[fusion-commits] r2581 - in trunk: docs_config lib
svn_fusion at osgeo.org
Fri Sep 7 04:17:30 PDT 2012
Author: jng
Date: 2012-09-07 04:17:29 -0700 (Fri, 07 Sep 2012)
New Revision: 2581
trunk/docs_config/Menu.txt
trunk/lib/fusion.js
#540: Menu re-organization, and remove docs for empty namespaces (not actually empty as the contents are defined in other files, but NaturalDocs thinks they are, so why try and fight it?)
Modified: trunk/docs_config/Menu.txt
--- trunk/docs_config/Menu.txt 2012-09-07 11:04:46 UTC (rev 2580)
+++ trunk/docs_config/Menu.txt 2012-09-07 11:17:29 UTC (rev 2581)
@@ -1,4 +1,4 @@
-Format: 1.52
+Format: 1.4
Title: Fusion
@@ -51,89 +51,89 @@
Group: Core {
- File: Fusion (%WORKING_COPY%\build\lib\fusion.js)
- File: Fusion.Error (%WORKING_COPY%\build\lib\Error.js)
- File: Fusion.Lib.ApplicationDefinition (%WORKING_COPY%\build\lib\ApplicationDefinition.js)
- File: Fusion.Lib.EventMgr (%WORKING_COPY%\build\lib\EventMgr.js)
- File: Fusion.Lib.MGBroker (%WORKING_COPY%\build\lib\MGBroker.js)
- File: Fusion.MapMessage (%WORKING_COPY%\build\lib\MapMessage.js)
- File: Fusion.Tool.Rectangle (%WORKING_COPY%\build\lib\RectTool.js)
- File: Fusion.Tool.Search (%WORKING_COPY%\build\lib\Search.js)
- File: Fusion.Widget (%WORKING_COPY%\build\lib\Widget.js)
- File: Fusion.Widget.map (no auto-title, %WORKING_COPY%\build\lib\Map.js)
+ File: Fusion (no auto-title, %WORKING_COPY%\build\lib\fusion.js)
+ File: Fusion.Error (no auto-title, %WORKING_COPY%\build\lib\Error.js)
+ File: Fusion.Lib.ApplicationDefinition (no auto-title, %WORKING_COPY%\build\lib\ApplicationDefinition.js)
+ File: Fusion.Lib.EventMgr (no auto-title, %WORKING_COPY%\build\lib\EventMgr.js)
+ File: Fusion.Lib.MGBroker (no auto-title, %WORKING_COPY%\build\lib\MGBroker.js)
+ File: Fusion.MapMessage (no auto-title, %WORKING_COPY%\build\lib\MapMessage.js)
+ File: Fusion.Tool.Rectangle (no auto-title, %WORKING_COPY%\build\lib\RectTool.js)
+ File: Fusion.Tool.Search (no auto-title, %WORKING_COPY%\build\lib\Search.js)
+ File: Fusion.Widget (no auto-title, %WORKING_COPY%\build\lib\Widget.js)
+ File: Fusion.Widget.Map (no auto-title, %WORKING_COPY%\build\lib\Map.js)
} # Group: Core
+Group: Widgets {
+ File: Fusion.Widget.About (no auto-title, %WORKING_COPY%\build\widgets\About.js)
+ File: Fusion.Widget.ActivityIndicator (no auto-title, %WORKING_COPY%\build\widgets\ActivityIndicator.js)
+ File: Fusion.Widget.AddWMSLayer (no auto-title, %WORKING_COPY%\build\widgets\AddWMSLayer.js)
+ File: Fusion.Widget.BasemapSwitcher (no auto-title, %WORKING_COPY%\build\widgets\BasemapSwitcher.js)
+ File: Fusion.Widget.Buffer (no auto-title, %WORKING_COPY%\build\widgets\Buffer.js)
+ File: Fusion.Widget.BufferPanel (no auto-title, %WORKING_COPY%\build\widgets\BufferPanel.js)
+ File: Fusion.Widget.CenterSelection (no auto-title, %WORKING_COPY%\build\widgets\CenterSelection.js)
+ File: Fusion.Widget.ClearSelection (no auto-title, %WORKING_COPY%\build\widgets\ClearSelection.js)
+ File: Fusion.Widget.ColorPicker (no auto-title, %WORKING_COPY%\build\widgets\ColorPicker.js)
+ File: Fusion.Widget.CursorPosition (no auto-title, %WORKING_COPY%\build\widgets\CursorPosition.js)
+ File: Fusion.Widget.EditableScale (no auto-title, %WORKING_COPY%\build\widgets\EditableScale.js)
+ File: Fusion.Widget.ExtentHistory (no auto-title, %WORKING_COPY%\build\widgets\ExtentHistory.js)
+ File: Fusion.Widget.FeatureInfo (no auto-title, %WORKING_COPY%\build\widgets\FeatureInfo.js)
+ File: Fusion.Widget.GetFeatureInfo (no auto-title, %WORKING_COPY%\build\widgets\GetFeatureInfo.js)
+ File: Fusion.Widget.GoogleStreetViewer (no auto-title, %WORKING_COPY%\build\widgets\GoogleStreetViewer.js)
+ File: Fusion.Widget.Help (no auto-title, %WORKING_COPY%\build\widgets\Help.js)
+ File: Fusion.Widget.InitialMapView (no auto-title, %WORKING_COPY%\build\widgets\InitialMapView.js)
+ File: Fusion.Widget.InvokeScript (no auto-title, %WORKING_COPY%\build\widgets\InvokeScript.js)
+ File: Fusion.Widget.InvokeURL (no auto-title, %WORKING_COPY%\build\widgets\InvokeURL.js)
+ File: Fusion.Widget.LayerManager (no auto-title, %WORKING_COPY%\build\widgets\LayerManager.js)
+ File: Fusion.Widget.Legend (no auto-title, %WORKING_COPY%\build\widgets\Legend.js)
+ File: Fusion.Widget.LinkToView (no auto-title, %WORKING_COPY%\build\widgets\LinkToView.js)
+ File: Fusion.Widget.MapMenu (no auto-title, %WORKING_COPY%\build\widgets\MapMenu.js)
+ File: Fusion.Widget.MapMetadata (no auto-title, %WORKING_COPY%\build\widgets\MapMetadata.js)
+ File: Fusion.Widget.Maptip (no auto-title, %WORKING_COPY%\build\widgets\Maptip.js)
+ File: Fusion.Widget.Measure (no auto-title, %WORKING_COPY%\build\widgets\Measure.js)
+ File: Fusion.Widget.Navigator (no auto-title, %WORKING_COPY%\build\widgets\Navigator.js)
+ File: Fusion.Widget.OverviewMap (no auto-title, %WORKING_COPY%\build\widgets\OverviewMap.js)
+ File: Fusion.Widget.Pan (no auto-title, %WORKING_COPY%\build\widgets\Pan.js)
+ File: Fusion.Widget.PanOnClick (no auto-title, %WORKING_COPY%\build\widgets\PanOnClick.js)
+ File: Fusion.Widget.PanQuery (no auto-title, %WORKING_COPY%\build\widgets\PanQuery.js)
+ File: Fusion.Widget.Print (no auto-title, %WORKING_COPY%\build\widgets\Print.js)
+ File: Fusion.Widget.Query (no auto-title, %WORKING_COPY%\build\widgets\Query.js)
+ File: Fusion.Widget.QuickPlot (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot.js)
+ File: Fusion.Widget.Redline (no auto-title, %WORKING_COPY%\build\widgets\Redline.js)
+ File: Fusion.Widget.RefreshMap (no auto-title, %WORKING_COPY%\build\widgets\RefreshMap.js)
+ File: Fusion.Widget.SaveMap (no auto-title, %WORKING_COPY%\build\widgets\SaveMap.js)
+ File: Fusion.Widget.SaveMapImage (no auto-title, %WORKING_COPY%\build\widgets\SaveMapImage.js)
+ File: Fusion.Widget.SaveSession (no auto-title, %WORKING_COPY%\build\widgets\SaveSession.js)
+ File: Fusion.Widget.Scalebar (no auto-title, %WORKING_COPY%\build\widgets\Scalebar.js)
+ File: Fusion.Widget.ScalebarDual (no auto-title, %WORKING_COPY%\build\widgets\ScalebarDual.js)
+ File: Fusion.Widget.Search (no auto-title, %WORKING_COPY%\build\widgets\Search.js)
+ File: Fusion.Widget.Select (no auto-title, %WORKING_COPY%\build\widgets\Select.js)
+ File: Fusion.Widget.SelectionInfo (no auto-title, %WORKING_COPY%\build\widgets\SelectionInfo.js)
+ File: Fusion.Widget.SelectionPanel (no auto-title, %WORKING_COPY%\build\widgets\SelectionPanel.js)
+ File: Fusion.Widget.SelectPolygon (no auto-title, %WORKING_COPY%\build\widgets\SelectPolygon.js)
+ File: Fusion.Widget.SelectRadius (no auto-title, %WORKING_COPY%\build\widgets\SelectAttribute.js)
+ File: Fusion.Widget.SelectRadius (no auto-title, %WORKING_COPY%\build\widgets\SelectRadius.js)
+ File: Fusion.Widget.SelectRadiusValue (no auto-title, %WORKING_COPY%\build\widgets\SelectRadiusValue.js)
+ File: Fusion.Widget.SelectWithin (no auto-title, %WORKING_COPY%\build\widgets\SelectWithin.js)
+ File: Fusion.Widget.TaskPane (no auto-title, %WORKING_COPY%\build\widgets\TaskPane.js)
+ File: Fusion.Widget.Theme (no auto-title, %WORKING_COPY%\build\widgets\Theme.js)
+ File: Fusion.Widget.ViewOptions (no auto-title, %WORKING_COPY%\build\widgets\ViewOptions.js)
+ File: Fusion.Widget.ViewSize (no auto-title, %WORKING_COPY%\build\widgets\ViewSize.js)
+ File: Fusion.Widget.Zoom (no auto-title, %WORKING_COPY%\build\widgets\Zoom.js)
+ File: Fusion.Widget.ZoomOnClick (no auto-title, %WORKING_COPY%\build\widgets\ZoomOnClick.js)
+ File: Fusion.Widget.ZoomToSelection (no auto-title, %WORKING_COPY%\build\widgets\ZoomToSelection.js)
+ File: OpenLayers.Control.MapCapturer (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot\MapCapturer.js)
+ } # Group: Widgets
Group: External {
- File: isValidLonLat (%WORKING_COPY%\build\lib\OLpatch.js)
+ File: OpenLayers.Map.isValidLonLat (no auto-title, %WORKING_COPY%\build\lib\OLpatch.js)
File: JxLib (no auto-title, %WORKING_COPY%\build\lib\jxLib\jxlib.uncompressed.js)
- File: OpenLayers.Control.DragFeature (%WORKING_COPY%\build\lib\DragFeature.js)
- File: OpenLayers\OpenLayers.js (%WORKING_COPY%\build\lib\OpenLayers\OpenLayers.js)
- File: Proj4js (%WORKING_COPY%\build\lib\Proj4js\proj4js-combined.js)
+ File: OpenLayers.Control.DragFeature (no auto-title, %WORKING_COPY%\build\lib\DragFeature.js)
+ File: OpenLayers (no auto-title, %WORKING_COPY%\build\lib\OpenLayers\OpenLayers.js)
+ File: Proj4js (no auto-title, %WORKING_COPY%\build\lib\Proj4js\proj4js-combined.js)
} # Group: External
-Group: Widgets {
- File: Fusion.Widget.About (%WORKING_COPY%\build\widgets\About.js)
- File: Fusion.Widget.ActivityIndicator (%WORKING_COPY%\build\widgets\ActivityIndicator.js)
- File: Fusion.Widget.AddWMSLayer (%WORKING_COPY%\build\widgets\AddWMSLayer.js)
- File: Fusion.Widget.BasemapSwitcher (%WORKING_COPY%\build\widgets\BasemapSwitcher.js)
- File: Fusion.Widget.Buffer (%WORKING_COPY%\build\widgets\Buffer.js)
- File: Fusion.Widget.BufferPanel (%WORKING_COPY%\build\widgets\BufferPanel.js)
- File: Fusion.Widget.CenterSelection (%WORKING_COPY%\build\widgets\CenterSelection.js)
- File: Fusion.Widget.ClearSelection (%WORKING_COPY%\build\widgets\ClearSelection.js)
- File: Fusion.Widget.ColorPicker (%WORKING_COPY%\build\widgets\ColorPicker.js)
- File: Fusion.Widget.CursorPosition (%WORKING_COPY%\build\widgets\CursorPosition.js)
- File: Fusion.Widget.EditableScale (%WORKING_COPY%\build\widgets\EditableScale.js)
- File: Fusion.Widget.ExtentHistory (%WORKING_COPY%\build\widgets\ExtentHistory.js)
- File: Fusion.Widget.FeatureInfo (%WORKING_COPY%\build\widgets\FeatureInfo.js)
- File: Fusion.Widget.GetFeatureInfo (%WORKING_COPY%\build\widgets\GetFeatureInfo.js)
- File: Fusion.Widget.GoogleStreetViewer (%WORKING_COPY%\build\widgets\GoogleStreetViewer.js)
- File: Fusion.Widget.Help (%WORKING_COPY%\build\widgets\Help.js)
- File: Fusion.Widget.InitialMapView (%WORKING_COPY%\build\widgets\InitialMapView.js)
- File: Fusion.Widget.InvokeScript (%WORKING_COPY%\build\widgets\InvokeScript.js)
- File: Fusion.Widget.InvokeURL (%WORKING_COPY%\build\widgets\InvokeURL.js)
- File: Fusion.Widget.LayerManager (%WORKING_COPY%\build\widgets\LayerManager.js)
- File: Fusion.Widget.Legend (%WORKING_COPY%\build\widgets\Legend.js)
- File: Fusion.Widget.LinkToView (%WORKING_COPY%\build\widgets\LinkToView.js)
- File: Fusion.Widget.MapMenu (%WORKING_COPY%\build\widgets\MapMenu.js)
- File: Fusion.Widget.MapMetadata (%WORKING_COPY%\build\widgets\MapMetadata.js)
- File: Fusion.Widget.Maptip (%WORKING_COPY%\build\widgets\Maptip.js)
- File: Fusion.Widget.Measure (%WORKING_COPY%\build\widgets\Measure.js)
- File: Fusion.Widget.Navigator (%WORKING_COPY%\build\widgets\Navigator.js)
- File: Fusion.Widget.OverviewMap (%WORKING_COPY%\build\widgets\OverviewMap.js)
- File: Fusion.Widget.Pan (%WORKING_COPY%\build\widgets\Pan.js)
- File: Fusion.Widget.PanOnClick (%WORKING_COPY%\build\widgets\PanOnClick.js)
- File: Fusion.Widget.PanQuery (%WORKING_COPY%\build\widgets\PanQuery.js)
- File: Fusion.Widget.Print (%WORKING_COPY%\build\widgets\Print.js)
- File: Fusion.Widget.Query (%WORKING_COPY%\build\widgets\Query.js)
- File: Fusion.Widget.QuickPlot (%WORKING_COPY%\build\widgets\QuickPlot.js)
- File: Fusion.Widget.Redline (%WORKING_COPY%\build\widgets\Redline.js)
- File: Fusion.Widget.RefreshMap (%WORKING_COPY%\build\widgets\RefreshMap.js)
- File: Fusion.Widget.SaveMap (%WORKING_COPY%\build\widgets\SaveMap.js)
- File: Fusion.Widget.SaveMapImage (%WORKING_COPY%\build\widgets\SaveMapImage.js)
- File: Fusion.Widget.SaveSession (%WORKING_COPY%\build\widgets\SaveSession.js)
- File: Fusion.Widget.Scalebar (%WORKING_COPY%\build\widgets\Scalebar.js)
- File: Fusion.Widget.ScalebarDual (%WORKING_COPY%\build\widgets\ScalebarDual.js)
- File: Fusion.Widget.Search (%WORKING_COPY%\build\widgets\Search.js)
- File: Fusion.Widget.Select (%WORKING_COPY%\build\widgets\Select.js)
- File: Fusion.Widget.SelectionInfo (%WORKING_COPY%\build\widgets\SelectionInfo.js)
- File: Fusion.Widget.SelectionPanel (%WORKING_COPY%\build\widgets\SelectionPanel.js)
- File: Fusion.Widget.SelectPolygon (%WORKING_COPY%\build\widgets\SelectPolygon.js)
- File: Fusion.Widget.SelectRadius (%WORKING_COPY%\build\widgets\SelectAttribute.js)
- File: Fusion.Widget.SelectRadius (%WORKING_COPY%\build\widgets\SelectRadius.js)
- File: Fusion.Widget.SelectRadiusValue (%WORKING_COPY%\build\widgets\SelectRadiusValue.js)
- File: Fusion.Widget.SelectWithin (%WORKING_COPY%\build\widgets\SelectWithin.js)
- File: Fusion.Widget.TaskPane (%WORKING_COPY%\build\widgets\TaskPane.js)
- File: Fusion.Widget.Theme (%WORKING_COPY%\build\widgets\Theme.js)
- File: Fusion.Widget.ViewOptions (%WORKING_COPY%\build\widgets\ViewOptions.js)
- File: Fusion.Widget.ViewSize (%WORKING_COPY%\build\widgets\ViewSize.js)
- File: Fusion.Widget.Zoom (%WORKING_COPY%\build\widgets\Zoom.js)
- File: Fusion.Widget.ZoomOnClick (%WORKING_COPY%\build\widgets\ZoomOnClick.js)
- File: Fusion.Widget.ZoomToSelection (%WORKING_COPY%\build\widgets\ZoomToSelection.js)
- File: OpenLayers.Control.MapCapturer (%WORKING_COPY%\build\widgets\QuickPlot\MapCapturer.js)
- } # Group: Widgets
Group: Index {
Index: Everything
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2012-09-07 11:04:46 UTC (rev 2580)
+++ trunk/lib/fusion.js 2012-09-07 11:17:29 UTC (rev 2581)
@@ -70,44 +70,32 @@
window.Fusion = {
- * Namespace: Fusion.Tools
* A set of utility classes that provide common tools for applications
Tool: {},
- * Namespace: Fusion.Widget
* A set of classes that implement the functionlity required for applications
Widget: {},
- * Namespace: Fusion.Event
* A class to provide for event handling at application runtime
Event: {lastEventId: 1},
- * Namespace: Fusion.Lib
* A set of classes to provide core funtionality
Lib: {},
- * Namespace: Fusion.Layers
* A set of classes that implement layer functionality for various server
* technologies.
Layers: {},
- * Class: Fusion.Constant
* Application scope constants
Constant: {},
More information about the fusion-commits
