[fusion-commits] r2677 - sandbox/adsk/2.4j/layers/MapGuide/php
svn_fusion at osgeo.org
Mon Mar 25 00:59:46 PDT 2013
Author: liuar
Date: 2013-03-25 00:59:45 -0700 (Mon, 25 Mar 2013)
New Revision: 2677
sandbox/adsk/2.4j/layers/MapGuide/php/Constants.php
sandbox/adsk/2.4j/layers/MapGuide/php/GetSelectionProperties.php
sandbox/adsk/2.4j/layers/MapGuide/php/Utilities.php
Submit on behalf of Andy Zhang
Revert change #2631 since it degrades performance a lot.
Modified: sandbox/adsk/2.4j/layers/MapGuide/php/Constants.php
--- sandbox/adsk/2.4j/layers/MapGuide/php/Constants.php 2013-03-25 03:52:08 UTC (rev 2676)
+++ sandbox/adsk/2.4j/layers/MapGuide/php/Constants.php 2013-03-25 07:59:45 UTC (rev 2677)
@@ -1871,13 +1871,4 @@
-/// <summary>
-/// The batch size to use when rendering a selection.
-/// </summary>
-class MgSelectionBatchSize
- const RenderSelectionBatchSize = 30000 ;
\ No newline at end of file
Modified: sandbox/adsk/2.4j/layers/MapGuide/php/GetSelectionProperties.php
--- sandbox/adsk/2.4j/layers/MapGuide/php/GetSelectionProperties.php 2013-03-25 03:52:08 UTC (rev 2676)
+++ sandbox/adsk/2.4j/layers/MapGuide/php/GetSelectionProperties.php 2013-03-25 07:59:45 UTC (rev 2677)
@@ -60,7 +60,6 @@
/*holds selection array*/
$properties = NULL;
$properties->layers = array();
- $properties->envelope = NULL;
//process
header('Content-type: application/json');
@@ -81,73 +80,66 @@
//could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
//the one causing a problem when the properies are limited ?
if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
- $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
- if (count($mappings) > 0) {
+ $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
+ if (count($mappings) > 0) {
foreach($mappings as $name => $value) {
$queryOptions->AddFeatureProperty($name);
//echo "$name $value <br>\n";
+ //Add geometry property in all cases.
+ $geomName = $oLayer->GetFeatureGeometryName();
+ $queryOptions->AddFeatureProperty($geomName);
- //Add geometry property in all cases.
- $geomName = $oLayer->GetFeatureGeometryName();
- $queryOptions->AddFeatureProperty($geomName);
- $filters = $selection->GenerateFilters($oLayer, $class, MgSelectionBatchSize::RenderSelectionBatchSize);
- $featureReaders = NULL;
- $featureReaders = array();
- for ($j = 0; $j < $filters->GetCount(); $j++) {
- $queryOptions->SetFilter($filters->GetItem($j));
- $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
- array_push($featureReaders, $featureReader);
+ $filter = $selection->GenerateFilter($oLayer, $class);
+ $queryOptions->SetFilter($filter);
+ $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
//$featureReader = $selection->GetSelectedFeatures($oLayer, $class, true );//this doesn't seem to work but would replace much of the above code
$layerName = $oLayer->GetName();
array_push($properties->layers, $layerName);
- // TODO: Check if computed properties are needed?
+ // TODO: Check if computed properties are needed?
$bComputedProperties = false;
$bNeedsTransform = false;
$srsLayer = NULL;
if ($bComputedProperties)
- $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
- $srsLayerWkt = false;
- if($spatialContext != null && $spatialContext->ReadNext() != null) {
- $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
- /* skip this layer if the srs is empty */
- if ($srsLayerWkt == null) {
- $srsLayerWkt = $srsDefMap;
- /* create a coordinate system from the layer's SRS wkt */
- $srsLayer = $srsFactory->Create($srsLayerWkt);
+ $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
+ $srsLayerWkt = false;
+ if($spatialContext != null && $spatialContext->ReadNext() != null) {
+ $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
+ /* skip this layer if the srs is empty */
+ if ($srsLayerWkt == null) {
+ $srsLayerWkt = $srsDefMap;
+ /* create a coordinate system from the layer's SRS wkt */
+ $srsLayer = $srsFactory->Create($srsLayerWkt);
- // exclude layer if:
- // the map is non-arbitrary and the layer is arbitrary or vice-versa
- // or
- // layer and map are both arbitrary but have different units
- $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
- $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
- if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
- ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
- $bComputedProperties = false;
- } else {
- $srsTarget = null;
- $srsXform = null;
- $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
+ // exclude layer if:
+ // the map is non-arbitrary and the layer is arbitrary or vice-versa
+ // or
+ // layer and map are both arbitrary but have different units
+ $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
+ $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
+ if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
+ ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
+ $bComputedProperties = false;
+ } else {
+ $srsTarget = null;
+ $srsXform = null;
+ $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
- $properties = BuildSelectionArrayEx($featureReaders, $layerName, $properties,
+ $properties = BuildSelectionArray($featureReader, $layerName, $properties,
$bComputedProperties,
$srsLayer, $bNeedsTransform, $oLayer, true);
- foreach ($featureReaders as $featureReader) {
- $featureReader->Close();
+ $featureReader->Close();
$result = NULL;
@@ -155,7 +147,7 @@
if ($layers && $layers->GetCount() >= 0)
$result->hasSelection = true;
- $oExtents = $properties->envelope;
+ $oExtents = $selection->GetExtents($featureService);
if ($oExtents)
$oMin = $oExtents->GetLowerLeftCoordinate();
Modified: sandbox/adsk/2.4j/layers/MapGuide/php/Utilities.php
--- sandbox/adsk/2.4j/layers/MapGuide/php/Utilities.php 2013-03-25 03:52:08 UTC (rev 2676)
+++ sandbox/adsk/2.4j/layers/MapGuide/php/Utilities.php 2013-03-25 07:59:45 UTC (rev 2677)
@@ -891,154 +891,6 @@
return $properties;
- keep all the attributes of selected features in an array
-function BuildSelectionArrayEx($featureReaders, $layerName, $properties, $bComputedProperties,
- $srsLayer, $bNeedsTransform, $layerObj, $isLayerNameEncoded)
- if (count($featureReaders) == 0)
- return $properties;
- if($isLayerNameEncoded)
- // Add prefix to avoid layer name beginning with number
- // So $isLayerNameEncoded should be true when and only when the properties will be stored in session
- $layerName = GetEncodedLayerName($layerName);
- $agf = new MgAgfReaderWriter();
- $srsFactory = new MgCoordinateSystemFactory();
- $properties->$layerName->propertynames = array();
- $properties->$layerName->propertyvalues = array();
- $properties->$layerName->propertytypes = array();
- $properties->$layerName->numelements = 0;
- $properties->$layerName->values = array();
- $properties->$layerName->metadatanames= array();
- array_push($properties->$layerName->metadatanames, 'dimension');
- array_push($properties->$layerName->metadatanames, 'bbox');
- array_push($properties->$layerName->metadatanames, 'center');
- array_push($properties->$layerName->metadatanames, 'area');
- array_push($properties->$layerName->metadatanames, 'length');
- $featureReader = $featureReaders[0];
- $mappings = $_SESSION['property_mappings'][$layerObj->GetObjectId()];
- foreach((array)$mappings as $name => $value)
- $propType = $featureReader->GetPropertyType($name);
- array_push($properties->$layerName->propertynames, $name);
- array_push($properties->$layerName->propertyvalues, $value);
- array_push($properties->$layerName->propertytypes, $propType);
- $srsXform = null;
- //$envelope = new MgEnvelope();
- while ($featureReader->ReadNext())
- $properties->$layerName->values[$properties->$layerName->numelements] = array();
- $properties->$layerName->metadata[$properties->$layerName->numelements] = array();
- $dimension = '';
- $bbox = '';
- $center = '';
- $area = '';
- $length = '';
- if ($bComputedProperties)
- $classDef = $featureReader->GetClassDefinition();
- $geomName = $classDef->GetDefaultGeometryPropertyName();
- if ($geomName != '') {
- $geomByteReader = $featureReader->GetGeometry($geomName);
- /* is this needed? We declare one outside the loop too?*/
- $geom = $agf->Read($geomByteReader);
- $envelope = $geom->Envelope();
- $ll = $envelope->GetLowerLeftCoordinate();
- $ur = $envelope->GetUpperRightCoordinate();
- $bbox = $ll->GetX().','.$ll->GetY().','.$ur->GetX().','.$ur->GetY();
- $centroid = $geom->GetCentroid()->GetCoordinate();
- $center = $centroid->GetX().','.$centroid->GetY();
- /* 0 = point, 1 = curve, 2 = surface */
- $dimension = $geom->GetDimension();
- if ($geom->GetDimension() > 0) {
- //conver the geometry to UTM auto so that local measurements
- //are accruate in meters
- if ($bNeedsTransform && $srsTarget == null && $srsXform == null) {
- $wkt = getUtmWkt($centroid->GetX(),
- $centroid->GetY());
- $srsTarget = $srsFactory->Create($wkt);
- $verMajor = subStr(GetSiteVersion(), 0,1);
- if ($verMajor == '1') {
- $srsXform = new MgCoordinateSystemTransform($srsLayer, $srsTarget);
- } else {
- $srsXform = $srsFactory->GetTransform($srsLayer, $srsTarget);
- if ($srsXform != null) {
- try {
- $ageom = $geom->Transform($srsXform);
- $geom = $ageom;
- } catch (MgException $ee) {
- echo "/*transform exception:";
- echo "ERROR: " . $ee->GetExceptionMessage() . "\n";
- echo $ee->GetDetails() . "\n*/";
- if ($geom->GetDimension() > 1) {
- $area = $geom->GetArea();
- $length = $geom->GetLength();
- array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $dimension);
- array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $bbox);
- array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $center);
- array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $area);
- array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $length);
- $numproperties = count($properties->$layerName->propertynames);
- for($j=0; $j<$numproperties; $j++) {
- $propname = $properties->$layerName->propertynames[$j];
- $propType = $properties->$layerName->propertytypes[$j];
- if ($propname == '')
- continue;
- if ($propType == MgPropertyType::Geometry) {
- $geomEnv = $geom->Envelope();
- $properties->envolope->ExpandToInclude($geomEnv);
- else {
- $value = GetPropertyValueFromFeatReader($featureReader,
- $properties->$layerName->propertytypes[$j],
- $propname);
- $value = htmlentities($value, ENT_COMPAT, 'UTF-8');
- $value = addslashes($value);
- $value = preg_replace( "/\r?\n/", "<br>", $value );
- array_push($properties->$layerName->values[$properties->$layerName->numelements], $value);
- //$properties->$layerName->values[$properties->$layerName->numelements][$propname] = $value;
- $properties->$layerName->numelements= $properties->$layerName->numelements+1;
function getUtmWkt($lon, $lat) {
$siteVersion = explode(".",GetSiteVersion());
if ((integer)$siteVersion[0] > 2 || (integer)$siteVersion[0] == 2 && (integer)$siteVersion[1] > 0) { //v2.1.x or greater
More information about the fusion-commits
