[fusion-dev] Re: [fusion-users] fusion 1.1 planning
Paul Spencer
pspencer at dmsolutions.ca
Tue May 6 16:01:02 EDT 2008
Hey Julien,
there is already a CanvasTool class that provides client side vector
capability on which you could create drawing and editing tools. I use
the CanvasTool class as a mix-in to SelectPolygon (for instance).
I would love to get this updated (or replaced) to use Layer.Vector and
provide widgets for the vector editing stuff but I don't know if I
will have time - if you are willing to work on it, I would work with
you on it.
Cheers
Paul
On 6-May-08, at 3:20 PM, Julien-Samuel Lacroix wrote:
> > * implement support for other OpenLayers layer types through the
> > MapGroup tag in the ApplicationDefinition
> Hi,
> What a coincidence! :) After demo-ing Fusion to a client last
> Friday, a question raised. Is it possible to use vector edition
> features from OpenLayers inside Fusion?
> Currently it's not possible. From what you write here, it would be
> possible to add OpenLayers layers on the top of a Fusion map. Could
> we then add a Vector layer and use the vector edition controls? I
> guess that would need a new widget for vector edition, right?
> Can you give us more details?
> Julien
> Mapgears
> http://www.mapgears.com/
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the fusion-dev
