[fusion-commits] r2789 - in trunk/lib/OpenLayers: . ext/OpenLayers/Layer ext/OpenLayers/Layer/Google
svn_fusion at osgeo.org
Thu Sep 19 01:14:34 PDT 2013
Author: jng
Date: 2013-09-19 01:14:34 -0700 (Thu, 19 Sep 2013)
New Revision: 2789
Added:
trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google/
trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js
trunk/lib/OpenLayers/OpenLayers.js
#596: Disable tilt in Google layers. Checked in a patched v3.js (2.12 with this patch applied: http://trac.osgeo.org/openlayers/ticket/3615) and a new OpenLayers.js with this patch Google layer built in.
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2013-09-19 06:01:58 UTC (rev 2788)
+++ trunk/lib/OpenLayers/OpenLayers.js 2013-09-19 08:14:34 UTC (rev 2789)
@@ -39782,6 +39782,14 @@
animationEnabled: true,
+ * APIProperty: enableTilt
+ * {Boolean} If set to true, Google's 45-degree tilt view will be enabled.
+ * Default is false, which disables 45-degree tilt.
+ * Note that enabling 45-degree tilt may cause problems with overlays and markers matching up to the map.
+ enableTilt: false,
* Method: loadMapObject
* Load the GMap and register appropriate event listeners. If we can't
@@ -39825,6 +39833,8 @@
streetViewControl: false
+ if (!this.enableTilt) mapObject.setTilt(0);
// cache elements for use by any other google layers added to
// this same map
cache = {
Property changes on: trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google
___________________________________________________________________
Added: bugtraq:number
+ true
Added: trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js
--- trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js (rev 0)
+++ trunk/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js 2013-09-19 08:14:34 UTC (rev 2789)
@@ -0,0 +1,477 @@
+/* Copyright (c) 2006-2012 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the 2-clause BSD license.
+ * See license.txt in the OpenLayers distribution or repository for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/Google.js
+ * Constant: OpenLayers.Layer.Google.v3
+ * Mixin providing functionality specific to the Google Maps API v3.
+ * To use this layer, you must include the GMaps v3 API in your html.
+ * Because OpenLayers needs to control mouse events, it isolates the GMaps mapObject
+ * (the DOM elements provided by Google) using the EventPane.
+ * However, because the Terms of Use require some of those elements,
+ * such as the links to Google's terms, to be clickable, these elements have
+ * to be moved up to OpenLayers' container div. There is however no easy way
+ * to identify these, and the logic (see the repositionMapElements function
+ * in the source) may need to be changed if Google changes them.
+ * These elements are not part of the published API and can be changed at any time,
+ * so a given OpenLayers release can only guarantee support for the 'frozen'
+ * Google release at the time of the OpenLayers release. See
+ * https://developers.google.com/maps/documentation/javascript/basics#Versioning
+ * for Google's current release cycle.
+ * For this reason, it's recommended that production code specifically loads
+ * the current frozen version, for example:
+ * (code)
+ * <script src="http://maps.google.com/maps/api/js?v=3.7&sensor=false"></script>
+ * (end)
+ * but that development code should use the latest 'nightly' version, so that any
+ * problems can be dealt with as soon as they arise, and before they affect the production, 'frozen', code.
+ * Note, however, that frozen versions are retired as part of Google's release
+ * cycle, and once this happens, you will get the next version, in the example above, 3.8 once 3.7 is retired.
+ * This version supports 3.7.
+ * Note that this layer configures the google.maps.map object with the
+ * "disableDefaultUI" option set to true. Using UI controls that the Google
+ * Maps API provides is not supported by the OpenLayers API.
+OpenLayers.Layer.Google.v3 = {
+ * Constant: DEFAULTS
+ * {Object} It is not recommended to change the properties set here. Note
+ * that Google.v3 layers only work when sphericalMercator is set to true.
+ * (code)
+ * sphericalMercator: true,
+ * projection: "EPSG:900913"
+ * (end)
+ DEFAULTS: {
+ sphericalMercator: true,
+ projection: "EPSG:900913"
+ * APIProperty: animationEnabled
+ * {Boolean} If set to true, the transition between zoom levels will be
+ * animated (if supported by the GMaps API for the device used). Set to
+ * false to match the zooming experience of other layer types. Default
+ * is true. Note that the GMaps API does not give us control over zoom
+ * animation, so if set to false, when zooming, this will make the
+ * layer temporarily invisible, wait until GMaps reports the map being
+ * idle, and make it visible again. The result will be a blank layer
+ * for a few moments while zooming.
+ animationEnabled: true,
+ * Method: loadMapObject
+ * Load the GMap and register appropriate event listeners. If we can't
+ * load GMap2, then display a warning message.
+ loadMapObject:function() {
+ if (!this.type) {
+ this.type = google.maps.MapTypeId.ROADMAP;
+ var mapObject;
+ var cache = OpenLayers.Layer.Google.cache[this.map.id];
+ if (cache) {
+ // there are already Google layers added to this map
+ mapObject = cache.mapObject;
+ // increment the layer count
+ ++cache.count;
+ } else {
+ // this is the first Google layer for this map
+ var container = this.map.viewPortDiv;
+ var div = document.createElement("div");
+ div.id = this.map.id + "_GMapContainer";
+ div.style.position = "absolute";
+ div.style.width = "100%";
+ div.style.height = "100%";
+ container.appendChild(div);
+ // create GMap and shuffle elements
+ var center = this.map.getCenter();
+ mapObject = new google.maps.Map(div, {
+ center: center ?
+ new google.maps.LatLng(center.lat, center.lon) :
+ new google.maps.LatLng(0, 0),
+ zoom: this.map.getZoom() || 0,
+ mapTypeId: this.type,
+ disableDefaultUI: true,
+ keyboardShortcuts: false,
+ draggable: false,
+ disableDoubleClickZoom: true,
+ scrollwheel: false,
+ streetViewControl: false
+ // cache elements for use by any other google layers added to
+ // this same map
+ cache = {
+ mapObject: mapObject,
+ count: 1
+ OpenLayers.Layer.Google.cache[this.map.id] = cache;
+ this.repositionListener = google.maps.event.addListenerOnce(
+ mapObject,
+ "center_changed",
+ OpenLayers.Function.bind(this.repositionMapElements, this)
+ this.mapObject = mapObject;
+ this.setGMapVisibility(this.visibility);
+ * Method: repositionMapElements
+ * Waits until powered by and terms of use elements are available and then
+ * moves them so they are clickable.
+ repositionMapElements: function() {
+ // This is the first time any Google layer in this mapObject has been
+ // made visible. The mapObject needs to know the container size.
+ google.maps.event.trigger(this.mapObject, "resize");
+ var div = this.mapObject.getDiv().firstChild;
+ if (!div || div.childNodes.length < 3) {
+ this.repositionTimer = window.setTimeout(
+ OpenLayers.Function.bind(this.repositionMapElements, this),
+ 250
+ return false;
+ // move the ToS and branding stuff up to the container div
+ // depends on value of zIndex, which is not robust
+ for (var i=div.children.length-1; i>=0; --i) {
+ if (div.children[i].style.zIndex == 1000001) {
+ var termsOfUse = div.children[i];
+ container.appendChild(termsOfUse);
+ termsOfUse.style.zIndex = "1100";
+ termsOfUse.style.bottom = "";
+ termsOfUse.className = "olLayerGoogleCopyright olLayerGoogleV3";
+ termsOfUse.style.display = "";
+ cache.termsOfUse = termsOfUse;
+ if (div.children[i].style.zIndex == 1000000) {
+ var poweredBy = div.children[i];
+ container.appendChild(poweredBy);
+ poweredBy.style.zIndex = "1100";
+ poweredBy.style.bottom = "";
+ poweredBy.className = "olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";
+ poweredBy.style.display = "";
+ cache.poweredBy = poweredBy;
+ if (div.children[i].style.zIndex == 10000002) {
+ container.appendChild(div.children[i]);
+ * APIMethod: onMapResize
+ onMapResize: function() {
+ if (this.visibility) {
+ } else {
+ if (!cache.resized) {
+ var layer = this;
+ google.maps.event.addListenerOnce(this.mapObject, "tilesloaded", function() {
+ google.maps.event.trigger(layer.mapObject, "resize");
+ layer.moveTo(layer.map.getCenter(), layer.map.getZoom());
+ delete cache.resized;
+ cache.resized = true;
+ * Method: setGMapVisibility
+ * Display the GMap container and associated elements.
+ * Parameters:
+ * visible - {Boolean} Display the GMap elements.
+ setGMapVisibility: function(visible) {
+ if (cache) {
+ var type = this.type;
+ var layers = this.map.layers;
+ var layer;
+ for (var i=layers.length-1; i>=0; --i) {
+ layer = layers[i];
+ if (layer instanceof OpenLayers.Layer.Google &&
+ layer.visibility === true && layer.inRange === true) {
+ type = layer.type;
+ visible = true;
+ break;
+ var container = this.mapObject.getDiv();
+ if (visible === true) {
+ this.mapObject.setMapTypeId(type);
+ container.style.left = "";
+ if (cache.termsOfUse && cache.termsOfUse.style) {
+ cache.termsOfUse.style.left = "";
+ cache.termsOfUse.style.display = "";
+ cache.poweredBy.style.display = "";
+ cache.displayed = this.id;
+ } else {
+ delete cache.displayed;
+ container.style.left = "-9999px";
+ cache.termsOfUse.style.display = "none";
+ // move ToU far to the left in addition to setting
+ // display to "none", because at the end of the GMap
+ // load sequence, display: none will be unset and ToU
+ // would be visible after loading a map with a google
+ // layer that is initially hidden.
+ cache.termsOfUse.style.left = "-9999px";
+ cache.poweredBy.style.display = "none";
+ * Method: getMapContainer
+ * Returns:
+ * {DOMElement} the GMap container's div
+ getMapContainer: function() {
+ return this.mapObject.getDiv();
+ // TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
+ * APIMethod: getMapObjectBoundsFromOLBounds
+ * Parameters:
+ * olBounds - {<OpenLayers.Bounds>}
+ * Returns:
+ * {Object} A MapObject Bounds, translated from olBounds
+ * Returns null if null value is passed in
+ getMapObjectBoundsFromOLBounds: function(olBounds) {
+ var moBounds = null;
+ if (olBounds != null) {
+ var sw = this.sphericalMercator ?
+ this.inverseMercator(olBounds.bottom, olBounds.left) :
+ new OpenLayers.LonLat(olBounds.bottom, olBounds.left);
+ var ne = this.sphericalMercator ?
+ this.inverseMercator(olBounds.top, olBounds.right) :
+ new OpenLayers.LonLat(olBounds.top, olBounds.right);
+ moBounds = new google.maps.LatLngBounds(
+ new google.maps.LatLng(sw.lat, sw.lon),
+ new google.maps.LatLng(ne.lat, ne.lon)
+ return moBounds;
+ * MapObject Interface Controls *
+ // LonLat - Pixel Translation
+ * APIMethod: getMapObjectLonLatFromMapObjectPixel
+ * Parameters:
+ * moPixel - {Object} MapObject Pixel format
+ * Returns:
+ * {Object} MapObject LonLat translated from MapObject Pixel
+ getMapObjectLonLatFromMapObjectPixel: function(moPixel) {
+ var size = this.map.getSize();
+ var lon = this.getLongitudeFromMapObjectLonLat(this.mapObject.center);
+ var lat = this.getLatitudeFromMapObjectLonLat(this.mapObject.center);
+ var res = this.map.getResolution();
+ var delta_x = moPixel.x - (size.w / 2);
+ var delta_y = moPixel.y - (size.h / 2);
+ var lonlat = new OpenLayers.LonLat(
+ lon + delta_x * res,
+ lat - delta_y * res
+ if (this.wrapDateLine) {
+ lonlat = lonlat.wrapDateLine(this.maxExtent);
+ return this.getMapObjectLonLatFromLonLat(lonlat.lon, lonlat.lat);
+ * APIMethod: getMapObjectPixelFromMapObjectLonLat
+ * Parameters:
+ * moLonLat - {Object} MapObject LonLat format
+ * Returns:
+ * {Object} MapObject Pixel transtlated from MapObject LonLat
+ getMapObjectPixelFromMapObjectLonLat: function(moLonLat) {
+ var lon = this.getLongitudeFromMapObjectLonLat(moLonLat);
+ var lat = this.getLatitudeFromMapObjectLonLat(moLonLat);
+ var extent = this.map.getExtent();
+ return this.getMapObjectPixelFromXY((1/res * (lon - extent.left)),
+ (1/res * (extent.top - lat)));
+ * APIMethod: setMapObjectCenter
+ * Set the mapObject to the specified center and zoom
+ * Parameters:
+ * center - {Object} MapObject LonLat format
+ * zoom - {int} MapObject zoom format
+ setMapObjectCenter: function(center, zoom) {
+ if (this.animationEnabled === false && zoom != this.mapObject.zoom) {
+ var mapContainer = this.getMapContainer();
+ this.mapObject,
+ "idle",
+ function() {
+ mapContainer.style.visibility = "";
+ mapContainer.style.visibility = "hidden";
+ this.mapObject.setOptions({
+ center: center,
+ zoom: zoom
+ // Bounds
+ * APIMethod: getMapObjectZoomFromMapObjectBounds
+ * Parameters:
+ * moBounds - {Object} MapObject Bounds format
+ * Returns:
+ * {Object} MapObject Zoom for specified MapObject Bounds
+ getMapObjectZoomFromMapObjectBounds: function(moBounds) {
+ return this.mapObject.getBoundsZoomLevel(moBounds);
+ * MapObject Primitives *
+ // LonLat
+ * APIMethod: getMapObjectLonLatFromLonLat
+ * Parameters:
+ * lon - {Float}
+ * lat - {Float}
+ * Returns:
+ * {Object} MapObject LonLat built from lon and lat params
+ getMapObjectLonLatFromLonLat: function(lon, lat) {
+ var gLatLng;
+ if(this.sphericalMercator) {
+ var lonlat = this.inverseMercator(lon, lat);
+ gLatLng = new google.maps.LatLng(lonlat.lat, lonlat.lon);
+ } else {
+ gLatLng = new google.maps.LatLng(lat, lon);
+ return gLatLng;
+ // Pixel
+ * APIMethod: getMapObjectPixelFromXY
+ * Parameters:
+ * x - {Integer}
+ * y - {Integer}
+ * Returns:
+ * {Object} MapObject Pixel from x and y parameters
+ getMapObjectPixelFromXY: function(x, y) {
+ return new google.maps.Point(x, y);
+ * APIMethod: destroy
+ * Clean up this layer.
+ destroy: function() {
+ if (this.repositionListener) {
+ google.maps.event.removeListener(this.repositionListener);
+ if (this.repositionTimer) {
+ window.clearTimeout(this.repositionTimer);
+ OpenLayers.Layer.Google.prototype.destroy.apply(this, arguments);
More information about the fusion-commits
