[fusion-dev] RE: Integrate Commercial Map Service Layers Problem
Jason Birch
Jason.Birch at nanaimo.ca
Fri Jul 17 00:02:14 EDT 2009
Hey Arthur,
Are you using Fusion trunk? I believe that there were some defects or maybe missing code that prevented this from working with previous versions.
Zac recently updated the wiki page on this:
http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
Jason
Sent: Thursday, July 16, 2009 8:18 PM
Subject: [fusion-dev] Integrate Commercial Map Service Layers Problem
Is there anyone successfully integrated Yahoo or Virtual Earth in MapGuide?
I always got failed with error message as “OpenLayers.Layer[this.layerType](…)” is not a constructor, unless I add the script for openlayers(<script type="text/javascript" src="http://www.openlayers.org/api/OpenLayers.js"></script>) into the index.html in MG template . Any suggestions and comments are very appreciated. Thanks.
BTW, Google Layers doesn’t has such kind of problem.
Regards,
Arthur
More information about the fusion-dev
