[fusion-dev] Mapguide Tiled Map Legends - redundant checkboxes
Zac Spitzer
zac.spitzer at gmail.com
Thu Nov 6 21:10:41 EST 2008
Looking at 1.1 with a sheboygan sample suign the tiled map ( it's not in the
sample,
you need to create one)
Individual layers are presented with check boxes which has can have no
effect with a tiled layer
Also when there is only one baselayer group, it doesn't need to have a
checkbox as you can't
turn off the base layer
I filed a bug http://trac.osgeo.org/fusion/ticket/163
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20081107/4e38cc89/attachment.html
More information about the fusion-dev
