[fusion-dev] RE: Integrate Commercial Map Service Layers Problem
Arthur Liu
arthur.liu at autodesk.com
Fri Jul 17 02:55:02 EDT 2009
Thanks for your reply.
I am using the lasted revision but still have that problem.
Regards,
Arthur
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, July 17, 2009 12:02 PM
To: Arthur Liu; fusion-dev at lists.osgeo.org
Subject: RE: Integrate Commercial Map Service Layers Problem
Hey Arthur,
Are you using Fusion trunk? I believe that there were some defects or maybe missing code that prevented this from working with previous versions.
Zac recently updated the wiki page on this:
http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
Jason
Sent: Thursday, July 16, 2009 8:18 PM
Subject: [fusion-dev] Integrate Commercial Map Service Layers Problem
Is there anyone successfully integrated Yahoo or Virtual Earth in MapGuide?
I always got failed with error message as "OpenLayers.Layer[this.layerType](...)" is not a constructor, unless I add the script for openlayers(<script type="text/javascript" src="http://www.openlayers.org/api/OpenLayers.js"></script>) into the index.html in MG template . Any suggestions and comments are very appreciated. Thanks.
BTW, Google Layers doesn't has such kind of problem.
Regards,
Arthur
More information about the fusion-dev
