[fusion-dev] new search widget - Autodesk Infrastructure Map Server
Zac Spitzer
zac.spitzer at gmail.com
Tue Feb 5 17:17:08 PST 2013
Hi Csaba,
You need to edit the ApplicationDefinition.xml via Maesto or studio,
inside the repository (i.e. Library:// etc ) (along side the maps, layers
etc)
the one in the file system is a sample
Regards
Zac
On Wed, Feb 6, 2013 at 2:45 AM, Csaba Janossy <Csaba.Janossy at cadi.hu> wrote:
> Hi there,****
> I’ve tried to change the search widget of fusion mapguide following this
> instruction: http://trac.osgeo.org/fusion/wiki/HowToCreateWidget.****
> I have created a new search widget master type, name is searchtwo.****
> I have created this files for the new widget:****
> fusion/widgets/searchtwo****
> viewer.css (not changed)****
> errorpage.templ (not changed)****
> search.php****
> searchprompt.php****
> search.templ****
> searchprompt.templ****
> fusion/widgets/widgetinfo****
> searchtwo.xml****
> fusion/widgets/****
> searchtwo.js****
> Only one step is missing, to add the widget definition to the
> ApplicationDefinition.xml.****
> I use the slate template, so I have to define it in
> fusion\templates\mapguide\slate\ApplicationDefinition.xml?****
> Do anyone know - How? Because the tutorial not discuss it, without it, the
> master type is not working.****
> Thanks,****
> Csaba****
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/fusion-dev/attachments/20130206/1d3554c3/attachment.html>
More information about the fusion-dev
