[fusion-dev] Question about GxSelectionObjectLayer
Daniel Morissette
dmorissette at mapgears.com
Tue Apr 1 10:33:39 EDT 2008
Mike Adair wrote:
> That is correct for MapGuide: propertyNames is the unaliased property
> name, propertyValues are the mapped property names and
> o[layerName].values contains the actual values for each property.
> Hopefully the MapServer version can be set up similarly?
From a pure software engineering perspective, without knowing much
about that specific code and how it works, don't you think that
"propertyValues" is a poor variable name for "the mapped property
names"? Could the variable not be changed to something more meaningful,
and especially not something as misleading as *value when it is really a
*name? Good variable names should help prevent bugs in the future... I'm
hoping we could avoid repeating the ka-Map maths obfuscation mistakes.
Perhaps "propertyValues" makes some sense in the context in which it is
used in the code, if that's the case then please disregard my comment
and I apologize for the noise in advance.
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the fusion-dev
