[fusion-commits] r2623 - sandbox/adsk/2.3r/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Sun Oct 28 23:36:12 PDT 2012
Author: liuar
Date: 2012-10-28 23:36:11 -0700 (Sun, 28 Oct 2012)
New Revision: 2623
   sandbox/adsk/2.3r/lib/proj4js-combined.js
   sandbox/adsk/2.3r/lib/proj4js-compressed.js
Submit on behalf of Spark Liu: Fix problem that Google CS doesn't fix with most popular CS.
Google's datum use same value for a and b, which doesn't fit with most other CS. So it always has problem to show Google Map as a background.
To fix this, we temporarily set the b to be compatible with other CS.
Modified: sandbox/adsk/2.3r/lib/proj4js-combined.js
--- sandbox/adsk/2.3r/lib/proj4js-combined.js	2012-10-26 01:25:46 UTC (rev 2622)
+++ sandbox/adsk/2.3r/lib/proj4js-combined.js	2012-10-29 06:36:11 UTC (rev 2623)
@@ -2710,7 +2710,7 @@
     defs/GOOGLE.js
-Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
+Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6356752.31424518 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
 Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];
     projCode/gstmerc.js
Modified: sandbox/adsk/2.3r/lib/proj4js-compressed.js
--- sandbox/adsk/2.3r/lib/proj4js-compressed.js	2012-10-26 01:25:46 UTC (rev 2622)
+++ sandbox/adsk/2.3r/lib/proj4js-compressed.js	2012-10-29 06:36:11 UTC (rev 2623)
@@ -140,7 +140,7 @@
 p.x=x;p.y=y;return p;},inverse:function(p){var con,phi;var delta_phi;var i;var max_iter=6;var lat,lon;if(this.sphere){var f=Math.exp(p.x/(this.a*this.k0));var g=.5*(f-1/f);var temp=this.lat0+p.y/(this.a*this.k0);var h=Math.cos(temp);con=Math.sqrt((1.0-h*h)/(1.0+g*g));lat=Proj4js.common.asinz(con);if(temp<0)
 lat=-lat;if((g==0)&&(h==0)){lon=this.long0;}else{lon=Proj4js.common.adjust_lon(Math.atan2(g,h)+this.long0);}}else{var x=p.x-this.x0;var y=p.y-this.y0;con=(this.ml0+y/this.k0)/this.a;phi=con;for(i=0;true;i++){delta_phi=((con+this.e1*Math.sin(2.0*phi)-this.e2*Math.sin(4.0*phi)+this.e3*Math.sin(6.0*phi))/this.e0)-phi;phi+=delta_phi;if(Math.abs(delta_phi)<=Proj4js.common.EPSLN)break;if(i>=max_iter){Proj4js.reportError("tmerc:inverse: Latitude failed to converge");return(95);}}
 if(Math.abs(phi)<Proj4js.common.HALF_PI){var sin_phi=Math.sin(phi);var cos_phi=Math.cos(phi);var tan_phi=Math.tan(phi);var c=this.ep2*Math.pow(cos_phi,2);var cs=Math.pow(c,2);var t=Math.pow(tan_phi,2);var ts=Math.pow(t,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var r=n*(1.0-this.es)/con;var d=x/(n*this.k0);var ds=Math.pow(d,2);lat=phi-(n*tan_phi*ds/r)*(0.5-ds/24.0*(5.0+3.0*t+10.0*c-4.0*cs-9.0*this.ep2-ds/30.0*(61.0+90.0*t+298.0*c+45.0*ts-252.0*this.ep2-3.0*cs)));lon=Proj4js.common.adjust_lon(this.long0+(d*(1.0-ds/6.0*(1.0+2.0*t+c-ds/20.0*(5.0-2.0*c+28.0*t-3.0*cs+8.0*this.ep2+24.0*ts)))/cos_phi));}else{lat=Proj4js.common.HALF_PI*Proj4js.common.sign(y);lon=this.long0;}}
-p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.common.cosh(
 Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.sin(dlon);
 var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
+p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6356752.31424518 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.com
 mon.cosh(Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.s
 in(dlon);var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
 p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinz,cosz;var temp;var con;var lon,lat;p.x-=this.x0;p.y-=this.y0;rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>this.a+.0000001){Proj4js.reportError("orthoInvDataError");}
 z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosz=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
 lat=Proj4js.common.asinz(cosz*this.sin_p14+(p.y*sinz*this.cos_p14)/rh);con=Math.abs(this.lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
More information about the fusion-commits mailing list
