[fusion-dev] Pan & Zoom Issues
Michael Adair
madair at dmsolutions.ca
Wed Nov 17 10:38:13 EST 2010
Your selection text looks about right, and the calling sequence goes
through the following methods in layers/MapGuide.js:
- setSelection
- updateMapSelection
- renderSelection
To me it sounds like you have a projection issue and I would look at the
response (specifically extents, map units, and the projection code or
WKT text for your projection) from LoadMap.php in the console to see if
it makes sense - are units in meters or degrees? do the bounds agree
with the map you defined?
Mike
On 17/11/2010 7:49 AM, snowbound wrote:
> Hi all,
> I'm fairly new to Mapguide and Fusion, but an old hat at webDev.
> I am working on modifying the interface of the fusion templates, but am
> experiencing some strange errors.
> I have created some Search widgets, each searches a different table in a
> different way and the delivery of the data to the task pane seems to be
> working fine. When I click on a result row, the expected behavior is the
> default Map.setSelection() which triggers a pan and zoom to that result.
> However what happens is the map view blows out to the furthest possible
> scale - as in outer space.
> what I need to know is after setSelection, what method is triggered to
> create the pan&zoom. Perhaps if I can find that I can figure out what I'm
> doing wrong.
> If its of help, here is the selectionXML that is passed to the setSelection
> method. Does this look appropriate?
> <?xml version="1.0" encoding="UTF-8"?>
> <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd">
> <Layer id="0c6589f0-d476-102d-800e-005056a33fe7">
> <Class id="Default:trails_index"> <ID>gAAAAA==</ID> </Class>
> </Layer>
> </FeatureSet>
More information about the fusion-dev
