[fusion-dev] new search widget - Autodesk Infrastructure Map Server
Csaba Janossy
Csaba.Janossy at cadi.hu
Tue Feb 5 07:45:39 PST 2013
Hi there,
I've tried to change the search widget of fusion mapguide following this instruction: http://trac.osgeo.org/fusion/wiki/HowToCreateWidget.
I have created a new search widget master type, name is searchtwo.
I have created this files for the new widget:
fusion/widgets/searchtwo
viewer.css (not changed)
errorpage.templ (not changed)
search.php
searchprompt.php
search.templ
searchprompt.templ
fusion/widgets/widgetinfo
searchtwo.xml
fusion/widgets/
searchtwo.js
Only one step is missing, to add the widget definition to the ApplicationDefinition.xml.
I use the slate template, so I have to define it in fusion\templates\mapguide\slate\ApplicationDefinition.xml?
Do anyone know - How? Because the tutorial not discuss it, without it, the master type is not working.
Thanks,
Csaba
URL: <http://lists.osgeo.org/pipermail/fusion-dev/attachments/20130205/837fed45/attachment.html>
More information about the fusion-dev
