[fusion-commits] r2788 - in trunk: layers/MapGuide text widgets/Redline widgets/Redline/classes widgets/Redline/templates
svn_fusion at osgeo.org
Wed Sep 18 23:01:58 PDT 2013
Author: jng
Date: 2013-09-18 23:01:58 -0700 (Wed, 18 Sep 2013)
New Revision: 2788
trunk/layers/MapGuide/MapGuideViewerApi.js
trunk/text/en
trunk/widgets/Redline/classes/markupeditor.php
trunk/widgets/Redline/editmarkup.php
trunk/widgets/Redline/templates/markuplayerdefinition_advanced.xml
#595, #597: Merge sandbox changes r2785, r2786 and r2787 to trunk
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2013-09-19 05:17:50 UTC (rev 2787)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2013-09-19 06:01:58 UTC (rev 2788)
@@ -51,11 +51,11 @@
-function SetSelectionXML(selectionXml) {
+function SetSelectionXML(selectionXml, bDoNotZoom) {
//var Fusion = window.top.Fusion;
var mapWidget = GetFusionMapWidget();
if (mapWidget && mapWidget.isMapLoaded()) {
- mapWidget.setSelection(selectionXml, true);
+ mapWidget.setSelection(selectionXml, !(bDoNotZoom || false));
Modified: trunk/text/en
--- trunk/text/en 2013-09-19 05:17:50 UTC (rev 2787)
+++ trunk/text/en 2013-09-19 06:01:58 UTC (rev 2788)
@@ -332,6 +332,8 @@
REDLINEDELETEOBJECT = Delete
REDLINEUPDATETEXT = Update Text
REDLINEEDITCLOSE = Close
+REDLINENOTEXT = no text
+REDLINEMULTISELECTHELP = To select multiple redline objects in the list above, hold down the CTRL key while selecting. To select a range of items, hold down the SHIFT key and select the first and last items.
# Redline Upload
REDLINEUPLOAD = Upload Redline
Modified: trunk/widgets/Redline/classes/markupeditor.php
--- trunk/widgets/Redline/classes/markupeditor.php 2013-09-19 05:17:50 UTC (rev 2787)
+++ trunk/widgets/Redline/classes/markupeditor.php 2013-09-19 06:01:58 UTC (rev 2788)
@@ -229,6 +229,20 @@
$result = $featureService->UpdateFeatures($featureSourceId, $commands, false);
MarkupEditor::CleanupReaders($result);
+ function BuildFeatureFilter($propName)
+ $ids = $this->args["MARKUPFEATURE"];
+ if (is_array($ids)) {
+ $filters = array();
+ foreach ($ids as $id) {
+ array_push($filters, "$propName = $id");
+ return join(" OR ", $filters);
+ } else {
+ return "$propName = $ids";
function DeleteMarkup()
@@ -242,7 +256,7 @@
$idName = $keyProp->GetName();
$commands = new MgFeatureCommandCollection();
- $commands->Add(new MgDeleteFeatures('Markup', $idName . ' = ' . $this->args['MARKUPFEATURE']));
+ $commands->Add(new MgDeleteFeatures('Markup', $this->BuildFeatureFilter($idName)));
@@ -263,7 +277,7 @@
$propertyValues->Add(new MgStringProperty('Text', trim($this->args['UPDATETEXT'])));
- $commands->Add(new MgUpdateFeatures('Markup', $propertyValues, $idName . ' = ' . $this->args['MARKUPFEATURE']));
+ $commands->Add(new MgUpdateFeatures('Markup', $propertyValues, $this->BuildFeatureFilter($idName)));
@@ -278,8 +292,15 @@
$markupLayer = $map->GetLayers()->GetItem('_' . $this->GetMarkupName());
$selection = new MgSelection($map);
- $selection->AddFeatureIdInt32($markupLayer, $markupLayer->GetFeatureClassName(), (int) $this->args['MARKUPFEATURE']);
+ $className = $markupLayer->GetFeatureClassName();
+ $ids = $this->args['MARKUPFEATURE'];
+ $selection->AddFeatureIdInt32($markupLayer, $className, (int) $id);
+ } else {
+ $selection->AddFeatureIdInt32($markupLayer, $className, (int) $ids);
return $selection->ToXML();
Modified: trunk/widgets/Redline/editmarkup.php
--- trunk/widgets/Redline/editmarkup.php 2013-09-19 05:17:50 UTC (rev 2787)
+++ trunk/widgets/Redline/editmarkup.php 2013-09-19 06:01:58 UTC (rev 2788)
@@ -118,6 +118,8 @@
$closeLocal = GetLocalizedString('REDLINEEDITCLOSE', $locale );
$promptLabelLocal = GetLocalizedString('REDLINEPROMPTLABEL', $locale);
$promptRedlineLabelsLocal = GetLocalizedString('REDLINEPROMPTFORLABELS', $locale);
+ $noTextLocal = GetLocalizedString('REDLINENOTEXT', $locale);
+ $multiHelpLocal = GetLocalizedString('REDLINEMULTISELECTHELP', $locale);
if (array_key_exists("REDLINEPROMPT", $args) && strcmp($args["REDLINEPROMPT"], "on") == 0) {
$checkState = " checked='checked'";
@@ -330,14 +332,33 @@
SubmitCommand(CMD_ADD_POLYGON);
+ function TrimString(str)
+ return (typeof String.prototype.trim == 'undefined') ? str.replace(/^\s+|\s+$/g, '') : str.trim();
+ function GetSelectedMarkupIds(mkEl)
+ var ids = [];
+ for (var i = 0; i < mkEl.options.length; i++) {
+ if (mkEl.options[i].selected) {
+ ids.push(mkEl.options[i].value);
+ return ids;
function SelectMarkup()
markupFeatures = document.getElementById("markupFeatures");
+ var featIds = GetSelectedMarkupIds(markupFeatures);
reqParams = "MAPNAME=" + encodeURIComponent(mapName);
reqParams += "&SESSION=" + encodeURIComponent(session);
reqParams += "&OPENMARKUP=" + encodeURIComponent('<?= $args['OPENMARKUP']; ?>');
- reqParams += "&MARKUPFEATURE=" + markupFeatures.value;
+ //reqParams += "&MARKUPFEATURE=" + markupFeatures.value;
+ for (var i = 0; i < featIds.length; i++) {
+ reqParams += "&MARKUPFEATURE[]=" + featIds[i];
if(msie)
reqHandler = new ActiveXObject("Microsoft.XMLHTTP");
@@ -350,7 +371,7 @@
reqHandler.send(reqParams);
if(reqHandler.responseXML)
- SetSelectionXML(reqHandler.responseText);
+ SetSelectionXML(reqHandler.responseText, true /*bDoNotZoom*/);
@@ -387,10 +408,16 @@
if (markupFeatures.selectedIndex >= 0)
value = markupFeatures.options[markupFeatures.selectedIndex].text;
- if (value != '[no text]')
- updateTextInput.value = value;
- else
+ if (value.indexOf('[<?= $noTextLocal ?>]') < 0) {
+ var tokens = value.split(":");
+ if (tokens.length == 2) {
+ updateTextInput.value = TrimString(tokens[1]);
+ } else {
+ updateTextInput.value = value;
+ } else {
updateTextInput.value = '';
selectBtn.disabled = false;
deleteBtn.disabled = false;
@@ -426,7 +453,6 @@
</head>
<body onLoad="OnLoad()" onUnload="OnUnload()" marginwidth=5 marginheight=5 leftmargin=5 topmargin=5 bottommargin=5 rightmargin=5>
<form action="editmarkup.php" method="post" enctype="application/x-www-form-urlencoded" id="editForm" target="_self">
<table class="RegText" border="0" cellspacing="0" width="100%">
<tr>
@@ -479,12 +505,12 @@
</tr>
<tr>
<td class="RegText">
- <select name="MARKUPFEATURE" size="15" class="Ctrl" id="markupFeatures" onChange="OnMarkupFeatureChange()" style="width: 100%">
+ <select name="MARKUPFEATURE[]" size="15" class="Ctrl" id="markupFeatures" onChange="OnMarkupFeatureChange()" multiple="multiple" style="width: 100%">
<?php
$selected = 'selected';
foreach($markupFeatures as $markupId => $markupText) {
- <option value="<?= $markupId ?>" <?=$selected ?> ><?= (strlen($markupText) > 0) ? htmlentities($markupText, ENT_COMPAT, 'UTF-8') : '[no text]' ?></option>
+ <option value="<?= $markupId ?>" <?=$selected ?> ><?= (strlen($markupText) > 0) ? "$markupId: ".htmlentities($markupText, ENT_COMPAT, 'UTF-8') : "$markupId: [$noTextLocal]" ?></option>
<?php
$selected = '';
@@ -494,6 +520,10 @@
</tr>
<tr><td colspan="2" height="2px"></td></tr>
<tr>
+ <td class="InfoText" colspan="2"><?= $multiHelpLocal ?></td>
+ </tr>
+ <tr><td colspan="2" height="2px"></td></tr>
+ <tr>
<td colspan="2">
<input class="Ctrl" id="selectBtn" type="button" onClick="SelectMarkup()" value="<?=$selectLocal?>" style="width:85px">
<input class="Ctrl" id="deleteBtn" type="button" onClick="DeleteMarkup()" value="<?=$deleteLocal?>" style="width:85px">
Modified: trunk/widgets/Redline/templates/markuplayerdefinition_advanced.xml
--- trunk/widgets/Redline/templates/markuplayerdefinition_advanced.xml 2013-09-19 05:17:50 UTC (rev 2787)
+++ trunk/widgets/Redline/templates/markuplayerdefinition_advanced.xml 2013-09-19 06:01:58 UTC (rev 2788)
@@ -768,11 +768,11 @@
<Markup>'MTEXT'</Markup>
</Text>
</Graphics>
- <LineUsage>
- <AngleControl>'FromAngle'</AngleControl>
+ <AreaUsage>
<Angle>%ROTATION%</Angle>
- <Repeat>1.0</Repeat>
- </LineUsage>
+ <RepeatX>100.0</RepeatX>
+ <RepeatY>100.0</RepeatY>
+ </AreaUsage>
<ParameterDefinition>
<Parameter>
<Identifier>CONTENT</Identifier>
More information about the fusion-commits
