[fusion-dev] Upgrading OpenLayers to 2.12
Michael Adair
madair at dmsolutions.ca
Wed Sep 19 13:12:53 PDT 2012
Jackie,
I've done some cursory testing of the sandbox/ol212 with MapServer side
of things and the update to OL2.12 isn't showing any issues.
The bigger issue on MapServer is the update from MS5.6 to MS6.0 as there
are number of things that are now deprecated in MapServer 6. I'm not
sure the best way to handle that as we should still support the
MapServer 5 line (I think).
Mike
On 19/09/2012 12:15 AM, Jackie Ng wrote:
> I have set up an sandbox branch that's been upgraded to OpenLayers 2.12 if
> you (or anyone else) are interested in playing around with.
> I've also taken a different approach to having a custom build of OpenLayers
> that should make keeping track of any fusion-specific modifications easier.
> Any modifications to OpenLayers are kept under lib/OpenLayers/ext, such that
> when we need to build a new OpenLayers.js, we just overlay these files
> against the official 2.12 source and build with our fusion.cfg
> My initial testing says that the upgrade was mostly smooth sailing. The
> client-zoom works nicely with OpenStreetMap (but only OSM as the other
> commercial layers aren't grid-based).
> I don't know what the current minimum supported IE version is for Fusion (I
> hope it's still not IE6!) but in IE7 the legend looks completely messed up
> and "disabled" buttons in the toolbar aren't visibile. IE8 and above are
> fine.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrading-OpenLayers-to-2-12-tp5000670p5002832.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev
