,6 +407,19 @@
this.oLayerOL2.setVisibility(true);
+ //Fix Defect: the Base Layer Group should be invisiable when the "initially visiable in map" is set to false
+ var i = 0;
+ var j = 0;
+ for(i = 0;i < this.layerRoot.groups.length; i++){
+ if(this.layerRoot.groups[i].isBaseMapGroup && !this.layerRoot.groups[i].initiallyVisible){
+ for(j = 0; j<this.oLayersOLTile.length; j++) {
+ if(this.oLayersOLTile[j].params.basemaplayergroupname === this.layerRoot.groups[i].name) {
+ this.oLayersOLTile[j].setVisibility(false);
this.mapWidget._removeWorker();
this.triggerEvent(Fusion.Event.LAYER_LOADED);
More information about the fusion-commits
