[fusion-dev] Re: [Code Review]: Print widget doesn't work with
IIS7
Kori Maleski
kori.maleski at gmail.com
Tue Mar 30 17:05:24 EDT 2010
On line 59 of Print.js:
Change
this.dialogContentURL = Fusion.getFusionURL() + widgetTag.location +
'Print/Print.html';
to
'Print/Print.php';
Rename the file Print.html to Print.php (change the extension)
That may work. IIS7 has an issue with GETs vs POSTs when utilizing html
pages.
Cheers,
Kori Maleski
On Tue, Mar 30, 2010 at 5:53 AM, TJmapper <tjordan at ddcwsa.com> wrote:
> I have an install of Mapguide Enterprise 2010 and I tried this code to no
> avail. My print dialog comes up blank still and i get a 404 error instead
> of
> a 400. Mine is still looking for the Print/Print.HTML I believe.
> Are there any other tricks with the Print.js I should try? Maybe there is
> something i am missing, but i can completely remove the Print.js file and
> it
> comes up with the same error. Does the Enterprise version read from some
> place else?
> I have been struggling with this for a few days now.
> Thanks.
> http://n2.nabble.com/Code-Review-Print-widget-doesn-t-work-with-IIS7-tp4150860p4824288.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20100330/f3949c8e/attachment.html
More information about the fusion-dev
