[fusion-dev] Re: Recursion issue? with the legend updates
    Zac Spitzer
    zac.spitzer at gmail.com
    Thu Jul 15 23:30:24 EDT 2010
logged in trac
http://trac.osgeo.org/fusion/ticket/400
On 15 July 2010 12:17, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> Hey Zac
> the next version of fusion/jxlib that Mike has been working on has a more reasonable approach to populating the tree to accommodate this kind of situation (although I'm still not sure it would handle your case that gracefully ;)).  I don't believe that we looked at delaying the actual insert, I should go back and see if we can gain some performance by setting a flag that says don't insert the tree, just build it.  I know that the found the style updates excessive and added a freeze/thaw rendering pattern to prevent updates to the whole tree on every insert and that proved to be a huge performance gain.
> Cheers
> Paul
> On 2010-07-14, at 9:46 PM, Zac Spitzer wrote:
>> Ok, I found what was causing the issue... a database generated theme
>> had 891 layers which is obviously a bit ridiculous...
>> the lock up was being caused by excessive dom inserts and style updates
>> a solution to this would be to make all the style elements just one block
>> and insert that once, rather than a theme at a time. I'm not familiar with JX
>> enough to know if that's possible
>> On 14 July 2010 18:06, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> I am working thru an issue with a map i have, using the mapguide 2.2 beta
>>> at the moment.
>>> Basically when i drop below the scale of 20k, the browser will lock up
>>> for upwards
>>> of 35-60 seconds in the update legend.js code.
>>> So far after some profiling pain, i have worked out that commenting out the
>>> line below stops the problem
>>>    _update: function() {
>>>            //this.updateGroupLayers(map.layerRoot.groups[i], currentScale);
>>> I will continue my digging to see if I can work out what is causing the issue.
>>> Looks like some kind of nasty recursion or something
>>> Thought I'd touch base to see if anyone else has seen this
>>> regards
>>> z
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://research.dmsolutions.ca/
Zac Spitzer
+61 405 847 168
More information about the fusion-dev
