[fusion-commits] r2622 - trunk/layers/MapGuide/php
svn_fusion at osgeo.org
Thu Oct 25 18:25:46 PDT 2012
Author: liuar
Date: 2012-10-25 18:25:46 -0700 (Thu, 25 Oct 2012)
New Revision: 2622
trunk/layers/MapGuide/php/GetSelectionProperties.php
Submit on behalf of Andy Zhang: integrate 2559
Modified: trunk/layers/MapGuide/php/GetSelectionProperties.php
--- trunk/layers/MapGuide/php/GetSelectionProperties.php 2012-10-22 08:14:33 UTC (rev 2621)
+++ trunk/layers/MapGuide/php/GetSelectionProperties.php 2012-10-26 01:25:46 UTC (rev 2622)
@@ -80,17 +80,19 @@
//could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
//the one causing a problem when the properies are limited ?
if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
- $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
- if (0 && count($mappings) > 0) {
+ $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
+ if (count($mappings) > 0) {
foreach($mappings as $name => $value) {
$queryOptions->AddFeatureProperty($name);
//echo "$name $value <br>\n";
- $geomName = $oLayer->GetFeatureGeometryName();
- $queryOptions->AddFeatureProperty($geomName);
+ //Add geometry property in all cases.
+ $geomName = $oLayer->GetFeatureGeometryName();
+ $queryOptions->AddFeatureProperty($geomName);
$filter = $selection->GenerateFilter($oLayer, $class);
$queryOptions->SetFilter($filter);
$featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
More information about the fusion-commits
