[fusion-dev] InitialView?
Paul Spencer
pspencer at dmsolutions.ca
Mon Apr 7 12:01:25 EDT 2008
The docs directory is sorely out of date and needs some attention,
that file should probably be deleted.
Paul
On 7-Apr-08, at 11:54 AM, Jason Birch wrote:
> Thanks Paul, I'll update the docs to describe InitialView.
> Just noticed something else odd. The ApplicationDefinition in the
> docs
> directory:
> http://trac.osgeo.org/fusion/browser/trunk/docs/ApplicationDefinition.xm
> l
> uses Map and Layer instead of MapGroup and Map. Is this correct?
> Does
> this document need to be there?
> Jason
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Monday, April 07, 2008 08:34
> To: Jason Birch
> Cc: fusion-dev at lists.osgeo.org
> Subject: Re: [fusion-dev] InitialView?
> Jason,
> just checked the code, it will look for CenterX, CenterY and Scale and
> if *all* are present it will use them, otherwise it looks for MinX,
> MinY, MaxX, MaxY and if *all* are present it will use them.
> If any of the values are missing from a group, it will ignore that
> group.
> It will use CenterX, CenterY, Scale in preference to the extent
> version if both exist.
> Sounds like the schema needs an update.
> Cheers
> Paul
> On 7-Apr-08, at 11:14 AM, Jason Birch wrote:
>> Hi there,
>> I have a fusion map that uses InitialView of a MapGroup like this:
>> <MapGroup id="NanaimoCemeteries">
>> <InitialView>
>> <MinX>430379</MinX>
>> <MinY>5446616</MinY>
>> <MaxX>430541</MaxX>
>> <MaxY>5446915</MaxY>
>> </InitialView>
>> </MapGroup>
>> But the schema's type for InitialView is MapViewType:
>> <xs:complexType name="MapViewType">
>> <xs:sequence>
>> <xs:element name="CenterX" type="xs:double"/>
>> <xs:element name="CenterY" type="xs:double"/>
>> <xs:element name="Scale" type="xs:double"/>
>> </xs:sequence>
>> </xs:complexType>
>> Neither of these are documented (yet):
>> http://trac.osgeo.org/fusion/wiki/ApplicationDefinition/MapSet/
>> MapGroup
>> I'd be happy to write both up if someone can clarify that they are
>> both
>> acceptable. I certainly wouldn't want to see the extents version go
>> away; midpoint+scale doesn't allow you to ensure that a specific
>> object
>> will stay on the screen on various resolutions, etc.
>> Jason
>> fusion-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
Paul Spencer
More information about the fusion-dev
