[fusion-dev] Wrong display of Mapguide map when BaseLayer (OpenLayer) is off
Zak James zjames at dmsolutions.ca
Tue Feb 9 15:05:06 EST 2010
I think this occurs because when you disable the Google layer, there is no base layer. Try setting the MapGuide layer's isBaseLayer setting to true.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
http://research.dmsolutions.ca
On 2010-02-06, at 2:17 PM, pcardinal wrote:
> When I close GoogleLayer in the Legend by unchecking it, the display of
> Mapguide features is erratic until the GoogleLayer is on again followed by a
> refresh. MapGuide features are PostGIS, SDF and Access data.
> I am using the "www\fusion\templates\mapguide\slate" directory with the
> following code in ApplicationDefinition.xml
>  <MapSet>
>    <MapGroup id="montreal">
>      <InitialView>
>        <CenterX>-8205000</CenterX>
>        <CenterY>5709400</CenterY>
>        <Scale>300000</Scale>
>      </InitialView>
>     <Map>
>        <Type>MapGuide</Type>
>        <SingleTile>true</SingleTile>
>        <Extension>
> <ResourceId>Library://Greffes/Cartes/greffes.MapDefinition</ResourceId>
>          <Options>
>            <isBaseLayer>false</isBaseLayer>
>            <projection>EPSG:900913</projection>
>          </Options>
>        </Extension>
>      </Map>
>      <Map>
>        <Type>Google</Type>
> 	<sphericalMercator>true</sphericalMercator>
>        <SingleTile>false</SingleTile>
>        <Extension>
>          <Options>
>            <name>GoogleLayer</name>
>            <type>G_HYBRID_MAP</type>
>          </Options>
>        </Extension>
>      </Map>
>      <Extension />
>    </MapGroup>
>  </MapSet>
> http://n2.nabble.com/file/n4526535/test1.png
> http://n2.nabble.com/file/n4526535/test2.png
> http://n2.nabble.com/file/n4526535/test3.png
> View this message in context: http://n2.nabble.com/Wrong-display-of-Mapguide-map-when-BaseLayer-OpenLayer-is-off-tp4526535p4526535.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
