[fusion-dev] Upgrading OpenLayers to 2.12
Michael Adair madair at dmsolutions.ca
Mon Sep 10 10:03:43 PDT 2012
Jackie,
I agree that updating would be very useful, however there are no plans
for an upgrade from our side at this point.  I could probably spend a
bit of time testing in the MapServer realm if someone wanted to put the
effort into upgrading.
I think (99% sure) that we use a straight up build of OpenLayers using
the fusion.cfg file to control the build.  If there were any
customizations, I would typically check those into Fusion SVN as a patch
file.
Mike
On 09/09/2012 11:56 PM, Jackie Ng wrote:
> Hi All,
> Are there any plans on upgrading Fusion's internal copy of OpenLayers to
> 2.12?
> There's plenty of useful improvements (eg. Client Zoom, Tile Queues, Tile
> Animation) that are beneficial to Fusion. Client Zoom is a really useful
> feature as it means that our maps are no longer "capped" by the discrete
> zoom levels of any base layers we mix in as OpenLayers will appropriately
> stretch such layers.
> There is only one major change I know of if we do move to 2.12. Yahoo layers
> will no longer be available, and Bing will require API keys, due to the
> removal of the Yahoo and VirtualEarth layer types.
> While we're on the subject, what level of modifications has been done on our
> internal copy of OpenLayers that would need transplanting should we decide
> to move to 2.12?
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrading-OpenLayers-to-2-12-tp5000670.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
