[fusion-dev] Fusion release plans
Mike Adair madair at dmsolutions.ca
Wed Feb 24 14:40:43 EST 2010
Apologies, I got the version numbers messed up in the message below.
v2.0 will be released soon with Jx v2.0 and Fusion v2.1 will include Jx
v3.0
Mike
Mike Adair wrote:
> I've now got some time to devote to Fusion so we would like to propose
> the following plan for the next couple of releases of Fusion:
> v2.1 - which uses JxLib v2.0, to be released very soon, (say end of
> Feb?) with only blockers and high priority bugs being fixed before then
> v2.2 - which uses JxLib v3.0, release date TBD, will be the trunk
> after the release of v2.1
> As part of the process, I will be going through all the open tickets
> in the next few days and re-assigning the target milestone to 2.1, 2.2
> or future.  I will also be closing bugs that either I can't re-produce
> or don't seem relevant any longer.
> However, please note that triage process is just my opinion and if I
> close or move one of your issues incorrectly, please go ahead and
> change it back.  I helps immensely if the issue is easily reproducible
> - i.e. include exact steps to re-produce it, possible even including a
> MapGuide package if necessary.  As another OS developer on another
> project once told me, if he can't reproduce the issue within a few
> minutes, the issue is unlikely to ever be addressed.
> Similarly, if I move an issue to a future milestone and you feel it
> should be addressed for v2.1, please change it back to 2.1.  The
> intent is to get the issue list into reasonable shape and your help in
> doing that is appreciated.
> Cheers,
> Mike
More information about the fusion-dev mailing list
