[fusion-commits] r2795 - in sandbox/closure: . utils
svn_fusion at osgeo.org
Tue Oct 15 23:56:03 PDT 2013
Author: jng
Date: 2013-10-15 23:56:03 -0700 (Tue, 15 Oct 2013)
New Revision: 2795
Added:
sandbox/closure/utils/compiler.jar
sandbox/closure/build.xml
#598: Use closure compiler for compressing our javascript. Besides producing smaller files (50kb less) on default settings, closure gives us sourcemap support which will make "debugging" fusionSF-compressed.js a much more pleasant affair. We're still keeping YUICompressor around for any CSS compression tasks.
Note: We're not using closure with advanced optimizations. Although advanced optimizations will make the resulting file 500kb smaller, it may change the actual behaviour of our code. To move to advanced optimizations requires a thorough review of the code base to determine if it is compatible with the closure compiler in this optimization mode.
Modified: sandbox/closure/build.xml
--- sandbox/closure/build.xml 2013-10-10 02:44:51 UTC (rev 2794)
+++ sandbox/closure/build.xml 2013-10-16 06:56:03 UTC (rev 2795)
@@ -74,7 +74,7 @@
<property environment="env"/>
<property name="app.name" value="fusion"/>
<property name="app.path" value="/${app.name}"/>
- <property name="app.version" value="2.0.x"/>
+ <property name="app.version" value="2.6.0"/>
<property name="build.home" value="${basedir}/build"/>
<property name="deploy.home" value="${basedir}/../${app.name}"/>
<property name="selfbuild.home" value="${basedir}/selfbuild"/>
@@ -88,8 +88,9 @@
Use property values to define the locations of external libraries on which
your application will depend.
+ <!-- We're still keeping YUI compressor for CSS duties. JS is now closure's job -->
<property name="YUIcompressor" value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
+ <property name="closure" value="${basedir}/utils/compiler.jar" />
<property name="sfName" value="fusionSF"/>
<property name="buildOutput" value="${build.home}/lib/${sfName}"/>
<property name="cssOutput" value="${build.home}/lib/${sfName}"/>
@@ -204,6 +205,11 @@
so replace the value to look for with the sfName used to create the file-->
<!-- merge everything into a single file -->
+ NOTE: Closure's source map support means fusionSF.js becomes somewhat redundant, but
+ we keep this around so that less-capable browsers can still debug a combined build by
+ switching to fusionSF.js in the template
<concat destfile="${buildOutput}.js" encoding="UTF-8" outputencoding="UTF-8">
<filelist dir="${build.home}/lib"
files=" SingleFile.js
@@ -258,12 +264,32 @@
<target description="Compress JS files" name="compress" depends="singleFile">
<echo message="compressing..."/>
- <java jar="${YUIcompressor}" fork="true"
- output="${buildOutput}-compressed.js">
+ <java jar="${closure}" fork="true" dir="${build.home}/lib">
<arg value="--charset"/>
<arg value="utf-8"/>
- <arg value="${buildOutput}.js"/>
+ <arg value="--compilation_level" />
+ TODO: We're sticking with SIMPLE_OPTIMIZATIONS for now
+ Moving to ADVANCED_OPTIMIZATIONS will shave off 500kb from the final compressed file, but
+ this requires a thorough review of the JS code to ensure it satisfies the requirements
+ demanded by the closure compiler and not result in any undefined behaviour.
+ Still as it currently stands, closure with SIMPLE_OPTIMIZATIONS is 50kb lighter than through
+ YUICompressor
+ <arg value="SIMPLE_OPTIMIZATIONS" />
+ <arg value="--source_map_format" />
+ <arg value="DEFAULT" />
+ <arg value="--create_source_map" />
+ <arg value="${sfName}-compressed.js.map" />
+ <arg value="--js" />
+ <arg value="${sfName}.js" />
+ <arg value="--js_output_file" />
+ <arg value="${sfName}-compressed.js" />
</java>
+ <!-- Huh? Closure doesn't tack this important line so we have to do it ourselves! -->
+ <concat destfile="${buildOutput}-compressed.js" append="true">//@ sourceMappingURL=${sfName}-compressed.js.map</concat>
<copy file="${buildOutput}-compressed.js" todir="${basedir}/lib"/>
</target>
@@ -328,7 +354,7 @@
<target name="selfbuild" description="Create zip file containing build tools">
<echo message="Deploying to web server"/>
<mkdir dir="${selfbuild.home}"/>
- <delete file="${selfbuild.home}/${app.name}-buildtools.zip" />
+ <delete file="${selfbuild.home}/${app.name}-${app.version}-buildtools.zip" />
<copy todir="${selfbuild.home}">
<fileset dir="${basedir}"
includes="build.xml
@@ -337,7 +363,7 @@
utils/**" />
</copy>
<!-- Create source zip file -->
- <zip destfile="${selfbuild.home}/${app.name}-buildtools.zip">
+ <zip destfile="${selfbuild.home}/${app.name}-${app.version}-buildtools.zip">
<zipfileset dir="${selfbuild.home}" />
</zip>
</target>
Added: sandbox/closure/utils/compiler.jar
(Binary files differ)
Property changes on: sandbox/closure/utils/compiler.jar
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
More information about the fusion-commits
