[fusion-commits] r2580 - in trunk: . docs_config
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Sep 7 04:04:46 PDT 2012
Author: jng
Date: 2012-09-07 04:04:46 -0700 (Fri, 07 Sep 2012)
New Revision: 2580
   trunk/build.xml
   trunk/docs_config/
   trunk/docs_config/Menu.txt
#540: The reason NaturalDocs completely trashes our Menu.txt file on each build is because the file paths it's looking for doesn't match. So what we do instead is use a %WORKING_COPY% placeholder for the paths in Menu.txt, which we replace with the actual working copy path via a replace ant task. This is done before NaturalDocs is executed
Modified: trunk/build.xml
--- trunk/build.xml	2012-09-07 09:20:12 UTC (rev 2579)
+++ trunk/build.xml	2012-09-07 11:04:46 UTC (rev 2580)
@@ -147,9 +147,13 @@
     <mkdir dir="${build.home}/docs"/>
     <mkdir dir="${build.home}/docs/NaturalDocs"/>
+    <!-- Dirty hack to avoid NaturalDoc's penchant for completely disregarding our Menu.txt -->
+    <echo message="Prepareing Menu.txt" />
+    <replace file="${basedir}/docs_config/Menu.txt" token="%WORKING_COPY%" value="${basedir}" />
     <echo message="Generating documentation"/>
     <exec executable="cmd" os="Windows Vista, Windows XP, Windows 7" dir="${basedir}/utils/NaturalDocs-1.4">
-        <arg line="/c NaturalDocs -i ${build.home}/lib -i ${build.home}/widgets -xi ${build.home}/lib/OpenLayers/Lang -o html ${build.home}/docs/NaturalDocs -p ${basedir}/docs_config -ro" />
+        <arg line="/c NaturalDocs -i ${build.home}/lib -i ${build.home}/widgets -xi ${build.home}/lib/OpenLayers/Lang -o html ${build.home}/docs/NaturalDocs -p ${basedir}/docs_config -nag -r" />
     </exec>
   </target>
Property changes on: trunk/docs_config
___________________________________________________________________
Added: svn:ignore
   + Data
Modified: trunk/docs_config/Menu.txt
--- trunk/docs_config/Menu.txt	2012-09-07 09:20:12 UTC (rev 2579)
+++ trunk/docs_config/Menu.txt	2012-09-07 11:04:46 UTC (rev 2580)
@@ -1,4 +1,4 @@
-Format: 1.4
+Format: 1.52
 Title: Fusion
@@ -51,87 +51,87 @@
 Group: Core  {
-   File: Fusion  (C:\Workspace\fusion-trunk\build\lib\fusion.js)
-   File: Fusion.Error  (C:\Workspace\fusion-trunk\build\lib\Error.js)
-   File: Fusion.Lib.ApplicationDefinition  (C:\Workspace\fusion-trunk\build\lib\ApplicationDefinition.js)
-   File: Fusion.Lib.EventMgr  (C:\Workspace\fusion-trunk\build\lib\EventMgr.js)
-   File: Fusion.Lib.MGBroker  (C:\Workspace\fusion-trunk\build\lib\MGBroker.js)
-   File: Fusion.MapMessage  (C:\Workspace\fusion-trunk\build\lib\MapMessage.js)
-   File: Fusion.Tool.Rectangle  (C:\Workspace\fusion-trunk\build\lib\RectTool.js)
-   File: Fusion.Tool.Search  (C:\Workspace\fusion-trunk\build\lib\Search.js)
-   File: Fusion.Widget  (C:\Workspace\fusion-trunk\build\lib\Widget.js)
-   File: Fusion.Widget.Map  (no auto-title, C:\Workspace\fusion-trunk\build\lib\Map.js)
+   File: Fusion  (%WORKING_COPY%\build\lib\fusion.js)
+   File: Fusion.Error  (%WORKING_COPY%\build\lib\Error.js)
+   File: Fusion.Lib.ApplicationDefinition  (%WORKING_COPY%\build\lib\ApplicationDefinition.js)
+   File: Fusion.Lib.EventMgr  (%WORKING_COPY%\build\lib\EventMgr.js)
+   File: Fusion.Lib.MGBroker  (%WORKING_COPY%\build\lib\MGBroker.js)
+   File: Fusion.MapMessage  (%WORKING_COPY%\build\lib\MapMessage.js)
+   File: Fusion.Tool.Rectangle  (%WORKING_COPY%\build\lib\RectTool.js)
+   File: Fusion.Tool.Search  (%WORKING_COPY%\build\lib\Search.js)
+   File: Fusion.Widget  (%WORKING_COPY%\build\lib\Widget.js)
+   File: Fusion.Widget.map  (no auto-title, %WORKING_COPY%\build\lib\Map.js)
    }  # Group: Core
 Group: External  {
-   File: jxLib  (no auto-title, C:\Workspace\fusion-trunk\build\lib\jxLib\jxlib.uncompressed.js)
-   File: OpenLayers  (no auto-title, C:\Workspace\fusion-trunk\build\lib\OpenLayers\OpenLayers.js)
-   File: Proj4js  (C:\Workspace\fusion-trunk\build\lib\Proj4js\proj4js-combined.js)
-   File: isValidLonLat  (C:\Workspace\fusion-trunk\build\lib\OLpatch.js)
-   File: OpenLayers.Control.DragFeature  (C:\Workspace\fusion-trunk\build\lib\DragFeature.js)
+   File: isValidLonLat  (%WORKING_COPY%\build\lib\OLpatch.js)
+   File: JxLib  (no auto-title, %WORKING_COPY%\build\lib\jxLib\jxlib.uncompressed.js)
+   File: OpenLayers.Control.DragFeature  (%WORKING_COPY%\build\lib\DragFeature.js)
+   File: OpenLayers\OpenLayers.js  (%WORKING_COPY%\build\lib\OpenLayers\OpenLayers.js)
+   File: Proj4js  (%WORKING_COPY%\build\lib\Proj4js\proj4js-combined.js)
    }  # Group: External
 Group: Widgets  {
-   File: Fusion.Widget.About  (C:\Workspace\fusion-trunk\build\widgets\About.js)
-   File: Fusion.Widget.ActivityIndicator  (C:\Workspace\fusion-trunk\build\widgets\ActivityIndicator.js)
-   File: Fusion.Widget.AddWMSLayer  (C:\Workspace\fusion-trunk\build\widgets\AddWMSLayer.js)
-   File: Fusion.Widget.BasemapSwitcher  (C:\Workspace\fusion-trunk\build\widgets\BasemapSwitcher.js)
-   File: Fusion.Widget.Buffer  (C:\Workspace\fusion-trunk\build\widgets\Buffer.js)
-   File: Fusion.Widget.BufferPanel  (C:\Workspace\fusion-trunk\build\widgets\BufferPanel.js)
-   File: Fusion.Widget.CenterSelection  (C:\Workspace\fusion-trunk\build\widgets\CenterSelection.js)
-   File: Fusion.Widget.ClearSelection  (C:\Workspace\fusion-trunk\build\widgets\ClearSelection.js)
-   File: Fusion.Widget.ColorPicker  (C:\Workspace\fusion-trunk\build\widgets\ColorPicker.js)
-   File: Fusion.Widget.CursorPosition  (C:\Workspace\fusion-trunk\build\widgets\CursorPosition.js)
-   File: Fusion.Widget.EditableScale  (C:\Workspace\fusion-trunk\build\widgets\EditableScale.js)
-   File: Fusion.Widget.ExtentHistory  (C:\Workspace\fusion-trunk\build\widgets\ExtentHistory.js)
-   File: Fusion.Widget.FeatureInfo  (C:\Workspace\fusion-trunk\build\widgets\FeatureInfo.js)
-   File: Fusion.Widget.GetFeatureInfo  (C:\Workspace\fusion-trunk\build\widgets\GetFeatureInfo.js)
-   File: Fusion.Widget.GoogleStreetViewer  (C:\Workspace\fusion-trunk\build\widgets\GoogleStreetViewer.js)
-   File: Fusion.Widget.Help  (C:\Workspace\fusion-trunk\build\widgets\Help.js)
-   File: Fusion.Widget.InitialMapView  (C:\Workspace\fusion-trunk\build\widgets\InitialMapView.js)
-   File: Fusion.Widget.InvokeScript  (C:\Workspace\fusion-trunk\build\widgets\InvokeScript.js)
-   File: Fusion.Widget.InvokeURL  (C:\Workspace\fusion-trunk\build\widgets\InvokeURL.js)
-   File: Fusion.Widget.LayerManager  (C:\Workspace\fusion-trunk\build\widgets\LayerManager.js)
-   File: Fusion.Widget.Legend  (C:\Workspace\fusion-trunk\build\widgets\Legend.js)
-   File: Fusion.Widget.LinkToView  (C:\Workspace\fusion-trunk\build\widgets\LinkToView.js)
-   File: Fusion.Widget.MapMenu  (C:\Workspace\fusion-trunk\build\widgets\MapMenu.js)
-   File: Fusion.Widget.MapMetadata  (C:\Workspace\fusion-trunk\build\widgets\MapMetadata.js)
-   File: Fusion.Widget.Maptip  (C:\Workspace\fusion-trunk\build\widgets\Maptip.js)
-   File: Fusion.Widget.Measure  (C:\Workspace\fusion-trunk\build\widgets\Measure.js)
-   File: Fusion.Widget.Navigator  (C:\Workspace\fusion-trunk\build\widgets\Navigator.js)
-   File: Fusion.Widget.OverviewMap  (C:\Workspace\fusion-trunk\build\widgets\OverviewMap.js)
-   File: Fusion.Widget.Pan  (C:\Workspace\fusion-trunk\build\widgets\Pan.js)
-   File: Fusion.Widget.PanOnClick  (C:\Workspace\fusion-trunk\build\widgets\PanOnClick.js)
-   File: Fusion.Widget.PanQuery  (C:\Workspace\fusion-trunk\build\widgets\PanQuery.js)
-   File: Fusion.Widget.Print  (C:\Workspace\fusion-trunk\build\widgets\Print.js)
-   File: Fusion.Widget.Query  (C:\Workspace\fusion-trunk\build\widgets\Query.js)
-   File: Fusion.Widget.QuickPlot  (C:\Workspace\fusion-trunk\build\widgets\QuickPlot.js)
-   File: Fusion.Widget.Redline  (C:\Workspace\fusion-trunk\build\widgets\Redline.js)
-   File: Fusion.Widget.RefreshMap  (C:\Workspace\fusion-trunk\build\widgets\RefreshMap.js)
-   File: Fusion.Widget.SaveMap  (C:\Workspace\fusion-trunk\build\widgets\SaveMap.js)
-   File: Fusion.Widget.SaveMapImage  (C:\Workspace\fusion-trunk\build\widgets\SaveMapImage.js)
-   File: Fusion.Widget.SaveSession  (C:\Workspace\fusion-trunk\build\widgets\SaveSession.js)
-   File: Fusion.Widget.Scalebar  (C:\Workspace\fusion-trunk\build\widgets\Scalebar.js)
-   File: Fusion.Widget.ScalebarDual  (C:\Workspace\fusion-trunk\build\widgets\ScalebarDual.js)
-   File: Fusion.Widget.Search  (C:\Workspace\fusion-trunk\build\widgets\Search.js)
-   File: Fusion.Widget.Select  (C:\Workspace\fusion-trunk\build\widgets\Select.js)
-   File: Fusion.Widget.SelectionInfo  (C:\Workspace\fusion-trunk\build\widgets\SelectionInfo.js)
-   File: Fusion.Widget.SelectionPanel  (C:\Workspace\fusion-trunk\build\widgets\SelectionPanel.js)
-   File: Fusion.Widget.SelectPolygon  (C:\Workspace\fusion-trunk\build\widgets\SelectPolygon.js)
-   File: Fusion.Widget.SelectRadius  (C:\Workspace\fusion-trunk\build\widgets\SelectRadius.js)
-   File: Fusion.Widget.SelectRadius  (C:\Workspace\fusion-trunk\build\widgets\SelectAttribute.js)
-   File: Fusion.Widget.SelectRadiusValue  (C:\Workspace\fusion-trunk\build\widgets\SelectRadiusValue.js)
-   File: Fusion.Widget.SelectWithin  (C:\Workspace\fusion-trunk\build\widgets\SelectWithin.js)
-   File: Fusion.Widget.TaskPane  (C:\Workspace\fusion-trunk\build\widgets\TaskPane.js)
-   File: Fusion.Widget.Theme  (C:\Workspace\fusion-trunk\build\widgets\Theme.js)
-   File: Fusion.Widget.ViewOptions  (C:\Workspace\fusion-trunk\build\widgets\ViewOptions.js)
-   File: Fusion.Widget.ViewSize  (C:\Workspace\fusion-trunk\build\widgets\ViewSize.js)
-   File: Fusion.Widget.Zoom  (C:\Workspace\fusion-trunk\build\widgets\Zoom.js)
-   File: Fusion.Widget.ZoomOnClick  (C:\Workspace\fusion-trunk\build\widgets\ZoomOnClick.js)
-   File: Fusion.Widget.ZoomToSelection  (C:\Workspace\fusion-trunk\build\widgets\ZoomToSelection.js)
-   File: OpenLayers.Control.MapCapturer  (C:\Workspace\fusion-trunk\build\widgets\QuickPlot\MapCapturer.js)
+   File: Fusion.Widget.About  (%WORKING_COPY%\build\widgets\About.js)
+   File: Fusion.Widget.ActivityIndicator  (%WORKING_COPY%\build\widgets\ActivityIndicator.js)
+   File: Fusion.Widget.AddWMSLayer  (%WORKING_COPY%\build\widgets\AddWMSLayer.js)
+   File: Fusion.Widget.BasemapSwitcher  (%WORKING_COPY%\build\widgets\BasemapSwitcher.js)
+   File: Fusion.Widget.Buffer  (%WORKING_COPY%\build\widgets\Buffer.js)
+   File: Fusion.Widget.BufferPanel  (%WORKING_COPY%\build\widgets\BufferPanel.js)
+   File: Fusion.Widget.CenterSelection  (%WORKING_COPY%\build\widgets\CenterSelection.js)
+   File: Fusion.Widget.ClearSelection  (%WORKING_COPY%\build\widgets\ClearSelection.js)
+   File: Fusion.Widget.ColorPicker  (%WORKING_COPY%\build\widgets\ColorPicker.js)
+   File: Fusion.Widget.CursorPosition  (%WORKING_COPY%\build\widgets\CursorPosition.js)
+   File: Fusion.Widget.EditableScale  (%WORKING_COPY%\build\widgets\EditableScale.js)
+   File: Fusion.Widget.ExtentHistory  (%WORKING_COPY%\build\widgets\ExtentHistory.js)
+   File: Fusion.Widget.FeatureInfo  (%WORKING_COPY%\build\widgets\FeatureInfo.js)
+   File: Fusion.Widget.GetFeatureInfo  (%WORKING_COPY%\build\widgets\GetFeatureInfo.js)
+   File: Fusion.Widget.GoogleStreetViewer  (%WORKING_COPY%\build\widgets\GoogleStreetViewer.js)
+   File: Fusion.Widget.Help  (%WORKING_COPY%\build\widgets\Help.js)
+   File: Fusion.Widget.InitialMapView  (%WORKING_COPY%\build\widgets\InitialMapView.js)
+   File: Fusion.Widget.InvokeScript  (%WORKING_COPY%\build\widgets\InvokeScript.js)
+   File: Fusion.Widget.InvokeURL  (%WORKING_COPY%\build\widgets\InvokeURL.js)
+   File: Fusion.Widget.LayerManager  (%WORKING_COPY%\build\widgets\LayerManager.js)
+   File: Fusion.Widget.Legend  (%WORKING_COPY%\build\widgets\Legend.js)
+   File: Fusion.Widget.LinkToView  (%WORKING_COPY%\build\widgets\LinkToView.js)
+   File: Fusion.Widget.MapMenu  (%WORKING_COPY%\build\widgets\MapMenu.js)
+   File: Fusion.Widget.MapMetadata  (%WORKING_COPY%\build\widgets\MapMetadata.js)
+   File: Fusion.Widget.Maptip  (%WORKING_COPY%\build\widgets\Maptip.js)
+   File: Fusion.Widget.Measure  (%WORKING_COPY%\build\widgets\Measure.js)
+   File: Fusion.Widget.Navigator  (%WORKING_COPY%\build\widgets\Navigator.js)
+   File: Fusion.Widget.OverviewMap  (%WORKING_COPY%\build\widgets\OverviewMap.js)
+   File: Fusion.Widget.Pan  (%WORKING_COPY%\build\widgets\Pan.js)
+   File: Fusion.Widget.PanOnClick  (%WORKING_COPY%\build\widgets\PanOnClick.js)
+   File: Fusion.Widget.PanQuery  (%WORKING_COPY%\build\widgets\PanQuery.js)
+   File: Fusion.Widget.Print  (%WORKING_COPY%\build\widgets\Print.js)
+   File: Fusion.Widget.Query  (%WORKING_COPY%\build\widgets\Query.js)
+   File: Fusion.Widget.QuickPlot  (%WORKING_COPY%\build\widgets\QuickPlot.js)
+   File: Fusion.Widget.Redline  (%WORKING_COPY%\build\widgets\Redline.js)
+   File: Fusion.Widget.RefreshMap  (%WORKING_COPY%\build\widgets\RefreshMap.js)
+   File: Fusion.Widget.SaveMap  (%WORKING_COPY%\build\widgets\SaveMap.js)
+   File: Fusion.Widget.SaveMapImage  (%WORKING_COPY%\build\widgets\SaveMapImage.js)
+   File: Fusion.Widget.SaveSession  (%WORKING_COPY%\build\widgets\SaveSession.js)
+   File: Fusion.Widget.Scalebar  (%WORKING_COPY%\build\widgets\Scalebar.js)
+   File: Fusion.Widget.ScalebarDual  (%WORKING_COPY%\build\widgets\ScalebarDual.js)
+   File: Fusion.Widget.Search  (%WORKING_COPY%\build\widgets\Search.js)
+   File: Fusion.Widget.Select  (%WORKING_COPY%\build\widgets\Select.js)
+   File: Fusion.Widget.SelectionInfo  (%WORKING_COPY%\build\widgets\SelectionInfo.js)
+   File: Fusion.Widget.SelectionPanel  (%WORKING_COPY%\build\widgets\SelectionPanel.js)
+   File: Fusion.Widget.SelectPolygon  (%WORKING_COPY%\build\widgets\SelectPolygon.js)
+   File: Fusion.Widget.SelectRadius  (%WORKING_COPY%\build\widgets\SelectAttribute.js)
+   File: Fusion.Widget.SelectRadius  (%WORKING_COPY%\build\widgets\SelectRadius.js)
+   File: Fusion.Widget.SelectRadiusValue  (%WORKING_COPY%\build\widgets\SelectRadiusValue.js)
+   File: Fusion.Widget.SelectWithin  (%WORKING_COPY%\build\widgets\SelectWithin.js)
+   File: Fusion.Widget.TaskPane  (%WORKING_COPY%\build\widgets\TaskPane.js)
+   File: Fusion.Widget.Theme  (%WORKING_COPY%\build\widgets\Theme.js)
+   File: Fusion.Widget.ViewOptions  (%WORKING_COPY%\build\widgets\ViewOptions.js)
+   File: Fusion.Widget.ViewSize  (%WORKING_COPY%\build\widgets\ViewSize.js)
+   File: Fusion.Widget.Zoom  (%WORKING_COPY%\build\widgets\Zoom.js)
+   File: Fusion.Widget.ZoomOnClick  (%WORKING_COPY%\build\widgets\ZoomOnClick.js)
+   File: Fusion.Widget.ZoomToSelection  (%WORKING_COPY%\build\widgets\ZoomToSelection.js)
+   File: OpenLayers.Control.MapCapturer  (%WORKING_COPY%\build\widgets\QuickPlot\MapCapturer.js)
    }  # Group: Widgets
 Group: Index  {
@@ -148,5 +148,5 @@
 ##### Do not change or remove these lines. #####
-Data: 1(D3330wb_uHA6Ip9GbcN68u\ztHN\AbYN8ofbo8Y)
-Data: 1(h3330wb_uHA6Ip9GbcN68u\ztHN\AbYN8ofb78f`Gt6)
+Data: 1(D3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofbo8Y)
+Data: 1(h3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofb78f`Gt6)
More information about the fusion-commits mailing list
