[fusion-commits] r2825 - in sandbox/robust_error_handling: lib text
svn_fusion at osgeo.org
Thu Nov 28 05:28:45 PST 2013
Author: jng
Date: 2013-11-28 05:28:45 -0800 (Thu, 28 Nov 2013)
New Revision: 2825
sandbox/robust_error_handling/lib/ApplicationDefinition.js
sandbox/robust_error_handling/text/en.json
#576: Error out fatally if CreateSession.php returns nothing as we need a valid session id (which is script is supposed to create) in order to continue.
Modified: sandbox/robust_error_handling/lib/ApplicationDefinition.js
--- sandbox/robust_error_handling/lib/ApplicationDefinition.js 2013-11-28 12:51:39 UTC (rev 2824)
+++ sandbox/robust_error_handling/lib/ApplicationDefinition.js 2013-11-28 13:28:45 UTC (rev 2825)
@@ -152,7 +152,11 @@
this.sessionId = o.sessionId;
Fusion.sessionId = this.sessionId;
- this.getAppDef();
+ //We must have a session id established in order to continue here
+ if (this.sessionId)
+ this.getAppDef();
+ else
+ Fusion.reportFatalError("Call to CreateSession.php failed");
getAppDef: function(){
Modified: sandbox/robust_error_handling/text/en.json
--- sandbox/robust_error_handling/text/en.json 2013-11-28 12:51:39 UTC (rev 2824)
+++ sandbox/robust_error_handling/text/en.json 2013-11-28 13:28:45 UTC (rev 2825)
@@ -5,6 +5,8 @@
'Make sure that you have copied config_dist.json to config.json ' +
'and have configured the settings for your system',
'pingFailure': 'Failed to keep session alive: ${message}',
+'sessionExpired': 'Your current MapGuide session has expired',
+'reload': 'Reload this application',
'createSessionFailure': 'Failed to create session: ${message}',
'ajaxError': 'Exception occurred in AJAX callback.\nMessage: ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
'detailedErrorTemplateHtml': '<h3>${name}</h3><br/>Error Details:<pre>${message}</pre><br/>Stack Trace:<br/><pre>${stacktrace}</pre><br/>Source: <pre>${source}</pre>',
More information about the fusion-commits
