[fusion-commits] r2824 - in sandbox/robust_error_handling: . lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 28 04:51:40 PST 2013
Author: jng
Date: 2013-11-28 04:51:39 -0800 (Thu, 28 Nov 2013)
New Revision: 2824
   sandbox/robust_error_handling/build.xml
   sandbox/robust_error_handling/lib/fusion.js
#576:
 - Integrate TraceKit to single-file build
 - Disable TraceKit remote fetching for single-file build
 - Point Fusion.ajaxRequest() failures to Fusion.ajaxException() if error handler is not set
Modified: sandbox/robust_error_handling/build.xml
--- sandbox/robust_error_handling/build.xml	2013-11-28 12:00:01 UTC (rev 2823)
+++ sandbox/robust_error_handling/build.xml	2013-11-28 12:51:39 UTC (rev 2824)
@@ -214,6 +214,7 @@
         <filelist dir="${build.home}/lib"
                   files=" SingleFile.js
                           fusion.js
+                          TraceKit/TraceKit.js
                           jxLib/jxlib.uncompressed.js
                           OpenLayers/OpenLayers.js
                           Proj4js/proj4js-compressed.js
Modified: sandbox/robust_error_handling/lib/fusion.js
--- sandbox/robust_error_handling/lib/fusion.js	2013-11-28 12:00:01 UTC (rev 2823)
+++ sandbox/robust_error_handling/lib/fusion.js	2013-11-28 12:51:39 UTC (rev 2824)
@@ -336,6 +336,7 @@
         initialize: function(options) {
+            TraceKit.remoteFetching = !singleFile;
             TraceKit.report.subscribe(OpenLayers.Function.bind(this.onTraceKitError, this));
             options = options || {};
@@ -722,6 +723,9 @@
             if (!options.onException) {
                 options.onException = OpenLayers.Function.bind(this.ajaxException, this);
+            if (!options.onFailure) {
+                options.onFailure = OpenLayers.Function.bind(this.ajaxException, this);
             if (!options.contentType) {
               options.contentType = 'application/x-www-form-urlencoded';
More information about the fusion-commits mailing list
