[fusion-commits] r2678 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Tue Mar 26 03:47:58 PDT 2013
Author: jng
Date: 2013-03-26 03:47:57 -0700 (Tue, 26 Mar 2013)
New Revision: 2678
Removed:
trunk/widgets/widgetinfo/ctrlclick.xml
#558: CTRLClick no longer exists as a widget. So remove the widgetinfo xml to avoid confusing client-side editing tools.
Deleted: trunk/widgets/widgetinfo/ctrlclick.xml
--- trunk/widgets/widgetinfo/ctrlclick.xml 2013-03-25 07:59:45 UTC (rev 2677)
+++ trunk/widgets/widgetinfo/ctrlclick.xml 2013-03-26 10:47:57 UTC (rev 2678)
@@ -1,21 +0,0 @@
-<WidgetInfo>
- <Type>CTRLClick</Type>
- <LocalizedType>CTRL Click</LocalizedType>
- <Description>Launch a window with a CTRL click if a URL expression is set on the layer</Description>
- <Location></Location>
- <Label>CTRLClick</Label>
- <Tooltip></Tooltip>
- <StatusText></StatusText>
- <ImageUrl></ImageUrl>
- <ImageClass></ImageClass>
- <StandardUi>false</StandardUi>
- <ContainableBy></ContainableBy>
- <Parameter>
- <Name>Layer</Name>
- <Description>A list of layers for CTRL click to work with</Description>
- <Type>String</Type>
- <Label>Layer</Label>
- <DefaultValue></DefaultValue>
- <IsMandatory>false</IsMandatory>
- </Parameter>
-</WidgetInfo>
More information about the fusion-commits
