[fusion-dev] Question about GxSelectionObjectLayer
Mike Adair
madair at dmsolutions.ca
Tue Apr 1 09:59:22 EDT 2008
That is correct for MapGuide: propertyNames is the unaliased property
name, propertyValues are the mapped property names and
o[layerName].values contains the actual values for each property.
Hopefully the MapServer version can be set up similarly?
Mike
Paul Spencer wrote:
> Hi Alan,
> I was able to piece this together from a couple of sources. Assefa
> originally set it to propertynames as part of implementing support for
> selections being stored in the session and possibly coming back
> paginated (requesting a sub-set of the selection). Then Mike fixed a
> bug related to using display names rather than field names with
> mapguide that changed it from propertynames to propertyvalues.
> I believe that the mapguide code is assuming that propertynames
> contains the original (unaliased) names and propertyvalues contains
> the alias for the property name.
> Does this help?
> Paul
> On 31-Mar-08, at 2:11 PM, Alan Boudreault wrote:
>> Hi,
>> After updating my sandbox the trunk this morning, and test my new
>> feature in the ticket #24 ( http://trac.osgeo.org/fusion/ticket/24 ).
>> I just notice something is going wrong with Propertyies name of a
>> query. After a moment, i notice that in the Map.js file of Fusion. In
>> the initialize() method of GxSelectionObjectLayer. Is there a reason
>> for using:
>> *this.aPropertiesName = o[layerName].propertyvalues;*
>> instead of
>> this.aPropertiesName = o[layerName].propertynames;*
>> Thanks ,
>> Alan
>> Alan Boudreault
>> Mapgears
>> http://www.mapgears.com
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
More information about the fusion-dev
