[fusion-commits] r2796 - in trunk: . utils
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Oct 17 22:22:34 PDT 2013
Author: jng
Date: 2013-10-17 22:22:33 -0700 (Thu, 17 Oct 2013)
New Revision: 2796
Added:
   trunk/utils/COPYING
   trunk/utils/README
   trunk/utils/compiler.jar
   trunk/build.xml
#598: Use closure compiler for compressing our javascript. Besides producing smaller files (50kb less) on default settings, closure gives us sourcemap support which will make "debugging" fusionSF-compressed.js a much more pleasant affair. We're still keeping YUICompressor around for any CSS compression tasks.
Note: We're not using closure with advanced optimizations. Although advanced optimizations will make the resulting file 500kb smaller, it may change the actual behaviour of our code. To move to advanced optimizations requires a thorough review of the code base to determine if it is compatible with the closure compiler in this optimization mode.
Modified: trunk/build.xml
--- trunk/build.xml	2013-10-16 06:56:03 UTC (rev 2795)
+++ trunk/build.xml	2013-10-18 05:22:33 UTC (rev 2796)
@@ -74,7 +74,7 @@
   <property environment="env"/>
   <property name="app.name" value="fusion"/>
   <property name="app.path" value="/${app.name}"/>
-  <property name="app.version" value="2.0.x"/>
+  <property name="app.version" value="2.6.0"/>
   <property name="build.home" value="${basedir}/build"/>
   <property name="deploy.home" value="${basedir}/../${app.name}"/>
   <property name="selfbuild.home" value="${basedir}/selfbuild"/>
@@ -88,8 +88,9 @@
   Use property values to define the locations of external libraries on which
   your application will depend.
+  <!-- We're still keeping YUI compressor for CSS duties. JS is now closure's job -->
   <property name="YUIcompressor"  value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
+  <property name="closure" value="${basedir}/utils/compiler.jar" />
   <property name="sfName"  value="fusionSF"/>
   <property name="buildOutput"  value="${build.home}/lib/${sfName}"/>
   <property name="cssOutput"  value="${build.home}/lib/${sfName}"/>
@@ -204,6 +205,11 @@
         so replace the value to look for with the sfName used to create the file-->
     <!-- merge everything into a single file -->
+    NOTE: Closure's source map support means fusionSF.js becomes somewhat redundant, but
+    we keep this around so that less-capable browsers can still debug a combined build by
+    switching to fusionSF.js in the template
     <concat destfile="${buildOutput}.js" encoding="UTF-8" outputencoding="UTF-8">
         <filelist dir="${build.home}/lib"
                   files=" SingleFile.js
@@ -258,12 +264,32 @@
   <target description="Compress JS files" name="compress" depends="singleFile">
     <echo message="compressing..."/>
-    <java jar="${YUIcompressor}" fork="true"
-          output="${buildOutput}-compressed.js">
+    <java jar="${closure}" fork="true" dir="${build.home}/lib">
         <arg value="--charset"/>
         <arg value="utf-8"/>
-        <arg value="${buildOutput}.js"/>
+        <arg value="--compilation_level" />
+        TODO: We're sticking with SIMPLE_OPTIMIZATIONS for now
+        Moving to ADVANCED_OPTIMIZATIONS will shave off 500kb from the final compressed file, but
+        this requires a thorough review of the JS code to ensure it satisfies the requirements
+        demanded by the closure compiler and not result in any undefined behaviour.
+        Still as it currently stands, closure with SIMPLE_OPTIMIZATIONS is 50kb lighter than through
+        YUICompressor
+        <arg value="SIMPLE_OPTIMIZATIONS" />
+        <arg value="--source_map_format" />
+        <arg value="DEFAULT" />
+        <arg value="--create_source_map" />
+        <arg value="${sfName}-compressed.js.map" />
+        <arg value="--js" />
+        <arg value="${sfName}.js" />
+        <arg value="--js_output_file" />
+        <arg value="${sfName}-compressed.js" />
     </java>
+    <!-- Huh? Closure doesn't tack this important line so we have to do it ourselves! -->
+    <concat destfile="${buildOutput}-compressed.js" append="true">//@ sourceMappingURL=${sfName}-compressed.js.map</concat>
     <copy file="${buildOutput}-compressed.js" todir="${basedir}/lib"/>
   </target>
@@ -328,7 +354,7 @@
  <target name="selfbuild" description="Create zip file containing build tools">
     <echo message="Deploying to web server"/>
     <mkdir dir="${selfbuild.home}"/>
-    <delete file="${selfbuild.home}/${app.name}-buildtools.zip" />
+    <delete file="${selfbuild.home}/${app.name}-${app.version}-buildtools.zip" />
     <copy todir="${selfbuild.home}">
       <fileset dir="${basedir}"
             includes="build.xml
@@ -337,7 +363,7 @@
                       utils/**" />
     </copy>
     <!-- Create source zip file -->
-    <zip destfile="${selfbuild.home}/${app.name}-buildtools.zip">
+    <zip destfile="${selfbuild.home}/${app.name}-${app.version}-buildtools.zip">
       <zipfileset dir="${selfbuild.home}" />
     </zip>
   </target>
Added: trunk/utils/COPYING
--- trunk/utils/COPYING	                        (rev 0)
+++ trunk/utils/COPYING	2013-10-18 05:22:33 UTC (rev 2796)
@@ -0,0 +1,202 @@
+                                 Apache License
+                           Version 2.0, January 2004
+                        http://www.apache.org/licenses/
+   TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
+   1. Definitions.
+      "License" shall mean the terms and conditions for use, reproduction,
+      and distribution as defined by Sections 1 through 9 of this document.
+      "Licensor" shall mean the copyright owner or entity authorized by
+      the copyright owner that is granting the License.
+      "Legal Entity" shall mean the union of the acting entity and all
+      other entities that control, are controlled by, or are under common
+      control with that entity. For the purposes of this definition,
+      "control" means (i) the power, direct or indirect, to cause the
+      direction or management of such entity, whether by contract or
+      otherwise, or (ii) ownership of fifty percent (50%) or more of the
+      outstanding shares, or (iii) beneficial ownership of such entity.
+      "You" (or "Your") shall mean an individual or Legal Entity
+      exercising permissions granted by this License.
+      "Source" form shall mean the preferred form for making modifications,
+      including but not limited to software source code, documentation
+      source, and configuration files.
+      "Object" form shall mean any form resulting from mechanical
+      transformation or translation of a Source form, including but
+      not limited to compiled object code, generated documentation,
+      and conversions to other media types.
+      "Work" shall mean the work of authorship, whether in Source or
+      Object form, made available under the License, as indicated by a
+      copyright notice that is included in or attached to the work
+      (an example is provided in the Appendix below).
+      "Derivative Works" shall mean any work, whether in Source or Object
+      form, that is based on (or derived from) the Work and for which the
+      editorial revisions, annotations, elaborations, or other modifications
+      represent, as a whole, an original work of authorship. For the purposes
+      of this License, Derivative Works shall not include works that remain
+      separable from, or merely link (or bind by name) to the interfaces of,
+      the Work and Derivative Works thereof.
+      "Contribution" shall mean any work of authorship, including
+      the original version of the Work and any modifications or additions
+      to that Work or Derivative Works thereof, that is intentionally
+      submitted to Licensor for inclusion in the Work by the copyright owner
+      or by an individual or Legal Entity authorized to submit on behalf of
+      the copyright owner. For the purposes of this definition, "submitted"
+      means any form of electronic, verbal, or written communication sent
+      to the Licensor or its representatives, including but not limited to
+      communication on electronic mailing lists, source code control systems,
+      and issue tracking systems that are managed by, or on behalf of, the
+      Licensor for the purpose of discussing and improving the Work, but
+      excluding communication that is conspicuously marked or otherwise
+      designated in writing by the copyright owner as "Not a Contribution."
+      "Contributor" shall mean Licensor and any individual or Legal Entity
+      on behalf of whom a Contribution has been received by Licensor and
+      subsequently incorporated within the Work.
+   2. Grant of Copyright License. Subject to the terms and conditions of
+      this License, each Contributor hereby grants to You a perpetual,
+      worldwide, non-exclusive, no-charge, royalty-free, irrevocable
+      copyright license to reproduce, prepare Derivative Works of,
+      publicly display, publicly perform, sublicense, and distribute the
+      Work and such Derivative Works in Source or Object form.
+   3. Grant of Patent License. Subject to the terms and conditions of
+      (except as stated in this section) patent license to make, have made,
+      use, offer to sell, sell, import, and otherwise transfer the Work,
+      where such license applies only to those patent claims licensable
+      by such Contributor that are necessarily infringed by their
+      Contribution(s) alone or by combination of their Contribution(s)
+      with the Work to which such Contribution(s) was submitted. If You
+      institute patent litigation against any entity (including a
+      cross-claim or counterclaim in a lawsuit) alleging that the Work
+      or a Contribution incorporated within the Work constitutes direct
+      or contributory patent infringement, then any patent licenses
+      granted to You under this License for that Work shall terminate
+      as of the date such litigation is filed.
+   4. Redistribution. You may reproduce and distribute copies of the
+      Work or Derivative Works thereof in any medium, with or without
+      modifications, and in Source or Object form, provided that You
+      meet the following conditions:
+      (a) You must give any other recipients of the Work or
+          Derivative Works a copy of this License; and
+      (b) You must cause any modified files to carry prominent notices
+          stating that You changed the files; and
+      (c) You must retain, in the Source form of any Derivative Works
+          that You distribute, all copyright, patent, trademark, and
+          attribution notices from the Source form of the Work,
+          excluding those notices that do not pertain to any part of
+          the Derivative Works; and
+      (d) If the Work includes a "NOTICE" text file as part of its
+          distribution, then any Derivative Works that You distribute must
+          include a readable copy of the attribution notices contained
+          within such NOTICE file, excluding those notices that do not
+          pertain to any part of the Derivative Works, in at least one
+          of the following places: within a NOTICE text file distributed
+          as part of the Derivative Works; within the Source form or
+          documentation, if provided along with the Derivative Works; or,
+          within a display generated by the Derivative Works, if and
+          wherever such third-party notices normally appear. The contents
+          of the NOTICE file are for informational purposes only and
+          do not modify the License. You may add Your own attribution
+          notices within Derivative Works that You distribute, alongside
+          or as an addendum to the NOTICE text from the Work, provided
+          that such additional attribution notices cannot be construed
+          as modifying the License.
+      You may add Your own copyright statement to Your modifications and
+      may provide additional or different license terms and conditions
+      for use, reproduction, or distribution of Your modifications, or
+      for any such Derivative Works as a whole, provided Your use,
+      reproduction, and distribution of the Work otherwise complies with
+      the conditions stated in this License.
+   5. Submission of Contributions. Unless You explicitly state otherwise,
+      any Contribution intentionally submitted for inclusion in the Work
+      by You to the Licensor shall be under the terms and conditions of
+      this License, without any additional terms or conditions.
+      Notwithstanding the above, nothing herein shall supersede or modify
+      the terms of any separate license agreement you may have executed
+      with Licensor regarding such Contributions.
+   6. Trademarks. This License does not grant permission to use the trade
+      names, trademarks, service marks, or product names of the Licensor,
+      except as required for reasonable and customary use in describing the
+      origin of the Work and reproducing the content of the NOTICE file.
+   7. Disclaimer of Warranty. Unless required by applicable law or
+      agreed to in writing, Licensor provides the Work (and each
+      Contributor provides its Contributions) on an "AS IS" BASIS,
+      WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+      implied, including, without limitation, any warranties or conditions
+      of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
+      PARTICULAR PURPOSE. You are solely responsible for determining the
+      appropriateness of using or redistributing the Work and assume any
+      risks associated with Your exercise of permissions under this License.
+   8. Limitation of Liability. In no event and under no legal theory,
+      whether in tort (including negligence), contract, or otherwise,
+      unless required by applicable law (such as deliberate and grossly
+      negligent acts) or agreed to in writing, shall any Contributor be
+      liable to You for damages, including any direct, indirect, special,
+      incidental, or consequential damages of any character arising as a
+      result of this License or out of the use or inability to use the
+      Work (including but not limited to damages for loss of goodwill,
+      work stoppage, computer failure or malfunction, or any and all
+      other commercial damages or losses), even if such Contributor
+      has been advised of the possibility of such damages.
+   9. Accepting Warranty or Additional Liability. While redistributing
+      the Work or Derivative Works thereof, You may choose to offer,
+      and charge a fee for, acceptance of support, warranty, indemnity,
+      or other liability obligations and/or rights consistent with this
+      License. However, in accepting such obligations, You may act only
+      on Your own behalf and on Your sole responsibility, not on behalf
+      of any other Contributor, and only if You agree to indemnify,
+      defend, and hold each Contributor harmless for any liability
+      incurred by, or claims asserted against, such Contributor by reason
+      of your accepting any such warranty or additional liability.
+   END OF TERMS AND CONDITIONS
+   APPENDIX: How to apply the Apache License to your work.
+      To apply the Apache License to your work, attach the following
+      boilerplate notice, with the fields enclosed by brackets "[]"
+      replaced with your own identifying information. (Don't include
+      the brackets!)  The text should be enclosed in the appropriate
+      comment syntax for the file format. We also recommend that a
+      file or class name and description of purpose be included on the
+      same "printed page" as the copyright notice for easier
+      identification within third-party archives.
+   Copyright [yyyy] [name of copyright owner]
+   Licensed under the Apache License, Version 2.0 (the "License");
+   you may not use this file except in compliance with the License.
+   You may obtain a copy of the License at
+       http://www.apache.org/licenses/LICENSE-2.0
+   Unless required by applicable law or agreed to in writing, software
+   distributed under the License is distributed on an "AS IS" BASIS,
+   WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+   See the License for the specific language governing permissions and
+   limitations under the License.
Added: trunk/utils/README
--- trunk/utils/README	                        (rev 0)
+++ trunk/utils/README	2013-10-18 05:22:33 UTC (rev 2796)
@@ -0,0 +1,292 @@
+ * Copyright 2009 The Closure Compiler Authors.
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ *     http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+// Contents
+The Closure Compiler performs checking, instrumentation, and
+optimizations on JavaScript code. The purpose of this README is to
+explain how to build and run the Closure Compiler.
+The Closure Compiler requires Java 6 or higher.
+http://www.java.com/
+// Building The Closure Compiler
+There are three ways to get a Closure Compiler executable.
+1) Use one we built for you.
+Pre-built Closure binaries can be found at
+http://code.google.com/p/closure-compiler/downloads/list
+2) Check out the source and build it with Apache Ant.
+First, check out the full source tree of the Closure Compiler. There
+are instructions on how to do this at the project site.
+http://code.google.com/p/closure-compiler/source/checkout
+Apache Ant is a cross-platform build tool.
+http://ant.apache.org/
+At the root of the source tree, there is an Ant file named
+build.xml. To use it, navigate to the same directory and type the
+command
+ant jar
+This will produce a jar file called "build/compiler.jar".
+3) Check out the source and build it with Eclipse.
+Eclipse is a cross-platform IDE.
+http://www.eclipse.org/
+Under Eclipse's File menu, click "New > Project ..." and create a
+"Java Project."  You will see an options screen. Give the project a
+name, select "Create project from existing source," and choose the
+root of the checked-out source tree as the existing directory. Verify
+that you are using JRE version 6 or higher.
+Eclipse can use the build.xml file to discover rules. When you
+navigate to the build.xml file, you will see all the build rules in
+the "Outline" pane. Run the "jar" rule to build the compiler in
+build/compiler.jar.
+// Running The Closure Compiler
+Once you have the jar binary, running the Closure Compiler is straightforward.
+On the command line, type
+java -jar compiler.jar
+This starts the compiler in interactive mode. Type
+var x = 17 + 25;
+then hit "Enter", then hit "Ctrl-Z" (on Windows) or "Ctrl-D" (on Mac or Linux)
+and "Enter" again. The Compiler will respond:
+var x=42;
+The Closure Compiler has many options for reading input from a file,
+writing output to a file, checking your code, and running
+optimizations. To learn more, type
+java -jar compiler.jar --help
+You can read more detailed documentation about the many flags at
+http://code.google.com/closure/compiler/docs/gettingstarted_app.html
+// Compiling Multiple Scripts
+If you have multiple scripts, you should compile them all together with
+one compile command.
+java -jar compiler.jar --js=in1.js --js=in2.js ... --js_output_file=out.js
+The Closure Compiler will concatenate the files in the order they're
+passed at the command line.
+If you need to compile many, many scripts together, you may start to
+run into problems with managing dependencies between scripts. You
+should check out the Closure Library. It contains functions for
+enforcing dependencies between scripts, and a tool called calcdeps.py
+that knows how to give scripts to the Closure Compiler in the right
+order.
+http://code.google.com/p/closure-library/
+// Licensing
+Unless otherwise stated, all source files are licensed under
+the Apache License, Version 2.0.
+Code under:
+src/com/google/javascript/rhino
+test/com/google/javascript/rhino
+URL: http://www.mozilla.org/rhino
+Version:  1.5R3, with heavy modifications
+License:  Netscape Public License and MPL / GPL dual license
+Description: A partial copy of Mozilla Rhino. Mozilla Rhino is an
+implementation of JavaScript for the JVM.  The JavaScript parser and
+the parse tree data structures were extracted and modified
+significantly for use by Google's JavaScript compiler.
+Local Modifications: The packages have been renamespaced. All code not
+relevant to parsing has been removed. A JsDoc parser and static typing
+system have been added.
+Code in:
+lib/rhino
+Rhino
+Version:  Trunk
+Description: Mozilla Rhino is an implementation of JavaScript for the JVM.
+Local Modifications: Minor changes to parsing JSDoc that usually get pushed
+up-stream to Rhino trunk.
+Code in:
+lib/args4j.jar
+Args4j
+URL: https://args4j.dev.java.net/
+Version: 2.0.16
+License: MIT
+Description:
+args4j is a small Java class library that makes it easy to parse command line
+options/arguments in your CUI application.
+Local Modifications: None.
+Code in:
+lib/guava.jar
+Guava Libraries
+URL: http://code.google.com/p/guava-libraries/
+Version:  14.0
+License: Apache License 2.0
+Description: Google's core Java libraries.
+Code in:
+lib/jsr305.jar
+Annotations for software defect detection
+URL: http://code.google.com/p/jsr-305/
+Version: svn revision 47
+License: BSD License
+Description: Annotations for software defect detection.
+Code in:
+lib/jarjar.jar
+Jar Jar Links
+URL: http://jarjar.googlecode.com/
+Version: 1.1
+Description:
+A utility for repackaging Java libraries.
+Code in:
+lib/junit.jar
+JUnit
+URL:  http://sourceforge.net/projects/junit/
+Version:  4.10
+License:  Common Public License 1.0
+Description: A framework for writing and running automated tests in Java.
+Code in:
+lib/protobuf-java.jar
+Protocol Buffers
+URL: http://code.google.com/p/protobuf/
+Version: 2.4.1
+License: New BSD License
+Description: Supporting libraries for protocol buffers,
+an encoding of structured data.
+Code in:
+lib/ant.jar
+lib/ant-launcher.jar
+URL: http://ant.apache.org/bindownload.cgi
+Version: 1.8.1
+Description:
+  Ant is a Java based build tool. In theory it is kind of like "make"
+  without make's wrinkles and with the full portability of pure java code.
+Code in:
+lib/json.jar
+URL: http://json.org/java/index.html
+Version: JSON version 20090211
+License: MIT license
+Description:
+JSON is a set of java files for use in transmitting data in JSON format.
+Code in:
+tools/maven-ant-tasks-2.1.3.jar
+URL: http://maven.apache.org
+Version 2.1.3
+Description:
+  Maven Ant tasks are used to manage dependencies and to install/deploy to
+  maven repositories.
Copied: trunk/utils/compiler.jar (from rev 2795, sandbox/closure/utils/compiler.jar)
(Binary files differ)
More information about the fusion-commits mailing list
