[fusion-dev] InitialView?
Jason Birch Jason.Birch at nanaimo.ca
Mon Apr 7 11:54:08 EDT 2008
Thanks Paul, I'll update the docs to describe InitialView.
Just noticed something else odd.  The ApplicationDefinition in the docs
directory:
http://trac.osgeo.org/fusion/browser/trunk/docs/ApplicationDefinition.xm
l
uses Map and Layer instead of MapGroup and Map.  Is this correct?  Does
this document need to be there?
Jason
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Monday, April 07, 2008 08:34
To: Jason Birch
Cc: fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] InitialView?
Jason,
just checked the code, it will look for CenterX, CenterY and Scale and
if *all* are present it will use them, otherwise it looks for MinX,
MinY, MaxX, MaxY and if *all* are present it will use them.
If any of the values are missing from a group, it will ignore that
group.
It will use CenterX, CenterY, Scale in preference to the extent
version if both exist.
Sounds like the schema needs an update.
Cheers
Paul
On 7-Apr-08, at 11:14 AM, Jason Birch wrote:
> Hi there,
> I have a fusion map that uses InitialView of a MapGroup like this:
>    <MapGroup id="NanaimoCemeteries">
>      <InitialView>
>        <MinX>430379</MinX>
>        <MinY>5446616</MinY>
>        <MaxX>430541</MaxX>
>        <MaxY>5446915</MaxY>
>      </InitialView>
>    </MapGroup>
> But the schema's type for InitialView is MapViewType:
>  <xs:complexType name="MapViewType">
>     <xs:sequence>
>       <xs:element name="CenterX" type="xs:double"/>
>       <xs:element name="CenterY" type="xs:double"/>
>       <xs:element name="Scale" type="xs:double"/>
>     </xs:sequence>
>   </xs:complexType>
> Neither of these are documented (yet):
> http://trac.osgeo.org/fusion/wiki/ApplicationDefinition/MapSet/
> MapGroup
> I'd be happy to write both up if someone can clarify that they are
> both
> acceptable.  I certainly wouldn't want to see the extents version go
> away; midpoint+scale doesn't allow you to ensure that a specific
> object
> will stay on the screen on various resolutions, etc.
> Jason
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-dev mailing list
