[fusion-dev] Is there a parameter missing inFusion.Layers.MapServer.getLegendImageURL(..)?
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Wed Dec 16 08:16:59 EST 2009
Bernhard,
I would update to the latest trunk of Fusion. I have made a bunch of fixes for the Legend rendering and other items specific for MapServer.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
Sprint Nextel
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office:  616-656-5163
PCS:     616-706-2438
Support: 616-929-0289
Fax:     616-554-6484
-----Original Message-----
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Bernhard Schneider
Sent: Wednesday, December 16, 2009 2:58 AM
To: fusion-dev at lists.osgeo.org
Subject: [fusion-dev] Is there a parameter missing inFusion.Layers.MapServer.getLegendImageURL(..)?
Hello Fusioners,
Building a Fusion application on the basis of MapServer, and using the
Fusion 2 beta version I downloaded quite a while ago, I am having
problems with the legend rendering.
All layers that have classes defined in the mapfile are rendered in
the legend with one line per class, including icons showing the
symbols (line color and width, fill color and pattern, etc.) with
which the classes are drawn in the map. In my case, only the first
class of each layer has the correct icon, all the other have the same
icon as the first class.
Digging into the code, I found something confusing which I think may
be the cause for the problem:
-- The two methods
Fusion.Widget.Legend.LegendRendererDefault.updateLayer and
Fusion.Widget.Legend.LegendRendererDefault.createTreeItem call the
MapServer method Fusion.Layers.MapServer.getLegendImageURL, each time
passing three parameters for scale, layer, and style.
-- The method Fusion.Layers.MapServer.getLegendImageURL, as
implemented in MapServer.js, accepts only two parameters, namely
fScale and layer.
Perhaps, someone knowledgeable could have look at this?
Bernhard
fusion-dev mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
