[fusion-dev] Fusion 1.1 Status
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 22 08:32:47 EDT 2008
the mg 2.1 release is why i was putting my hand up to test 1.1 :)
what I was suggesting with subversion is an easy way for someone like
myself who
is happy to update often to just replace the current fusion tree in
mapguide with a version
directly checked out of the fusion ' builds' tree. rather than having
to build it from the svn src.
I am not really much of a fan of the way fusion and other things are
snapshoted version wise tied to
the long points between mapguide releases.
having the compiled builds in the subversion would allow me to do
something like this to a mg install
cd /mgos2.0/webserverextensions/wwww
mv fusion fusion_release
svn co http://svn.osgeo.org/fusion/builds/development fusion
that way I just have to svn update to grab the latest build to test
z
On Wed, Oct 22, 2008 at 10:40 PM, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> Hi Zac,
> I think Mike has been steadily working on bugs for 1.1 as well as finishing
> up features for 2.0.  I'd personally like to see 1.1 finalized soon, so if
> you want to do some testing that would help a lot.  One of the things we
> added to 1.1 was a compatibility mode for the existing templates so that it
> can be a drop-in replacement for the existing fusion code, which should make
> upgrading easier!
> I believe mgos 2.1 is tracking Fusion trunk which will be branched for a 2.0
> version shortly too, so my fears of 1.1 slipping between releases seem to
> have materialized, but no matter - both contain important code and 1.1 might
> get rolled into another 2.0 minor update if I can convince Tom its a good
> idea :)
> From this point forward, I believe that mgos is using svn externals to
> include fusion, so checking in built versions would only apply up to the
> current point in time I think (unless I am missing the point somehow)
> Paul
> On 22-Oct-08, at 4:05 AM, Zac Spitzer wrote:
>> How is 1.1 going?, it been a while since RC1 I'm happy to do some more
>> testing.
>> When 1.1 is released, I'm thinking about a few ideas which would make
>> adoption easier.
>> Once is to create a windows installer which is MGOS and MGE aware so
>> people can
>> easily update (replace) older fusion installs.
>> Secondly, what do people think about checking in built releases of
>> fusion into subversion?
>> builds\stable
>> builds\development
>> builds\1.06
>> builds\1.1RC1
>> That way users can a simple svn update to update fusion.
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://research.dmsolutions.ca/
Zac Spitzer -
+61 405 847 168
More information about the fusion-dev mailing list
