[fusion-commits] r2676 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Sun Mar 24 20:52:08 PDT 2013
Author: jng
Date: 2013-03-24 20:52:08 -0700 (Sun, 24 Mar 2013)
New Revision: 2676
Added:
trunk/widgets/widgetinfo/scalebardual.xml
#556: Add missing widgetinfo xml for ScalebarDual widget
Added: trunk/widgets/widgetinfo/scalebardual.xml
--- trunk/widgets/widgetinfo/scalebardual.xml (rev 0)
+++ trunk/widgets/widgetinfo/scalebardual.xml 2013-03-25 03:52:08 UTC (rev 2676)
@@ -0,0 +1,53 @@
+<WidgetInfo>
+ <Type>ScalebarDual</Type>
+ <LocalizedType>Scale Bar Dual</LocalizedType>
+ <Description>A dynamically generated cartographic scalebar that looks like the Google scalebar</Description>
+ <Location></Location>
+ <Label>ScalebarDual</Label>
+ <Tooltip></Tooltip>
+ <StatusText></StatusText>
+ <ImageUrl></ImageUrl>
+ <ImageClass></ImageClass>
+ <StandardUi>false</StandardUi>
+ <ContainableBy></ContainableBy>
+ <Parameter>
+ <Name>MaxWidth</Name>
+ <Description>Maximum width of the scalebar in pixels</Description>
+ <Type>integer</Type>
+ <Label>Maximum width</Label>
+ <DefaultValue>300</DefaultValue>
+ <IsMandatory>false</IsMandatory>
+ </Parameter>
+ <Parameter>
+ <Name>TopInUnits</Name>
+ <Description>Units for zoomed in on top bar</Description>
+ <Type>String</Type>
+ <Label>Top bar units (zoomed in)</Label>
+ <DefaultValue>ft</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <Name>TopOutUnits</Name>
+ <Description>Units for zoomed out on top bar</Description>
+ <Label>Top bar units (zoomed out)</Label>
+ <DefaultValue>mi</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <Name>BottomInUnits</Name>
+ <Description>Units for zoomed in on bottom bar</Description>
+ <Label>Bottom bar units (zoomed in)</Label>
+ <DefaultValue>m</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <Name>BottomOutUnits</Name>
+ <Description>Units for zoomed out on bottom bar</Description>
+ <Label>Bottom bar units (zoomed out)</Label>
+ <DefaultValue>km</DefaultValue>
+ </Parameter>
+</WidgetInfo>
More information about the fusion-commits
