[fusion-dev] RE: Integrate Commercial Map Service Layers Problem
Zac Spitzer
zac.spitzer at gmail.com
Fri Jul 17 03:16:37 EDT 2009
I didn't do the wiki page :)
fusion uses a a profile to reduce the size of the file, all of OL is like 1mb..
http://trac.openlayers.org/wiki/Profiles
the build script for fusion will have a .cfg file which is called during the
build process, you will need to locate that in the fusion tree and add
in the layers you need
http://trac.osgeo.org/fusion/browser/trunk/fusion.cfg
remember you cannot use commerical maps with a password protected site,
subject to licensing
z
On Fri, Jul 17, 2009 at 4:55 PM, Arthur Liu<arthur.liu at autodesk.com> wrote:
> Thanks for your reply.
> I am using the lasted revision but still have that problem.
> Regards,
> Arthur
> -----Original Message-----
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Friday, July 17, 2009 12:02 PM
> To: Arthur Liu; fusion-dev at lists.osgeo.org
> Subject: RE: Integrate Commercial Map Service Layers Problem
> Hey Arthur,
> Are you using Fusion trunk? I believe that there were some defects or maybe missing code that prevented this from working with previous versions.
> Zac recently updated the wiki page on this:
> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> Jason
> ________________________________
> From: Arthur Liu
> Sent: Thursday, July 16, 2009 8:18 PM
> Subject: [fusion-dev] Integrate Commercial Map Service Layers Problem
> Is there anyone successfully integrated Yahoo or Virtual Earth in MapGuide?
> I always got failed with error message as "OpenLayers.Layer[this.layerType](...)" is not a constructor, unless I add the script for openlayers(<script type="text/javascript" src="http://www.openlayers.org/api/OpenLayers.js"></script>) into the index.html in MG template . Any suggestions and comments are very appreciated. Thanks.
> BTW, Google Layers doesn't has such kind of problem.
> Regards,
> Arthur
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-dev
