[fusion-dev] Is there a parameter missing in
Fusion.Layers.MapServer.getLegendImageURL(..)?
Bernhard Schneider
schneiderei at hispeed.ch
Wed Dec 16 02:58:20 EST 2009
Hello Fusioners,
Building a Fusion application on the basis of MapServer, and using the
Fusion 2 beta version I downloaded quite a while ago, I am having
problems with the legend rendering.
All layers that have classes defined in the mapfile are rendered in
the legend with one line per class, including icons showing the
symbols (line color and width, fill color and pattern, etc.) with
which the classes are drawn in the map. In my case, only the first
class of each layer has the correct icon, all the other have the same
icon as the first class.
Digging into the code, I found something confusing which I think may
be the cause for the problem:
-- The two methods
Fusion.Widget.Legend.LegendRendererDefault.updateLayer and
Fusion.Widget.Legend.LegendRendererDefault.createTreeItem call the
MapServer method Fusion.Layers.MapServer.getLegendImageURL, each time
passing three parameters for scale, layer, and style.
-- The method Fusion.Layers.MapServer.getLegendImageURL, as
implemented in MapServer.js, accepts only two parameters, namely
fScale and layer.
Perhaps, someone knowledgeable could have look at this?
Bernhard
More information about the fusion-dev
